Old 11-07-2009, 03:08 PM   #61
4Vman
4Vman's Avatar
Originally Posted by ltd
Unless the item is specifically mentioned in the warranty as not being covered, it is covered. I do agree, they do tend to use very generic descriptions of what is not covered like exhaust system, fuel system etc. Also, isn't this guys car still covered by the Toyota factory warranty or is it like ford at 3 years 100000klm?
It pays to read the fine print on used car warranties...
Ive seen limitation placed on value of repairs, engines and drivelines excluded except for complete failure i.e piston through block, head gaskets specifically excluded, "normal wear and tear" excluded... the warranty actually covered very little and in may circumstances had a cap set on repair costs...
So all im saying is make sure your complaints are actually covered under the warranty in the first place.
335 S/C GT: The new KING of Australian made performance cars..
4Vman is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2009, 03:55 PM   #62
ltd
Force Fed Fords
ltd's Avatar
Couldn't agree more. If it isn't covered under factory warranty then it would be best to read the warranty documentation from cover to cover including all the minute fine print to check no exclusions are in place first. Should it be the case, then getting independent validation of the complaint would be the best option forward. As you undoubtedly know 4Vman, many a place have unspoken policies of fobbing off a complaint to avoid paying for something.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
