Old 07-04-2007, 02:03 PM   #31
JC
JC's Avatar
Have you tried a different battery? And I can't recommend changing the coilpack enough.
Ford Performance Club ACT
Old 07-04-2007, 03:19 PM   #32
hfcrussell
hfcrussell's Avatar
Anyone got heads up on how much the coil packs are. I actualy saw it yesterday under the manifold. Does look like a mission.....
Russell.
1973 XAGT Coupe T B T B , , 1974 XBGT Sedan T B B M, 2011 Territory Titanium TDCi, 2014 Ford Ranger XLS 4x4 Dual cab 3.2TD 6 speed auto, 1974 XBGS Coupe Y L P 2
hfcrussell is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2007, 03:24 PM   #33
bodes-sh
about $80 from supercheap, try coventrys and repco probably as well
Old 07-04-2007, 04:17 PM   #34
loony888
loony888's Avatar
mine was starting but wouldn't idle without a bootful of throttle, read on here somewhere that the inlet manifold works loose and sucks in air till there's enough expansion from heat to seal it. i checked mine and EVERY manifold bolt was a good 3/4 turn loose. tightened it up and it fixed my problem completely. try that before spending any more cash.
cheers,
paul.
i was going how fast officer?
loony888 is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2007, 05:04 PM   #35
JC
JC's Avatar
cheers,
paul.
Good one! Don't know why I didn't think of that (too focussed on coilpacks, lol).
Old 07-04-2007, 06:06 PM   #36
all4fordau
I had the same problem with mine. Definately check the manifold bolts. Had me stumped and my mechanic had it fixed in a couple of hours. How do these things come loose???????
all4fordau is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2007, 06:38 PM   #37
hfcrussell
hfcrussell's Avatar
Good call there... Some were loose. But not enough to be the problem.
Ive just been to supercheap and a1 auto but no coil packs avaliable @$139.00.
Just put in a new set of plugs and had the battery disconected overnight but cant test drive till tomorrow.
Russell.
Old 08-04-2007, 11:05 PM   #38
TwistedEL
TwistedEL's Avatar
hfcrussell I just replaced my coilpack today. Took about an hour. Got a genuine one for $55 from eBay.
It's a ***** of a job I'll tell you that for nothing.
But it drives like a new car, except that the motor was still jumping around a bit at idle in gear. I've sorted that out by increasing the base idle on the throttle body, that's doing the trick.
Oh and supercheap don't stock ANYTHING to suit AU. Retards.
Old 09-04-2007, 09:37 AM   #39
hfcrussell
hfcrussell's Avatar
This car still takes about 1-2 minutes to start from cold.
It now drives heaps better through the rev range, with no hesitation or missing.
I have the air box out so i could look for loose spark last night but there was nothing.
Old 09-04-2007, 11:45 AM   #40
MNM96
LIFELONG DJR SUPPORTER
MNM96's Avatar
Twisted,
You got an Ebay link. I looked, but only found EF/ EL units. (EL had a dissy?). Are they the same (EF and AU)???
Cheers,
Mike
Old 09-04-2007, 07:24 PM   #41
TwistedEL
TwistedEL's Avatar
Hey mate it was a private seller not a shop link you can try asking if they have another if you want.
russell I am in Belmont you can come and grab my old coilpack if you want, it still works fine it's just getting a little old (155,000 k's). Might be useful to confirm your problem.
Old 09-04-2007, 07:49 PM   #42
bodes-sh
I got one off ebay today aswell, $86 delivered. Keep in mind the coil packs for au1 and 2/3 are different,
this one is a bit more but here it is anyway...coil pack
Old 09-04-2007, 08:02 PM   #43
hfcrussell
hfcrussell's Avatar
That would be great Twisted..... Can you pm me....
Old 09-04-2007, 08:51 PM   #44
MNM96
MNM96's Avatar
Thanks Twisted and Bodes-sh
Today I tightened the Intake Manifold bolts. Some went up a little, but imo not enough to make a difference.
I am suffering similar issues to hfcrussell. Done plugs, leads, fuel filter and a gauze in the tank and at manifold. Had Carbon clean done. Car sat a Ford Dealership for two days and all they found was an inactive Coil Pack failure. They said it is not the cause, I'm not sure now.
This is where I am going now.
Keep trying things, and we will work it out, 4 sure.
Cheers,
Mike
Edit,
Just purchased the one you linked Bodes-sh, Thanks
Old 09-04-2007, 08:59 PM   #45
AUXRVIII
When the engine is running how much combustion is coming out the exhaust? Also does it feel excessively hot? Undo the engine pipe at the exhaust manifold when it's cold then see how it starts. Another thing worth a try is to disconnect the map sensor, a faulty sensor will cause running issues but a disonnected sensor may cause it to run a default mode and see how it starts.
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2007, 09:01 PM   #46
hfcrussell
hfcrussell's Avatar
MNM96,
Can i ask how much Ford charged you for their services? I am scared to send mine there......
Russell.
Old 09-04-2007, 09:05 PM   #47
hfcrussell
hfcrussell's Avatar
Ive disconnected the O2 sensor to try and fault find but theres no noticable difference in starting or running. Should there be?????
I noteced this morning on cold start that once the car did start it was very rich smell so i think i have eliminated fuel from the problem.
I cant block my exhaust because there is an exhaust leak some where.....
BTW which one is the MAP sensor??
Russell.
Old 09-04-2007, 09:38 PM   #48
AUXRVIII
Car will run fairly well with O2 sensor disconnected, it's only used for trimming injector on time.
By disconnecting the exhaust it eliminates a blocked muffler or cat converter. An exhaust leak is no indication of free flowing, it could be corroded internally and have a collapsed baffle, that why I asked how hot the exhaust gasses are.
Map sensor is located on inlet manifold under the throttle body, it will be difficult to disconnect.
Old 09-04-2007, 10:15 PM   #49
bodes-sh
Cheers,
Mike
Edit,
No worries, we're all here to try and help
Old 10-04-2007, 01:15 AM   #50
MNM96
MNM96's Avatar
Originally Posted by hfcrussell
MNM96,
Russell.
Russ,
They were too embarrassed at there inability to find the drama to charge me. I was crapping when it came 'pay up' time, after two days, turns out, very surprised.
The mechanic said, when cold, my car goes harder than any AU HP he's driven?
Runs shite when warm!
Does yours seem to hesitate when taking off with more throttle applied, and get going when you lift to a lesser throttle percentage.
Ford replaced my Throttle Body under wtty. I think the problems began about then, and got progressively worse?? :
Cheers,
Mike
Old 11-04-2007, 12:04 PM   #51
hfcrussell
hfcrussell's Avatar
OK. I picked up a spare coil pack of TwistedEL (thanks Graeme) but still the same.
MNM96 my car seem oppisite to yours, its only a pig cold. Once its hot its fine.
The best way to start this car is to crack the throttle slightly but it still takes time for it to start.
Russell.
Old 11-04-2007, 08:01 PM   #52
AUXRVIII
Sounds like there might be an issue with the IAC motor, stuck shut perhaps? Have you had this checked? Also could be an out of range TPS, I think the best approach for you would be to have someone retrieve codes from it if it has any.
Old 12-04-2007, 12:43 AM   #53
TwistedEL
TwistedEL's Avatar
Yeah go the codes
I stopped by a mechanic today and asked how much to pull the codes off, he said a couple of beers
Old 13-04-2007, 07:43 PM   #54
hfcrussell
hfcrussell's Avatar
Well, i`ve bitten the bullet and have to use the "F" word.
I have taken it to Ford and will get it back next week.
Old 14-04-2007, 02:30 AM   #55
TwistedEL
TwistedEL's Avatar
bugger
Old 16-04-2007, 11:32 PM   #56
hfcrussell
hfcrussell's Avatar
Got the call from Ford today and they said it was the fuel pump.
Seemed strange but i told em to fix it......
Old 17-04-2007, 12:11 AM   #57
JC
JC's Avatar
From the first page:
Originally Posted by JC
If the car turns over (ie starter works), but it doesn't fire, then I would say it's fuel or spark related. So, I'd be checking fuel filter and fuel pump (filter is only $20 odd, but hard-ish to fit, fuel pump is a bit more expensive and a bugger to fit in a wagon).
Once it's starts, if it sort of runs OK, then I reckon spark is probably OK, so I'm really thinking it's fuel related. Get that filter checked, and if it's OK, definitely get the pump checked too.
Sometimes it pays to take it to the experts (Ford). Hopefully it will actually fix your problems.
Old 17-04-2007, 12:23 AM   #58
hfcrussell
hfcrussell's Avatar
Yes JC,
I did go back to the first page to see who was right.
Still seems unusual to not have fuel to start but enought to fling the engine to 3-4000 rpm when running..... me no comprehende....
Old 17-04-2007, 12:25 AM   #59
JC
JC's Avatar
Yes JC,
Yeh, me either - but that's cars for you!
Old 18-04-2007, 11:10 AM   #60
james22
With da Warlords
james22's Avatar
Might have to check my fuel pump then. I started a thread on the same thing last winter when I bought my AU II, and never resolved the problem, bugger me.
Link to my old thread
http://www.fordforums.com.au/showthr...highlight=cold
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
