12-11-2009, 01:13 PM | #61 | ||
Deaf Driver
Around 670 in one full tank to get me back to Canberra from Melbourne on Monday - almost ran out of fuel just in time to arrive in Canberra, I stopped to the nearest petrol station.
Former owner of 2009 5dr Silverdust Ford Fiesta Zetec (Manual) In the look out for WS/WT Zetec Ford Fiesta (Manual only) in 2016. |
12-11-2009, 06:10 PM | #62 | |||
'09 Vision 5 Dr Man Zetec
2009 Vision 5 door manual 1.6l Zetec 16inch rims w/ front mudspats & factory stone chip protection. |
12-11-2009, 09:04 PM | #63 | |||
Depends on how much torque the engine has, I bet the air con affects the diesel Fiesta alot less, it hardly changes the fuel use on a V8 at all but the Fiesta has a few litres to spare on bigger cars anyway |
12-11-2009, 09:06 PM | #64 | |||
12-11-2009, 09:48 PM | #65 | ||
I can only go to the first bowser stop. Any more and it overflows...
13-11-2009, 10:51 AM | #66 | |||
Deaf Driver
13-11-2009, 11:24 PM | #67 | |||
Using a complicated calculation I estimated the fuel consumption at idle with the A/C on and off. A/C off: 1.01 Litres/hr A/C off: 0.74 Litres/hr (a tiny 12 mL per minute when you are stopped at the lights.) So the A/c (on a fan speed of 1) was using 0.27 litres per hour. I've used the fuel meter and odometer and added 12% which is my fuel meter error. Now make the bold assumption that the A/C uses the same amount of fuel at 50 km/hr or 100 km/hr as at idle. So at 100 km/h it will add 0.27 L/100km (eg. from 6.00 L/100km with A/C off to 6.27 L/100km with A/C on.) At 50 km/hr it will add 0.54 litres/100km (eg. from 6.00 L/100km with A/C off to 6.54 L/100km with A/C on.) This is a more reasonable average speed, for my week anyway. My impression is the A/C effect is smaller than this but I use recycled air. There are many assumptions built into this. The A/C was at 100% duty cycle when I measured this. If you use recycled air and the A/C switches on and off (which it does, although the fan keeps going) the fuel consumption will be lower. On the other hand if its a hot day and you don't use recycled air and have the fan on 4, I'm sure could easily be double this and add 1-2L/100km (at least at an average speed of 50 km/hr), if not more.
"Look at that! The smoke grenades fit perfectly in the cup holders." "I've got 120 horse power in this. You don't want any more than that on marble." - Jeremy Clarkson on the WS Fiesta Zetec |
13-11-2009, 11:29 PM | #68 | |||
The first time I put 41.26 litres in (to first click). The second time I put 42.63 litres in (to first click). This is on a 43 litre tank (although I'm sure I read 42 litres somewhere). So DTE is not a bad guide. I wouldn't push it! :togo:
14-11-2009, 11:36 AM | #69 | ||
@BruceT, I asked a similar question of our 4WD group since they were adding engine analysers to thier cars, one of the screens shows current fuel consumption. It worked out that it was around 2l/hr more @ idle with the AC on.
I'm sure there is a margin on the DTE calculations, but that is running it close!
14-11-2009, 08:59 PM | #70 | |||
Distance at travelled: 523 km Distance to empty : 162 km Total : 685 km Refilled with 32.47 litres and the DTE after refill said 703.7 km. The real fuel economy was 6.20 L/100km, my gauge said 5.5 L/100 km. I had A/C on 1 and recycled air all the way (there were breaks to avoid CO2 poisonning) - don't drive more than 2 hours on recycled air! The trip is quite hilly and I travelled with me mum and about 80 kg luggage (say equaivalent to 3 persons total). I get the impression that extra load and hills really drag down fuel economy. On the way down to Bega - before I picked up my mum at Bowral - the gauge dropped to 5.2 L/100km, but my mum brought the proverbial (kitchen sink) and the total load in the car must have been around 400 kg (I had to adjust the headlights and the mirrors!), so the real economy was 6.45 L/100 for the trip down.
14-11-2009, 09:06 PM | #71 | |||
And on DTE, the 2nd one was a shock as I thought after the first effort that a DTE of zero meant 1.5 - 2 litres left. I'm confident you can run DTE to zero, but you better have a petrol station nearby when you do! It also gets a little unstable with around 80 km left (when the refil light comes on). For awhile it drops too slowly, making you overconfident, the somewhere around 20-25 km it starts to drop rapidly. All of a sudden at 12 km it went to zero!
18-11-2009, 01:37 PM | #72 | |||
18-11-2009, 07:14 PM | #73 | ||
Perhaps a new thread....How many kms did you get after your DTE said it was empty!
(& how did you get home after that!)
18-11-2009, 07:30 PM | #74 | ||
BruceT, you must have a prodigy in engineering. I have a scangauge and the fuel consumption hovers around 0.8-0.9L per hour without AC and ~1.2LPH with AC on. Mine is an auto however. The figures you posted earlier were close nevertheless.
18-11-2009, 10:30 PM | #75 | ||
curik, what speed is the sweet spot... i.e. best l/h usually around 80km/h I would have thought....or is the resolution of the scangauge insufficient to easliy show that?
PS thanks for the numbers!
19-11-2009, 08:11 AM | #76 | ||
Oh I forgot to say that those figures were during idle. And also those with autos like me, switch to N when waiting at the lights, leaving in D actually uses about 50% more fuel (based on the litres per hour reading on scangauge).
SK, I haven't tested about the sweet spot yet, since I don't hit freeways much. I need to drive on a long stretch of straight road to be able to get a valid conclusion. But I can't do that since I live in the city and don't go out to suburbs often. |
19-11-2009, 03:09 PM | #77 | |||
20-11-2009, 04:32 PM | #78 | ||
People, check out the onboard diagnostics information on this forum to be found here...
http://www.fordforums.com.au/showthr...=1#post2940109 & post your indicated fuel usage @ 100km/h. It will be interesting to see any varience. PS I'm hoping it reads litres per hour....
22-11-2009, 03:52 PM | #79 | ||
Be cool to see whos' getting the best fuel consumption on which firmware version, once we get a few up.
26-11-2009, 11:37 PM | #80 | ||
I drove 100km/h today reset the fuel average once I got on the highway. I averaged 4.5L/100, had a railway crossing 80 zone, and a 60 zone for roadworks and another 80 zone for a small 10 house town :p. Apart from that sat right on an indicated 100 the entire way and clutched down a few big hills. Pretty good!. It was sitting on 4.4 most of the way but the road got really rough for the last 20ks and I was struggling to keep the average under 4.6 at that stage. I think I can do really low 4's if I were to drive the same way on hot mix. Still can't get diagnostic mode to come up tho :S
26-12-2009, 11:41 AM | #81 | ||
ok did the first trip in the festy to vic.. had cruise and air con on all the way at 100kmh.. i got 5.3ltr/100km and that included about 30kms of city driving..
so relatively happy with that since it only has 5000 on clock |
26-12-2009, 12:35 PM | #82 | ||
Thailand Specials
Mines only got 2200km on the clock it seems to be using about 6.62L/100km but thats with a bit of redline here and there.
26-12-2009, 06:31 PM | #83 | ||
XCPWSF, have you checked what software it's running?. I didn't know Pirates was illegal here that's a shame, it's a very fine movie
27-12-2009, 09:41 PM | #84 | ||
BASS ON BOARD!
My wife does 98% town driving (ACT) and its about 7-7.3 as per the trip meter. Im just waiting for blownba to be able to cutom tune them
Nothing interesting to put here. |
28-12-2009, 11:13 AM | #85 | |||
Thailand Specials
DTE was 480km though and its on 3/4 of a tank. |
29-12-2009, 08:22 PM | #86 | ||
Thailand Specials
Also while playing around with it today, i noticed once screen saying "Er 125" or something similar, is that an error code?
30-12-2009, 08:10 PM | #87 | ||
I think they are error codes but I've no clue what they mean, the number for the tune is a two digit hex number there's a thread somewhere in here with the numbers we had in ours. It seems to be the lower the number the newer the tune
26-07-2012, 12:09 PM | #88 | ||
so can anyone supply the latest firmware version # that is being flashed by ford at the moment?
On the economy side, I can tell you the minute by wife puts her butt in the drivers seat all my efforts at hypermile-ing go out the window (I aim for 600km out of a tank 100% city). |
26-07-2012, 10:52 PM | #89 | ||
LZ Titanium Focus
Get the manual diesel people and enjoy getting 900km out of a 40 Ltr tank (combined city/country). Still have never done a long trip @ 23000km.
Even when driving hard averages under 5ltrs/100kms. Aver 4.3. I have brought the Ecoroute Bluetooth device to connect to the OBD2 plug, and watch the fuel economy figures live. Great device and useful for extra gauge readouts. Temp, battery, real speed, etc. Garmin gps way to go. |
27-07-2012, 08:13 AM | #90 | ||
