29-08-2005, 09:49 PM | #31 | ||
Two things are a MUST for the next all new Falcon which is due in early 2008 (code name Orion):
1. ensure that the new model is no heavier than the current car at minimum and lighter than the current car should be the target 2. Introduce a smaller capacity version of the 6 cylinder engine. Up to the EA model Ford offered two capacities of the 6 cylinder for more than 20 years. Not everybody needs four litres of donk which puts out 190kW of power. A three odd litre version of the current engine would have approximately 140kw. It wasn't that long ago that this was the most power you could get in a Falcon. And a lot of people found it to be adequate. Those who don't can get the larger 6 cylinder version. As the Orion will have a 5-speed auto for the poverty pack models I see this could work very well will a say 3.2 litre engine. FF |
29-08-2005, 09:56 PM | #32 | |||
LPG > You
Navara diesel = 75 litre tank. So... 600km out of 75 litres is 12.5 litres/100km 320km out of 76 litres is 23.7 litres/100km We'll use these figures as averge consumption. I'll also use the figures for 91 RON, Diesel and LPG I observed today as examples, $1.19/L for 91 RON, $1.31/L for Diesela and $0.39/L for LPG respectively. I'll also use the amount of driving I'd do on average a week when working in the city from my house etc as an example (about 500km). So with the diesel car, I'm getting 600km to the tank, using 500 a week, that's 5/6ths of my tank. 5/6ths of 75 litres is 62.5 litres. So every week, I'm putting 62.5litres of diesel into my car, at $1.31/litre, that's $81.88 a week. Multiplty that by 52 weeks, and we get $4,257.76 in fuel bills per year. Now, with the petrol engine, I'm only getting 320km to the tank. Which means I've got to fill up the tank plus an extra 42.66 litres to make 500km, every week. 76 + 42.66 = 118.66 litres a week. Multiplied by $1.19 a litre, that's $141.21, by 52 weeks, $7,342.92 a year in fuel costs. Now, say I decided to convert the petrol car to dedicated LPG. That's approx $2500. Now, on average, one burns 1.2 litres of LPG for every 1 litre of petrol, so, multiply our 23.7litre/100km figure by 1.2 and you get 28.44/100km. Now, since my car is now dedicated LPG, I've put a gas bottle where the petrol tank was, so for this example, we'll use the same capacity figure of 76 litres. Now, 76 litres and 28.44/100km will net me 267km per tank. So, lets just say, for this example, I fill up 76L twice a week. 76 x $0.39 = $29.64, x 2 = $59.28 per week. Multiply that by 52 weeks in a year and you get $3,082.56 in total for the LPG vehicle. So, that's a $4,260.36 saving over petrol for the year (thus paying off the conversion costs, and then some)... and $1,175.20/year cheaper to run then the diesel car. Ahem. LPG = Way of the near future (until we go hydrogen or whatever) for Australia At least, that's how I see it.
LPG Lovers Association President & Member #1. : |
29-08-2005, 09:56 PM | #33 | ||
The 'Stihl' Man
interesting info you have there FF....you might want to say where you got that info before misleading people?
29-08-2005, 10:00 PM | #34 | |||
Viper FG XR6 Turbo
29-08-2005, 10:05 PM | #35 | |||
Viper FG XR6 Turbo
um falcon coupe was quoting figues from a diesel towing large trailers, trailers make your car suck huge amounts of fuel, in some cases a large trailer can half the distance from a tank. anyway, with LPG currently at 50cpl at some places, and will be taxed in the short future, i doubt its worth the conversion cost |
29-08-2005, 10:07 PM | #36 | |||
LPG > You
Plus, LPG isn't getting taxed until 2007. I wonder how much petrol will cost by then?
29-08-2005, 10:14 PM | #37 | ||
Clevo Mafia Inc.
Not to mention lpg kits for RA rodeos were taken off the market due to problems including regularly blowing airbox apart and taking out the o2 sensor at the same time, so i looked into gas injection, that kit cost nealy 5k and the injectors need replacing evey 40,000klm, plus the shorter engine life on lpg throws that option out the window.
So, they way i see it, diesel with double milage towing a trailer over petrol is the way to go. |
30-08-2005, 10:23 AM | #38 | |||
LPG > You
IMO the injection kit is worth it.. it'll pay itself off in a year and a bit - two years absolute max.
30-08-2005, 10:25 AM | #39 | |||
im looking forward to reading the results from the long term LPG v Petrol test you're conducting! Especially after you've pulled both motors apart to check wear rates etc, when will the results be in??!! :Reverend: Ive said it before and ill say it again, LPG is for barbeques!!! :Reverend:
335 S/C GT: The new KING of Australian made performance cars.. |
30-08-2005, 10:49 AM | #40 | |||
Hoon On The Rise
Maybe Steffo is testin this theory on a AU cab..... :
Stomp 'n' Steer FGX-XR8 Manual, BFII E-Gas, '11 GSXR 1000 - Love 'em!
FPV Tickford Club of NSW - www.fpvclub.com |
30-08-2005, 11:01 AM | #41 | |||
The reasons; LPG produces more acids than petrol, the oil breaks down quicker but looks clean, the acids attack bearings & seals. Check out the recomendations from the manufacturers, you'll see that LPG engines require a higher rating. LPG also causes oil to thicken with age, so not changing oil & filter at specified intervals leaves a too thick oil to circulate to the valve train. Petrol has a natural cooling effect, this causes the air/fuel charge to be denser (more power) and also helps cool the valve & top piston ring. LPG does not have this, so there is more heat stress in the combustion chamber. So there is good and bad with LPG. |
30-08-2005, 11:05 AM | #42 | |||
30-08-2005, 11:08 AM | #43 | ||
Its yellow, NOT green!
4Vman & I seem to have dissagreed on most things, but yes, LPG is for BBQs. Its horrible, it adds weight, it stinks, it has an ugly red sticker on your number plate and an even uglier metal filler cap on the side of the car...yuk yuk yuk!
EL XR8 sedan - low & loud FG XR6 Turbo ute - Auto & Lux pack Last edited by Citric GT; 30-08-2005 at 11:10 AM. Reason: Spelling |
30-08-2005, 11:12 AM | #44 | ||
Formerly Black EX-R6
Does anybody actually have hard data on LPG and the damage it does to engines reducing engine life or possibly even data on the incident rate of major failures in LPG installations compared to actual installation numbers.
So far all im reading is opinion and nothing put forward as actual fact or researched in any obvious way. Oh, and according to this article HERE The government wont be taxing LPG till 2011 and even then only 12.5c/L. The current Government excise on petrol is 37.7c/L in vic.
""It's not the ideal way to win, but we got here, so yeah baby," said Kelly." Stinking, mongrel, dog. Last edited by Black XR6; 30-08-2005 at 11:22 AM. |
30-08-2005, 11:14 AM | #45 | ||
What does a tired BBQ fuel debate have to do with this topic?
Even Burke & Wills never made it this far off track!! |
30-08-2005, 11:19 AM | #46 | |||
LPG > You
30-08-2005, 11:28 AM | #47 | ||
Well Stefo, Ill put that one down as a stroke in the LPG is good column. Anybody got anything printed or on the web that demonstrates how bad it is?
""It's not the ideal way to win, but we got here, so yeah baby," said Kelly." Stinking, mongrel, dog. |
30-08-2005, 11:32 AM | #48 | ||
I wonder if sales of Fords E-Gas Falcon have increased with recent petrol pricing? I was looking at buying a base model petrol BA ute, but now very interested in the E-gas option
1966 Ford Mustang coupe. 347 stroker, PA reverse manual C4, TCE high stall converter, B&M Pro Ratchet, Edelbrock alum heads, Edelbrock intake manifold, MSD ignition, Holley Street HP 750 CFM carb, gilmer drive, wrapped Hooker Super Comp Headers, dual 3" straight through exhaust, Bilstein shocks, custom springs, full poly suspension, American Racing rims, Open Tracker roller spring saddles and shelby drop. Still to go - Holley Sniper EFI with integrated fuel cell. |
30-08-2005, 11:33 AM | #49 | ||
I know it roots valve stem seals quick fast. When I pulled my old clevo out not one was intact they were all lying in the bottom of the sump both exhaust and inlet!
30-08-2005, 11:38 AM | #50 | ||
So we have info stating:
The gov wont be taxing LPG till 2011. And then only 1/3 pf the current petrol tax. LPG systems are simpler wth no need for surge tanks, electronic fuel pumps, carbies, injectors and ECU's in most cases. Its cleaner, high octane, and runs smoother Oil stays cleaner longer and LPG dosnt contaminate oil Less Ring Wear Less risk of spillage in accidents and less risk of fire hazard Sounds good so far!
30-08-2005, 11:46 AM | #51 | ||
Less rind wear :
When combustion temperatures are higher and lack of lubricating properties playing havoc with your cylinder cross hatch pattern? Not to mention the abuse that the guides and valve seats cop espesialy on the exhaust side. I don't think so. out: |
30-08-2005, 11:46 AM | #52 | |||
Below is a quote from this website.
30-08-2005, 11:48 AM | #53 | ||||
Another quoted section from a web page. HERE Quote:
""It's not the ideal way to win, but we got here, so yeah baby," said Kelly." Stinking, mongrel, dog. Last edited by Black XR6; 30-08-2005 at 11:59 AM. |
30-08-2005, 11:54 AM | #54 | ||
Mate you never take a leaf out of the beuracrats book their a pack of scum bags that are just intersted in filling their own pockets. Out in the REAL WORLD ive seen the consequences of poor gas installations which most are.
The problem stems from poor placement of converters/mixing bowls and poor tuning. Gas is very tempermental in that running it too rich/lean will root your engine while in a petrol engine its MAINLY running lean is what you need to be worried about. |
30-08-2005, 11:55 AM | #55 | |||
This gas debate has nothing to do with the topic, BBQ conversions and comparisons are something quite different from manufacturer willingness to offer E-Gas etc. Car manufactures will cater their product to the wishes of those actually in the market for new vehicles, simple business survival. |
30-08-2005, 12:02 PM | #56 | ||
I think its on topic enough. Considreing we are talking about companies not willing to adapt and adopt cheaper fuel technology wether its better petrol consumption or an alternative fuel.
Believe me Ive tried to find good and bad website about LPG. Havent found one website that proclaims its bad.
30-08-2005, 12:04 PM | #57 | ||
Adapt or perish...
Why are some people bagging gas here?
I run dual fuel on my ute, I get an extra 600km range just by having gas. There's a 75 litre petrol tank, which gets filled $20- $30 at a time when the DTE hits 80 or lower. I also have an 80 litre gas tank, which costs me no more than $35 to fill. Both these tanks get me over a 1000km range, which means I fill up on average once every 10 days. I agree with some that gas is the way to go. Even if you go dual fuel, you're still saving money. Yes, I'm not in the best mood either, people who are bagging gas, don't knock it until you try it.
Carless
30-08-2005, 12:06 PM | #58 | ||
Any taxi drivers here? How do you guys get maximum engine life? Do you run the engine on petrol for a few kms once a fortnight or something?
30-08-2005, 12:07 PM | #59 | ||
The last thing we need is more diesels on the road. its bad enough with people owning cars they cannot maintain. let alone more smokey diesels.
i see so many unserviced diesel landcruisers and other mitsubishi's and other makes its not funny. blowing big clouds of soot. People are attacking this from the wrong angle. BioDiesel and Bio Alcohol blended fuels or striaght bio fuels are the way to go. but hell Sultin Durka Durka wont make any money if we dont buy crude oil. and shell, bp and mobil cant make squilions in coullison with the govt either. (excise etc, gst) It all comes down to Not the environment but how much money can be made from the plebs. Govt and big corps. |
30-08-2005, 12:15 PM | #60 | |||
If there were substantial savings and cost benefits to be made dont you think the high volume korean economy cars would have adapted to what is a pre-existing rather than innovative technology? |
