Old 17-12-2011, 10:13 PM   #31
Pedro
Pedro's Avatar
Default Re: Any one use new oil called ''royal purple'' new at supper cheap
Originally Posted by eb-fairmont
i know this may be off topic but with the Castrol Magnetech i think its called they say it sticks to the engine so my question is how on earth do ya know if all the oil has come out or not???? since they advertise it sticks to the engine?
Easy mate, remove the sump plug, stick the garden hose in the top and turn it on full bore ... most of the oil should come out.
Pedro is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2011, 10:16 PM   #32
Falcman0o7
Falcman0o7's Avatar
Default Re: Any one use new oil called ''royal purple'' new at super cheap
Penrite will do me.
Falcman0o7 is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2011, 10:17 PM   #33
Falcman0o7
Falcman0o7's Avatar
Good thing there is an R in your username!
Old 17-12-2011, 10:19 PM   #34
SSD-85
Overly priced for my needs. A good (& appropriate) dinosaur oil is all thats needed to keep a public roader happy.
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2011, 10:26 PM   #35
Silver Ghia
Silver Ghia's Avatar
Yes, stay with the one oil, I supply my own oil (Penrite HPR5) when my FG gets serviced, so the oil stays the same. Have used this oil for about 4 years now, including in the BA, found the engine ran noticably quieter and smoother with it.
Penrite is also Australian founded, owned and manufactured.
Originally Posted by Ford_The_Win
In theory if you change your oil regularly and use the right viscosity and type for your engine it shouldn't make much difference as far as the brand is concerned? I use Castrol GTX, it's cheap, comes in the right grade and seems to do a reasonable job.
I have found using the straight mineral oils that Ford and dealers use (GTX and Magnatec) that the oil level starts dropping after 8,000-10,000km. Then when draining the oil, some of it has a watery consistency. I have found that Penrite HPR5 does not do this, even after 15,000km in the engine. Fully synthetic oils the same, they retain the viscosities much better.
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2011, 10:31 PM   #36
Shonky.
Shonky.'s Avatar
Originally Posted by prydey
also, don't be tricked into thinking the colour of the oil means something. most oils have detergents and all sorts in them designed to clean your engine so they will go dirty. they still work how they are supposed to.
Never thought of that. I've always assumed clean oil for a long time = oil doing a good job (and vice versa). Probably not the case.
I do believe you are better off buying the cheapest adequate oil and changing more regularly though (and be consistent in what you use as others have said)
Shonky. is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2011, 10:57 PM   #37
Ford_The_Win
Interesting that you mention that, I noticed that just before the last service which was a bit later than normal. But it would be impossible to rule out oil leaks and oil being burned by the engine in a car like mine. After 13 years and 120XXX kays of being run on the same Castrol mineral oil it would be a bit pointless to switch over now, but in a new car that would be an important factor to consider.
2011 FG XR6 Sedan
Ford_The_Win is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2011, 10:59 PM   #38
Ford_The_Win
My oil normally goes dark quickly and comes out pretty much black even after 6,000 kays. I'm guessing that's a bad thing?
2011 FG XR6 Sedan
Old 17-12-2011, 11:08 PM   #39
bigsta
Making superman jealous
bigsta's Avatar
i just put castrol edge full synthetic in mine, and so far seems to use slightly less petrol, only reason i went full synthetic is because im doing the service every 15000kms and i dont have much faith in mineral oil last much more than 10000kms.
bit pricey though at $69 per 5LTR.
Anyone know where you can get it cheaper?
If life deals you lemons dont complain just get on with it and make lemonade
2006 SY Territory Ghia AWD in ego with roof mount DVD, tints, 7 seats, iPod input
2005 Crewman Cross 8 with 350 cubic inches, AWD, black on black rims on black leather, tints and polished racks
NEW TOY Bayliner 185, inboard 3L 4 cylinder pushing us along at 50MPH whenever i get a chance
I love Aussie cars and are gonna really miss them soon.......
bigsta is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2011, 11:20 PM   #40
Windsor220
Now Fordless
Windsor220's Avatar
Oil is oil. Dont understand why people buy $100 oil and then replace it every 3 months.
Old 18-12-2011, 01:01 AM   #41
SpoolMan
Solution Was Boost 4?, 6 & 8
SpoolMan's Avatar
I will buy a years worth of oil for both our cars on boxing day supercheap have there 20% off store wide sale..
$69 - 20% off = $55
[SIGPIC][/SIGPIC]
SpoolMan is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2011, 01:33 AM   #42
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Penrite HPR gas does me for both our Fords. I buy it by the 20L drum. I looked at that Royal Purple right up till I saw the price then decided it was too overpriced. you end up paying a premium just because of the name. It's like buying a Harley, you pay extra just for the name on the tank. I am trying Nulon Diesel in the Delica as there was a 20L drum of the stuff sitting there when I bought my last drum of Penrite and it was at a very good price. That should see me out for over 12 months with the Delica as it only goes out on the weekends so it should be a good test to see how well it stands up over an extended period.
Bushbasher
MINE- AUII Forte
Old 18-12-2011, 09:19 AM   #43
mickyyyy
Im suprised no one is using Valvoline...
Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc
mickyyyy is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2011, 10:39 AM   #44
Paxton
Cobblers!
Paxton's Avatar
I was - their 15W-40, but Bursons doesn't stock it, so I'm now using Nulon.
Penrith made my engine noisy (and I don't buy their extra 10 line), Shell was ok, but my engine is far happier with a 15W-40 than anything else.
Ego BFII Ghia
Titanium Silver E53 X5 4.4i
Gunmetal EF XR6. Now retired from active duty.
Roses are red. Violets are blue. OS X rocks. Homage to you.
Paxton is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2011, 10:56 AM   #45
XBROO
Obsessed with wheels
XBROO's Avatar
Have they started making big stickers for the RP brand? I want to stick one on all my cars, oh and the bike.
XBROO is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2011, 01:09 PM   #46
Peter B - CV8
Quite the opposite actually. It means your oil is removing contaminants & holding them in suspension - rather than allowing them to adhere to surfaces & start sludging up.
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2011, 01:15 PM   #47
FreddyDUZ747
FreddyDUZ747's Avatar
Smile Re: Any one use new oil called ''royal purple'' new at supper cheap
Exactly,the reason imo Castrol Edge is overated.
FreddyDUZ747 is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2011, 01:52 PM   #48
pottery beige
to sludge.. or not to sludge....
Old 18-12-2011, 01:57 PM   #49
FreddyDUZ747
Only our findings from LS engines.Tried it once in mine a couple years ago when I first came on forums and it came out lighter than the Penrite previouslly used,quite alot lighter actually after same kms.
Old 18-12-2011, 02:07 PM   #50
pottery beige
really, mine darkens up fairly quick in the Boss, always up it, but methinks tune needs a look at mo bt me cbf........
