21-08-2007, 06:52 PM | #61 | ||
really..
when you push for power (both torque and Kw) stuff breaks doesnt matter when or how if its pushed beyond what its built for then its going to be destroyed turbo ..n/a..nitrous..supercharged... some guy with a lead foot and a deep pocket for tyres.... all are going to break SOMTHING hell the BTR transmission dies just by looking at it in stock form
21-08-2007, 07:03 PM | #62 | ||
And I agree stuff breaks, hell ive broken a Z spec gearbox with a shade under 140rwkw and 410nm of torque (Autotech's Dyno).
I dont even want to think about the amount of $$$ gone into tyres over the last years ive had the car, at 350-400 each that I replace every 3 months.. hmm expensive.. Ive had the diff go, ive had a gearbox go, thats about it.. IM saying a force fed car will break things ALOT easier and sooner than what a N/A car will. Torque is what kills a driveline, not the HP or KW your making. |
21-08-2007, 07:43 PM | #63 | |||
Just slidin'
Yeah, its ok, I do understand. I guess its different for us up here in QLD, we dont have to worry to much about enginering, and insurance doesnt come into play as its easy to get with the car enginered. At leat you do have (most of) the driveline to put the power through now. And Stiddy, I believe what you are saying is correct, the torque will kill the auto quick smart.
MD Mondeo - For the family
21-08-2007, 07:46 PM | #64 | ||
the Term 'power'.. means different things to different people too
some think its Kw some people is torque.. so yeah
21-08-2007, 07:52 PM | #65 | |||
Oh Yeah!
To stop what happened to my engine (if it turns out to be blow by) is probably not much. I mean you buy a turbo for one reason to put the foot into it everynow and then and if you dont what was the point. I didn't thrash my car or do burnouts and it still happened. Nothing worse then having a good turbo on an engine you know if you put your foot down it will blow. Id be weary if you are going to buy a AU with a turbo on it as they are most likley selling it as they are having issues. I could be wrong its just hard to tell they could do a patchy job on a fix only for it to be your problem 6 months later. Day 3 Quotes have come back and the engine will be going down tommorrow and hope to have it back next week. Its getting a full proper rebuild with the lot so the engine alone should be able to give good power even without the turbo. It will have to be run in for a good 3000-5000km on about 6psi before it gets boosted back up. Ill posts some costs when I get them but the bottom part alone is roughyl $1700
Oh no! Duffman can't breath! Oh, yeah! |
21-08-2007, 09:57 PM | #66 | ||
Thats a cheap bottom end.. The conrods I want for my build are close to that mark!!
whats getting done, parts? brands? Having your motor at that stage, I would recommend a stud girdle. |
21-08-2007, 10:34 PM | #67 | |||
22-08-2007, 03:52 PM | #68 | ||
justa6
keep at it duffman. yeah you will break stuff, and it probably will end up being over 10grand. but gee it's fun doing it
22-08-2007, 04:13 PM | #69 | ||
justa6
also duffman, i've got a jmm stage 2 turbo cam and springs. it's all i've had in it so i can't compare with anything else but it makes plent of power.
22-08-2007, 07:21 PM | #70 | |||
I dont want cheap tyres, its great steping off at 4000rpm and launching with no spin what so ever.. and other times.. well thats fun to lol.. Im looking forward to some boost through my thing.. and it will be done properly.. few other things before then though.. arms recovering from rubbing the ol' girl back. |
22-08-2007, 08:18 PM | #71 | |||
22-08-2007, 08:51 PM | #72 | |||
Sly like a G6
Power is a measure of work done and is calculated as torque times revs divided by a constant. Same meaning no matter how many people you have. The difference can be difficult to conceptualise, especially as torque is a rotational force rather than linear. Think of the difference between hitting a nail once with a hammer (applying force) as against driving the nail all the way in (doing work - applying force 1 or more times until the desired result is achieved) Gearing (torque multiplication) muddies the water too. AutoSpeed had an article some weeks ago on Power v's Torque which showed that:
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
22-08-2007, 09:13 PM | #73 | ||
("(O.o)") Fear the EL!!!
It all depends how you do it casper, you do all the work yourself you should have a good system capable of 230rwkw for around 5000... Depends on what you know you and who you know...
04 Silver BA XR6 Turbo, Now with 241RWKW thanks to CV Performance! : |
22-08-2007, 09:33 PM | #74 | |||
Z-spec is a beefed up T5.. |
23-08-2007, 03:47 PM | #75 | |||
Sly like a G6
Starting with the same stock I6 you shoot for 250rwkw, spending $15,000 to do it properly as per Casper's list. You get 150% more power. Guess what, still $100 per 1%. So on BFYB there's nothing in it. You can probably argue that the cost of the CAPA option should include strengthening the tranny. I'd argue that if you don't thrash it all the time the tranny would last pretty well. If you drive under 3000rpm 90% of the time then 90% of the time boost never goes over 4.8PSI. In my case the tranny has 315,000km up and will need replacement eventually. The extra cost of a strengthened box is not much over a reco'd standard spec. So I reckon you get what you pay for, and on BFYB the CAPA kit doesn't look like such a rip-off after all.
23-08-2007, 09:28 PM | #76 | ||
i'm now facing the dilemna of supercharger vs turbocharger....the main thing holding me back with supercharger.. is no real room to gain more power... but with turbo.. you can just increase boost.. (for all the Mr. Negatives out there.. assuming the driveline has been strengthened)
but i guess i'm not looking to keep the car for a great length of time.. so the supercharger might be a better option considering prices etc... |
24-08-2007, 01:08 AM | #77 | |||
Tuned @ Pitlane Frankston
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
25-08-2007, 07:21 PM | #78 | ||
Turbo Falcon Fiend
Any updates Duffman?
Too many turbo toys...... 2009 FG F6 Nitro LPI LPG 290rwkw on LPG. 2005 BAMKII XR6 Turbo with LPG (ex HWP 255,000k's and counting) Honda 2001 CR500E Road registered CR500 Honda 1985 CR500 (the one with the arm ripping power) DT200r regoed Hack Yamaha IT/YZ 465 Vinduro rocket Imported IT465 and 490 back up bikes VF1000R mid 80's racer built by HMR Honda CR480 Air cooled project road cafe racer. T88 Turbo XT Falcon project with 351 Cleveland (mothballed) Plus the rest. . |
26-08-2007, 03:15 PM | #79 | ||
Oh Yeah!
Is where it is at now. At the moment the engine and manifold are off being machined/put back together hopefully should have some more interesting news soon
01-09-2007, 03:03 PM | #80 | ||
Oh Yeah!
Not much of an update on the rebuild topic (ill post a big post about it later) but I am thinking of putting on some 19" bf tyhpoon wheels and adding a bf typhoon front bar to replace the te50 one. The main thing I am worried about with the bar is that it may not flow with the car and will just look odd. I hate the vs commos you see with vy body kits that just look stupid so hopefully it wont turn out like that. Ill get the front bar painted up so it looks like the one on the typhoon r-spec.
So if anyone is interested in some furys or a t3 front bar let me know.
01-09-2007, 03:05 PM | #81 | ||
got pics of the front bar?.. or are there some at the beginning of this thread?..heh
actually just checked... and nevermind.. i'm going to leave the stock bars on. |
03-09-2007, 12:03 PM | #82 | ||
Let us know what you want for the front bar
13-09-2007, 01:34 PM | #83 | ||
duffman, just out of interest, have you found out what caused the engine to pressureize yet?
the AU im looking at has everything.. full wolf 3d, injectors, cooler, fuel pump, etc.. standard engines shouldn't just die like yours did unless there was something wrong with it, right? please let me know ASAP what happened to yours so i can re-assess the purchase of the turbo.. cheers
21-09-2007, 03:53 PM | #84 | ||
Oh Yeah!
Well I was a bit lazy and didnt keep the thread up to date but here are some pics:
The manifold also got machined as it had a tendency to blow gaskets All I have to do now is put it all back in and its on the road! The engine has been fully rebuilt with compression lowered etc so it should go good
21-09-2007, 05:23 PM | #85 | ||
How many rwkw are u looking to get ounce u have finished???
21-09-2007, 05:34 PM | #86 | ||
Awesome......
AU2 XR6 VCT...
Powered by Vortech : T1 TE50 #094 : |
22-09-2007, 12:40 PM | #87 | |||||
Oh Yeah!
Sorry I havent answered any questions lately
26-02-2008, 10:40 PM | #88 | ||
Spin 'em Habib !
Time to Beef this Thread back up ..
My AU is in the Stages of Being Turbo'd Within the next Month .. IM going to run a Stock Bottom End , And Buy another Motor and Put the ACL Rebuild Kit in it just incase .. Now heres something i think though .. A Lot of you guys are horsepower hungry , For some , to say that a jump from 140 to 190 Kilowatts is unoticable , then thats just you ... For my to have 40 more kWs at the Treads would be awsome .. and mine wont be running on the track .. basically going to be For Cruising and Showing .. It Can be done , It Will be done , Progress is Progress and at the End of the day , it if Works , then others will follow .. (Also , Yella-Terra might be helping me with the Install - woot)
AU2PWR |
26-02-2008, 10:46 PM | #89 | ||
what does the ACL kit have that a normal rebuild kit doesnt??
is it just more heavy duty stock rebuild parts?? good luck!
26-02-2008, 10:48 PM | #90 | ||
www.TUFFCARPARTS.com
AU bottom ends are pretty tough things man, as long as it's tuned right and you don't abuse it (ie thrash when cold, over rev etc) then it will cope with alot more than you'd think.
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
