Old 21-12-2015, 06:29 PM   #31
T MAN
T MAN's Avatar
Default Re: AU i6 & V8 engine oil, what are you using & are you happy with it?
mine are 60 psi cold start at idle with both oils and normal driving at operating temp is around 40-45psi, in extreme conditions as in hard running on hot days the hpr10 does drop into the low 30s sometimes high 20s at idle.. the hpr 15 seems to stay in the high 30s low 40s psi when hot...
T MAN is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2015, 06:38 PM   #32
99AUXR
Brad
99AUXR's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Installing starter motor advice on ba / bf 6cyc Falcon.
When engine is hot, 2000 RPM oil pressure should be 275-413 kPA = 39-60 PSI
Just check your values against this as to whats best, but either or should do, if the thinner one meets these specs then go with that if not as you were
Silhouette BF MKII F6
Plazmaman Intercooler Kit, ID1000, 34mm Internal Wastegate and Turbosmart Actuator, Tein Coilovers, Focal Audio, XXR 521 18x8.5 18x10
99AUXR is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2015, 06:46 PM   #33
zdenko
2002 XR6 VCT Owner
I have mainly used Shell HX7 10W40. Some Penrite and Castrol Semi Syn 10W-40's as well depending on Supercheap specials.
Xr6 VCT on LPG.
Been running it since I bought the car with 130000kms and it now has 240000kms.
Doesn't burn a drop and it comes out pretty clean every 10000kms.
SOLD: 2002 AU3 Falcon XR6 VCT on Impco Mixer Gas
Factory Leather and Towbar
Stock 17' rims Perfect After Fixing Myself
Air Hog Air Filter + 2.5 Inch Sterling Mandrel Bent Exhaust + Supercheap Oval Tip.
Carbon Fibre Style Vinyl Wrapped Roof and Boot
zdenko is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2015, 12:53 AM   #34
Fairlane Al
I hope I'm not the only one here who will admit to just running whatever 15w40 oil is on cheap special at Repco or Supercheap. Admittedly changed every 5 to 7000 km and mainly doing fairly easy highway cruising, it comes out somewhat darker and dirtier than when it went in but not particularly so. Right now it is running Nulon oil, before that Shell HX5.
I have considered if I should upgrade to a nicer semi synthetic or synthetic oil but I can't see the point when it still holds good oil pressure nicely at 260,000 km, at least according to the gauge, it doesn't make noises, and I haven't blown the motor up yet. At least I'm changing the oil, I don't think the previous owner knew or cared to know that oil is best changed on a regular basis.
Fairlane Al is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2015, 07:37 AM   #35
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Hi Fairlane Al, thanks for your reply mate! Imo if your happy with how its running, I wouldn't change anything either. Keep up the good work mate, good luck!
cheer's, Maka
Old 22-12-2015, 07:43 AM   #36
Maka
Maka's Avatar
Xr6 VCT on LPG.
Hi zdenko, sounds like your happy with the way your vct is running atm, if it ain't broke don't fix it hey lol! Keep up the good work mate, good luck!
cheer's, Maka
Old 23-12-2015, 07:25 AM   #37
Maka
Maka's Avatar
Hi guys, the 5/40 has been in for a few days now & the hot day / cold engine startup tac noise is a lot better now, will give it a few more days to see if the noise disappears completely. My motor is getting on a little now so some noise is to be expected on startup tbh, will see how it goes & go from there.
The Nulon that come out was pretty dirty, glad to change it out for sure!
cheer's, Maka
Old 23-12-2015, 01:06 PM   #38
PridenJoy
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For his contributions to the forum, especially showcased with his highly detailed AU build threads. He is a fountain of AU knowledge.
I'm scratching my head a little bit, when i first bought my wagon ( just a six dual fuel), i changed the oil and put synthetic 15W40 (shell i think), but shortly after (maybe a month) i found half the oil was gone (car has zero leaks), so i put in some Nulon Mineral 20W50 and on checking the oil yesterday I found the level has also dropped a fair bit, this things burns oil which is strange because the spark plugs have no oil on them.
Being dual fuel, it might cost the same in regular oil top ups as the LPG.
PridenJoy is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2015, 01:07 PM   #39
PridenJoy
Oh and I use Penrite 10W40 in the XR8 ute.
Old 23-12-2015, 05:44 PM   #40
Maka
Maka's Avatar
Hi Sam, my hunch is check your pvc valve, the oil maybe getting burnt with the air-fuel mixture? You can pull the black breather pipe off the t/b & see if its wettish with oil. Good luck mate, hope its a nice simple fix hey!
cheer's, Maka
Old 23-12-2015, 06:25 PM   #41
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
Up to 200000 I used castrol gtx 15w40 changed every 150000km, city driving.
I did about a year on penrite 15w60 and penrite gas after that to see if there was any difference. Car felt slightly "heavier" on acceleration, but other than that, no difference. I even had it tested and at 15000km and the oil was as new - run mainly on LPG. The main issue was that the dirt was beginning to build up in the oil. If it was worthwhile to run a bypass filter, I wouldn't bother
changing the oil!! Stretch the change out to 40k to 50k.
Back on the supercheap specials now. I was planning on doing another test, but the oil testing company I was using wasn't taking samples at the time. I will post up next time I get a result.
Evgeni is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2015, 09:48 AM   #42
PridenJoy
cheer's, Maka
Hey Maka, the PVC valve was replaced about a month ago as it was busted in pieces and causing a vacuum leak. I'll check the breather pipe anyway just to make sure that's not the cause.
Old 24-12-2015, 10:47 AM   #43
NCII40
XR6T BA 2002
NCII40's Avatar
My oil pressure never moves regardless of driving conditions and over the different oil i have used stated above
I saw mcfly94 using 15w60?
Can anyone comment on this
XR6T 2002 BA
NCII40 is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2021, 04:38 PM   #44
1TUFGQ
Hi, apologies for the grave dig
We just bought an AU VCT XR6T ute with 296,150km on the clock.
Runs well and seems to have been well maintained, i'm going to change thge oil and filter this weekend as a matter of course (don't know when the last change was done).
I did a search and came up with this thread, am going to put a Ryco Z9 on and have got some Penrite Vantage 10W/30 Semi Synthetic. I hope that was a good choice of oil?.
Will keep an ear out for tappet chatter, we don't get thge hot temps you guys do over there so may even drop back to 5W/30 if need be.
Cheers from NZ.
1TUFGQ is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2021, 12:22 PM   #45
XC50077
Drive'n Cruise'n Live'n
XC50077's Avatar
Using Penrite 10w/30 premium mineral in my I6, travelled 215K ,change oil and filter every 10k. Does notrattle or burn oil and stays relatively clean. Cheers
XC50077 is offline   Reply With Quote Multi-Quote with this Post
