#31 | |||
Peter Car
How accurate is your info? |
#32 | ||
Peter Car
Seems to be what they did to the FG in June, a retune and a new cat.
Strange that the old Copperhead engine goes Euro 4 before the Orion does. Makes a mockery of the plan to switch to a V6 because it was so expensive to make the I6 Euro 4 compliant when the about to be superseeded engine can so easily make Euro 4. |
#33 | |||
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s 226.8rwkW@178kmh/537Nm@140kmh 1/9/2013 14.2@163kmh 23/10/2013 Boss349 built. Not yet run. Waiting on a shell. Retrotech thread http://www.fordforums.com.au/showthr...1363569&page=6 |
#34 | |||
#35 | |||
Peter Car
The reason they wanted the I6 gone was due to the fact they wanted to cut the number of different Ford/PAG 6 cylinder variants down from 9 to just 2, the V6 and the Volvo/LR 3.2 I6. But I guess now that LR is gone and Volvo isn't far off being sold that they will only have 2 6 cylinders soon, the V6 and I6. |
#36 | ||
Pity the fool
Still makes me wonder what is in store for the I6 in 2011...E4 is just the start of it.
Fords I own or have owned: 1970 XW Falcon GT replica ![]() Proud to buy Australian and support Ford Australia through thick and thin |
#37 | |||
Regards, Dave
PoweredByCNG: Sick and tired of all the ignorant 'gas is crap' comments out there. |
#38 | |||
IWCMOGTVM Club Supporter
As has been said in many threads E5 is actually a small step from E4. I wouldn't be surprised if Ford could do it with port injection and the cast iron block.
Daniel |
#39 | ||
Lukeyson
![]() Join Date: Mar 2005
To me, the step from SOHC to DOHC with VCT seems a MUCH bigger engineering task than the step from port injection to direct injection. 230Mil is a lot of money to spend on the engineering QA of fitting just 3 engines, so I reckon we'll either see Direct Injection on the I6 (although I expect they'll have to retain port-injection heads for the Liquid LPG variant), different body panels for the Falcon I4T (like Camry vs Aurion) OR Local assembly of the I4T engine.
But are we talking 3 x 16 engines here? ie, the original non-E4 190kW I6, the Orion upgraded plastic-intake non-E4 195kW I6, and now a single E4 compliant I6? Seems to me that the E4 barrier to putting a new engines in either existing or new models would be removed, and if I were running Ford, I would seek to converge the engine-line as soon as was possible. I have it in my head that E5 didn't have much of an impact on Spark Ignition engines, but was focussed on improvements in Compression Ignition vehicles. Lukeyson
If the human brain was simple enough to understand, we'd be too simple to understand it. |
#40 | |||
Problem is, the Euro emissions norms do not take fuel consumption (read: CO2 emissions) into consideration and therefore, with the increase in stringency comes an increase in fuel consumption (claimed to be 10% per level on average). Regards, Dave
#41 | ||||
See my previous post: Quote:
#42 | ||
Like I said, the SINGLE biggest problem with diesel and direct petrol injection is emissions of Nitrogen Oxides (NOx). Because spark ignition engines with direct injection run with a very lean air/fuel ratio, three-way catalytic converters (as used on indirect injection engines) on these engines would be inefficient at oxidising NOx due to the presence of oxygen in the exhaust.
While pre-cat NOx might be lower in these ultra-lean conditions due to lower combustion temperatures, post-cat NOx levels are higher. Regards, Dave
#43 | |||
Peter Car
So Ford will still need to engineer it for the different engine if they want to continue with it, as well as the 5 speed auto cause the 4 speed is most likely finished too. Not too much effort required but R&D costs Vs sales will decide wether it happens or not. Petrol engine could be made Euro 4 like the Territory as its practically the same, but fleets want LPG, not petrol, and LPG is the volume seller. |
