Old 15-01-2015, 02:47 PM   #31
Vesper Martini
Vesper Martini's Avatar
Default Re: Oversize
Originally Posted by XR6 Martin View Post
It states down the bottom of this document your allowable width overhangs. Project no more than 150mm each side, as long as it does not exceed 2.5m
https://www.vicroads.vic.gov.au/~/me...ria.ashx?la=en
Just because some says something, doesnt not over rule what is actually written down as regulations. Unless youve got their name and have recorded the conversation it will mean nothing the next time a VicRoads officer pulls you over, and if he's having a bad day he can force you to not to go any further till you get the applicable permits.
Also as I said before it can result in your insurance being void if there is an accident.
I know of a truck driver who had it happen to them because the truck was 30cm too long (due to a bull bar)
Thanks that is a useful document, but its from 2007 they created the Class O vehicle in feb last year, which Naddis has supplied the info above for.
this regulation was brought in for light vehicles. so you don't need a permit.
My issue was the information was not readily available, I would argue that Vic Roads should be stipulating when its first registered that it complies with these Class O regs
there are many Boats on the Roads here that are in the same "Boat"
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2015, 03:05 PM   #32
XR Martin
XR Martin's Avatar
Whatever mate, there are no exemptions anywhere in the country regarding the 2.5m rule.
Dont be surprised to find yourself regularly pulled over, as I know for a fact the road authorities and the highway cops are all targetting these oversized boats.
2004 BA wagon RTV project.
Old 15-01-2015, 05:06 PM   #33
xtremerus
FG XR6T trayback
xtremerus's Avatar
Or can be over the 2.5m rule by the thickness of the ropes on the trailer.
This was before the use of straps.
xtremerus is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2015, 06:52 PM   #34
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Originally Posted by Gaz View Post
Get a grinder and shave 5mm off each side? Probably easier!
Would need to be 50 mm actual- well 45 to be exact!
I was thinking the same thing - however does the boat have some sort of ID tag that states length and width etc? (Is this how they knew you were oversize or did they pull out a tape measure?)
What a lot of pain for 9cm.
This may be a stupid suggestion, but would it be at all possible to rig up something that loads then tilts the boat?
Nah - forget that idea! The top half of the boat will eventually widen the overall width again if it id angled too far.
Old 15-01-2015, 11:35 PM   #35
Matty4
Banana
Matty4's Avatar
My boat trailer is exactly 2.5 wide (Aus built so it complies) and I had to have it put on a flatbed the other day. The driver told me he had an exemption to be wider than 2.5 without signage because they will sometimes carry a 2.5 wide load, so need to be a bit wider to fit it on, just like my boat and trailer.
2024 Ford Ranger Wildtrak V6 w/PP
2012 WK2 Jeep Grand Cherokee Overland CRD
Matty4 is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2015, 10:24 AM   #36
Vesper Martini
[QUOTE=Yellow_Festiva;5307126]Would need to be 50 mm actual- well 45 to be exact!
[QUOTE]
The Cop has a special app on his phone that tells the dimensions of the boat when you put in the make/model, it would be near impossible to measure with a tape as its sort of an oval shaped boat.
But they did get the tape out for the trailer.
Old 16-01-2015, 07:25 PM   #37
naddis01
naddis01's Avatar
Originally Posted by Bevsta007 View Post
The link Naddis has just kindly posted does not say that.
The multiple people at vic roads did not tell me that.
Finally The Cop that fined me did not tell me that.
Did you happen to read the entire regulation or just the one page I posted?
naddis01 is offline   Reply With Quote Multi-Quote with this Post
