View Poll Results: How often to you reflash your ecu with the flash tuner | |||
once a month | 2 | 12.50% | |
once every 2 months | 0 | 0% | |
every now and then | 3 | 18.75% | |
not often enough | 6 | 37.50% | |
never OR I dont feel I need to | 1 | 6.25% | |
I plan to now that you have reminded me | 3 | 18.75% | |
I do it too often, somethings not right | 1 | 6.25% | |
Voters: 16. You may not vote on this poll |
13-05-2009, 08:15 PM | #31 | |||
Performance Inc.
I am only a dumb leco but I am interested in what makes my car tic now my tuner who looks after my car explained to me a custom tune resets the parameters for timing, mixtures, idle etc to levels that he uploads via the flash unit to the car computer I get that part. I am trying to understand how the computer decides for it's self (depending on how you drive) the parameters it will use to drive the car why wouldn't the parameters set at the time of tuning say 6000rpm be different say months later in it's setting I just dont see how the car can vary an uploaded program so much?
Funny thing a couple of weeks ago the idle on the car started sticking and being erratic consulted the forum for advice cleaned the T/B and disconnected the battery for about 2 hrs took the oldgirl for a spanking and it went like the clappers dont know if it was the cleaning or resetting the computer by disconnecting the battery but the change was massive. It felt crisper definately quicker maybe I should reflash the custom tune and see how it goes.
In The Garage... FPV Super Pursuit Build no 0080/91 Lotus Exige S/C S240 Kart Hasse Chassis 100J Power Quote:
13-05-2009, 08:57 PM | #32 | |||
BF FPV GT-P Goodness.....
It detects WOT and increases the injector pulse and duty cycle etc. It uses the coolant/air temp sensors to detect cold start or warm and adjusts the mixture accordingly. All these inputs are used to ensure the best performance/ economy. If one sensor goes 't*ts Up' the ECU then has to compensate for this. Not sure what kinda leco you are, but think of the ECU as a PLC and the sensors as inputs and outputs ;) It simply matches conditions. In your case, it sounds like the TB or ISC solenoid was fouled up. A good power cycle also helped, could be resetting the sensor parameters. BTW fpv84d just notice John does your car too, he does a great job doesn't he?
13-05-2009, 09:17 PM | #33 | ||||
Performance Inc.
That reply makes sense it explains how when a major failure occurs the computer makes allowances and enters a limp mode rather just stopping on the road the ECU set parameters dont change so much as the inputs from the sensors cause the changes and by infact resetting the computer ie powering down and back up any temporary stored info would be lost only leaving the written codes in the ecu making the car as good as when it left the tune shop. This would also explain F6FOON saying the car lost heaps of power, the ecu was reacting to the inputs from the various sensors and learnt signals and to a less extent the "written program" by reflashing it may remove the learnt sensor inputs?
13-05-2009, 09:22 PM | #34 | ||||
Back to Le Frenchy
13-05-2009, 09:22 PM | #35 | |||
Wizard Member
Pretty much what I was saying Yeah just disconnecting the battery for a few minutes will do the same thing, but in mine the alarm goes off the whole time so is easier just to reflash it.
Frosty and FPR - Bathurst winners 2013 |
13-05-2009, 09:24 PM | #36 | |||
This is why I replied in the first place as I know that the tune isn't changing, its all the other variables that are feeding the ECU.
13-05-2009, 09:38 PM | #37 | |||
Performance Inc.
Thats what I like about this place you can learn something every day maybe every time I get an oil change @ 7,500k's a reflash should be done. Dont guess there is a limit on how many times you can flash the eprom chip?
13-05-2009, 09:43 PM | #38 | ||
I know after reflashing my Auto XR8, the shifts are way up in the rev range, even with light throttle until it re-learns.
A bit of a hassle with a cold engine ! |
13-05-2009, 09:50 PM | #39 | |||
Most manufacturers rate their EEPROMS at around 1000-1000000 writes, however, the speed of the write can also dictate how long it lasts. As it is an unknown quantity in X2/X3's etc, I'd wanna flash as few times as possible. Found this too(this could be what is causing probs): The timespan over which a ROM remains accurately readable is not limited by write cycling. The data retention of EEPROM and Flash may be limited by charge leaking from the floating gates of the memory cell transistors. Leakage is exacerbated at high temperatures or in high-radiation environments. Hope this helps guys. Regards Mick
13-05-2009, 09:56 PM | #40 | |||
Performance Inc.
Thanks Mick maybe just a power down and repower occasionally to wipe temporary stored info would be better than a reflash anyhow may see you at Johns one day.
Cheers Steve.
13-05-2009, 09:57 PM | #41 | |||
13-05-2009, 10:40 PM | #42 | ||||
AU DIE HARD
14-05-2009, 02:59 AM | #43 | |||
Just slidin'
MD Mondeo - For the family
14-05-2009, 11:54 AM | #44 | ||
Critical Thinker
I never knew some of the things you blokes are saying. And with my limited knowledge probably will only take on X amount of info.
But if I can summarise basically what this page is saying, its saying that the custom tune will not change, but the learnt memory has the ability to change the characteristics of the car based on your driving style/habits?
14-05-2009, 12:19 PM | #45 | |||
Wizard Member
14-05-2009, 01:37 PM | #46 | ||
Critical Thinker
The question still remains for me though, is it still ok to wipe the learnt memory with a reflash every few weeks or will this eventually do damage?
14-05-2009, 01:41 PM | #47 | ||
Wizard Member
Instead of reflashing if your worried, just disconnect the battery for 5 mins every week/month or whatever you feel like
14-05-2009, 02:12 PM | #48 | |||
Critical Thinker
14-05-2009, 02:26 PM | #49 | |||
Back on the road
The reason why this is having any effect is because re-flash also clears the KAM (where all the adaptive learning is stored). Disconnecting the battery for a few minutes would have the same affect. As I understand it, the more thorough the tune, the less correction the adaptive parts of the strategy will try to change the tune. But who is really prepared to pay for 20+ hours of tuning time, when reflashing every few weeks is so easy to do. Possibly more of an issue for those with a "quick" tune from a less experienced tuner. Or for those with radically modified engines.
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
14-05-2009, 02:29 PM | #50 | |||
Back on the road
And as has already been said, no damage from continually re-flashing.
14-05-2009, 02:42 PM | #51 | |||
Critical Thinker
14-05-2009, 04:44 PM | #52 | |||
I program eeproms as part of my business and I can assure you that they can and do fail as a result of continual flashing. I also use far more sofisticated hardware to program them than a flash tuner(I can adjust the speed of the flash etc) I'm not saying this to be some kind of 'killjoy', just as a word of caution and as I have extensive experience and qualifications in Electrical/Electronics & Avionics(on F/A-18 hornet) I am more that able to advise correctly ;) Sure, go ahead and flash away, don't say I didn't warn you though. Regards Mick
14-05-2009, 04:57 PM | #53 | |||
Critical Thinker
14-05-2009, 05:10 PM | #54 | |||
You will need a new EEPROM asa minimum, possibly new ECU, then you need to consider what that may do to your VIN lock on your flash tuner. How long is a piece of string...you cannot say mate. If it goes 't*ts Up' you will be able to recover it, it will just cost you dollars, that all. Perhaps I should get into ECU reprogramming :
14-05-2009, 05:20 PM | #55 | ||
Critical Thinker
Hmm ok, it seems like we have all be warned. I wonder what capa/sct have to say on the matter. Not that I want to dig a slinging match up, but you would think there would be a way around this.
14-05-2009, 05:39 PM | #56 | |||
Back on the road
Once a month for the life of the car (lets be extremely generous and say you do this for 50 years), so you have flashed the thing 600 times. Is EEPROM really so fragile that this would be a genuine issue? Why didn't Ford use a cheap USB key? The instructions that came with my USB key say that I can write to it up to 100,000 times?
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. Last edited by xr8ute; 14-05-2009 at 05:42 PM. Reason: wrong quote |
14-05-2009, 05:41 PM | #57 | |||
Wizard Member
14-05-2009, 05:42 PM | #58 | |||
Wizard Member
14-05-2009, 05:43 PM | #59 | ||
Muzz just flashed his and found the following:
"I think it made the stereo a little louder and it skips the wheels into 2nd?"
14-05-2009, 05:50 PM | #60 | |||
Its got nothing to do with CAPA, the flash unit simply stores the tune, does it very well too. Its the eeprom(where the tune is stored on the car) in the ECU that can give way, as they were never designed to be reflashed a multitude of times with the exception for fords field service actions(which should only be for example 10 times for the life of the car.) Remember, you are altering your tune, not CAPA, not ford, which means you play you pay as was said before. I don't want to create a slinging match between ppl that know and ppl that profess to know etc, tuning out of this thread....pardon the pun...LOL
