Old 23-11-2019, 04:54 PM   #31
JasonACT
Away on leave
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Outstanding work on the FG ICC issues. Technical Contributor: For members who share their technical expertise. - Issue reason: The insane amount of work he has put into the Falcon FG ICC is unbelievable. He has shared everything he has done and made a great deal of it available to us all. He has definitely helped a great deal of us with no personal gains to himself.
Default Re: NEW 'Sniper' coils for 6T's!!!!!!!
I got a generic note from my tuner, for my flash unit he programmed.
It says you must set your plug gaps to 0.75mm or the car will misfire. BA-BF turbo only. FG turbo plug gaps are OK at std gaps.
(Mine is an FG. Also says, all turbo engines must run on 98 Octane.)
JasonACT is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2019, 05:02 PM   #32
arronm
BA/F6 BF/F6 SSV/R TTG
arronm's Avatar
$200
https://www.ebay.com.au/itm/GENUINE-...L/300992973718
BA BF FPV starter button repairs. PM me.
Nizpro equipped and Tuned by the BEST in the west
Xtreme Ford Tuning
479RwKw Fuel limited, more pumps and power too come.
F6#0507 & #0639 Pro racer and Tech expert
NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below.
https://youtu.be/oa4IfguGQ-A
arronm is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2019, 10:48 PM   #33
Cashie
Cashie's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Multiple helpful contributions throughout the tech area.
Originally Posted by QUIKXR6T View Post
No it ISNT Cat007 as i have just proven!!!!!!!
The boost pressure obviously blows the spark off the plug under high load.
I just been driving quite hard before and damn it goes much better now...
Def not stock this project car i really want to throw it on BPRD Dyno and find out if its been tuned already.....
It goes very well and spools up quick as!!!!!!!!!!!!!!
Isn’t it still misfiring?
Current Rides:
2017 Ford Mustang
2020 Ford Everest Sport
Past Rides:
2017 Kia Stinger GT
2008 FG XR6 Sedan
2008 FG G6E Sedan
2004 BA XR8 Sedan
2008 BF XR6 Turbo Sedan
2004 BA XR8 Sedan
2003 BA XR8 Ute
2003 BA XR6 Sedan
Cashie is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2019, 07:02 AM   #34
GASWAGON
Sometimes while idling AFTER giving it a bootfull???
GASWAGON is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2019, 11:43 AM   #35
GasoLane
Former BTIKD
GasoLane's Avatar
Mate, the ****ing compressor housing is bigger than a stock 6T turbo cos i has the ****ing thing off to replace the gaskets
SO, obvoiulsy, more fuking air is being pumped in than stock!!!!!!!!!!!!
I ****ing told you .....' it aint stock'!!!!!!!!!!!
You were asking for help so there's is no need to be abusive when someones suggestion doesn't agree with your ideas.
As for 'blowing the spark off the plug' I have never ever heard of that.......
I wonder how the supercharged engines manage not to do it
Old 24-11-2019, 11:50 AM   #36
Blue Dog
NSW Highway Patrol run E10 in the turbo falcons.
98 in the Commodores.
Blue Dog is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2019, 12:30 PM   #37
JasonACT
Away on leave
Sorry, I should have been more clear.. It was referring to once programmed with his tune - they all must then use 98. That's also the reason I wouldn't change to a different brand of coil, they may be good with a stock program (maybe even better) but I'm pretty happy with what I've got and it would risk needing another tune. That would put the final price of using different coils much higher for little reason.
Old 24-11-2019, 12:36 PM   #38
Blue Dog
Re:
"The boost pressure obviously blows the spark off the plug under high load".
Impossible!
How can the boost pressure possibly blow the spark off the plug?
Think about it............
The intake valve opens.........
The air & fuel mix passes through the intake valves.......
The valves close as the piston is on its way down the cylinder......
The piston gets to the bottom of its stroke & then travels back up the cylinder, with both intake & exhaust valves closed.....
When it's nearly at the top of its stroke, the spark plug fires & the piston is forced back down the cylinder.
It's the density of the fuel air mix that creates the problem with ignition.
Old 24-11-2019, 12:41 PM   #39
arronm
arronm's Avatar
Sounds like valve springs. Are yours stock BA?
Xtreme Ford Tuning
Old 24-11-2019, 12:45 PM   #40
JasonACT
Away on leave
I'd agree with the air/fuel thing, but also..
My understanding is, increasing the plug gap size increases the time it takes for the spark to form. You need a certain amount of volts for a spark to jump a particular distance - and the coil ramps up to that voltage - it can't produce it instantly.
But this is probably not going to misfire, it just won't produce all the power you are expecting.
Old 24-11-2019, 12:54 PM   #41
arronm
arronm's Avatar
Originally Posted by Blue Dog View Post
Re:
Impossible!
Correct, but we call it spark blow out. But people think the spark is literally blown out by high boost.
We could leave the large gap and increase the voltage. OR keep the stock system and reduce the gap.
https://youtu.be/1mD9Ye-ygso
Xtreme Ford Tuning
Old 25-11-2019, 12:51 PM   #42
Bossxr8
Peter Car
Bossxr8's Avatar
SO, obvoiulsy, more ****ing air is being pumped in than stock!!!!!!!!!!!!
Nice anger issues.
Got you mixed up with the other thread with the guy with the stock BA Turbo having misfire issues due to bad coils.
Old 25-11-2019, 02:15 PM   #43
cat007
Woah - calm down son.
Unless you're running a LOT more boost than stock, i.e. you've had a tune done and pushing 15-18PSI, a 1-1.1mm gap is not going to be causing your under load issues. Closing the gap to 0.7mm to resolve the issue on a MOSTLY STOCK Barra is just masking the real problem. Have you checked all earths?
Tell me how will a tighter gap help with this idling problem if you're talking about the spark being "blown out"? I doubt she's making >15PSI at idle
cat007 is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2019, 03:00 PM   #44
GASWAGON
Tell you y...cos the ****wit atmy Bursons toil;d me this and reckons he úsed to work for NGK.' for 15 years.
I apolisgise Cat007 as your 4 stroke cycle is correct.
BPRD did meteion that BA's can break conrods when pushed to far AND they can also suffer from 'valve float' while under hesavy load ie Valve springs too soft.
Thanks guys i have just realised and solved what the problem is.
New valve springs and Dyno test just to find out its max power output is coming soon!!!!!!!!!!
Old 25-11-2019, 08:06 PM   #45
GASWAGON
C uz on the road............. SKEGGS!!!!!!!!!!!
Old 26-04-2020, 06:35 AM   #46
NCII40
XR6T BA 2002
NCII40's Avatar
so the sniper coils weren't the problem ?
XR6T 2002 BA
NCII40 is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2020, 10:31 AM   #47
arronm
arronm's Avatar
Its not valve float as such. Its the high boost pressure blowing the closed valves off their seats.
Xtreme Ford Tuning
Old 26-04-2020, 03:49 PM   #48
fnp
Aside from coils, I found my both my BA and FG only like the standard Ford plugs too. Anything other plug (NGK, Bosch, etc) would start misfiring under load within 15k or so.
FG XR8 289rwkw
ED Fairmont Ghia 5.0 broken
fnp is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2020, 04:42 PM   #49
MercuryT
MercuryT's Avatar
Originally Posted by Franco Cozzo View Post
OEM coils are good quality - stick with the genuine Ford stuff.
I know an old post Franco but no definitely not. I went through multiple sets in quick time.
I can't remember which brand I eventually bought (off EBay) and they were great, never failed again but Ford were overpriced crap imo (plugs too)
MercuryT is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2020, 08:54 PM   #50
TrVrPhiLpsiNdstrys
I tried a few snake oil coils !!
BF Ford original saw my highest mph and dyno readings...
Yes I tried them all...
Old 26-04-2020, 09:41 PM   #51
arronm
arronm's Avatar
General consensus says stock ford coils are the best.
Xtreme Ford Tuning
Old 27-04-2020, 08:27 AM   #52
Fed
I think most coil problems are caused by carbon contamination on the plugs & coil shrouds.
I'd explain why but it's embarrassing and might not make sense unless you were an electrician.
Fed is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2020, 08:45 AM   #53
In light of that, what about the shading of rust that sometimes creeps up the insulator when wells get damp? I’ve often been suss about this as a possible source of spark leakage.
Old 27-04-2020, 09:05 AM   #54
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
The parts specified by OE meet more stringent testing to their own or industry standards than the aftermarket stuff does.
This car is making 1028KW/wheels on the factory ignition system until they started running into problems with it.
I'd say there's other issues with the electrical system if it was frying the factory coils repeatedly, if you get a bad earth on the electronics side of the coil/ignition system, that'll do it pretty quick smart.
Old 27-04-2020, 09:15 AM   #55
I used to see a lot of audiophile argument about star vs point-point earthing, interesting it doesn’t seem to come up in highly stressed automotive applications.
