04-02-2014, 12:04 PM | #61 | ||
As I stated before by the time the XY model arrived Ford Au effectively made the HO an option giving it the same common model code as the XY GT rather than having a stand alone different model code for the HO. This effectively turned a corner and made what was stamped on the compliance plate less significant and the sum of special homologation parts fitted by the manufacturer much more important. Rather than a typo Ford Au may have been making this a point by only stamping Falcon GT on the compliance plate of some early HO3 cars! If we carry this logic over to the 3 XA GTHO race cars what is stamped on an ADR compliance plate, it could be Falcon 500 for all I care!, is of little significance.The manufacturers intent, the purpose they were modified for, the special massaging and homologation parts fitted and the sheer weight of documentation should be what identifies these cars as the 3 Factory Works XA GTHO race cars.
Cheers Mick |
3 users like this post: |
04-02-2014, 01:06 PM | #62 | |||
wtf were they if they weren't P4s boofhead |
04-02-2014, 01:16 PM | #63 | ||
Its common knowledge there were 3 prototype Phase 4's & 1 production car made. Why is that so hard to understand?
Mercury Silver 03 BA GT-P Tremec TR3650 Number 534 Herrod 4 into ones, Manta Exhaust, CAI, K&N Filter, Mellings oil pump, 19" FPV alloys, Bilsteins, Kings, tuned by Autotech, 272rwkw RIP Fish 15/1/73 - 9/2/19
04-02-2014, 01:26 PM | #64 | ||
Isn't it obvious?
anyone else have that picture in their head of Biff knocking on Marty Mcflys noggin????
08 Strike G6E T. 10 Ergo G6E Sept 75 XB Falcon in mushroom beige, 3 on the tree 200cid for sale, offers in the teens |
04-02-2014, 01:55 PM | #65 | ||
I think its been determined that HO stands for handling options so the race cars just received a higher level of handling options so you are right that doesn't make them HO's it makes them HHHOOO's which is better and they are still GT's so that actually makes them the highest optioned HO's around, and that's the truth!
http://www.fordforums.com.au/showthr...sic+xp+cruiser |
04-02-2014, 02:40 PM | #66 | ||
Hmmmmm...
04-02-2014, 03:20 PM | #67 | ||
its only hard for some to understand.......for a long time people believed there was such a thing as a phase 2.5 also....as time goes on the myths swallow the truth. at least we all know now that if either of the red phase fours or prototypes or just xa gt s come up for sale we wont be bidding against castellan as the 2 red cars are not ho s. . if ford says its a phase four but castellan says its not what does one believe?
04-02-2014, 04:34 PM | #68 | ||
Yeah, wouldn't own one of those red shitboxes if you paid me. I mean, can you believe it got through Ford QC with a burnt door trim from the freshly welded rollcage.
Like i said shitboxes! Bahahaha
2 users like this post: |
04-02-2014, 05:03 PM | #69 | ||
04-02-2014, 05:08 PM | #71 | |||
04-02-2014, 05:12 PM | #72 | ||
now your just trolling
go read some more books bonehead |
04-02-2014, 05:14 PM | #73 | ||
04-02-2014, 05:18 PM | #74 | ||
No the correct term is 3 XA GTHO race cars no need for a prototype as the mechanicals were a carry over from the XY..........and 1 higher spec 'Pilot' road car was sent down the production line as a timing test to make sure everything was in place for the run of 200 more HO4 road cars. Cheers Mick |
04-02-2014, 05:20 PM | #75 | ||
04-02-2014, 05:29 PM | #76 | |||
3 XA GTHO race cars. I pilot XA GT-HO road car made in the production line. I would accept that is correct. |
04-02-2014, 08:55 PM | #78 | ||
04-02-2014, 10:14 PM | #79 | |||
The XY GT-HOs only came out with 31 spline if they had 3.5 or 3.89 Diff Gearing. Otherwise it was 28 spline with 3.25 Diff Gears. |
04-02-2014, 10:21 PM | #80 | ||
If I had a choice between a Phase 4 and new FG GT, I take the Phase 4. Hands down.
04-02-2014, 10:30 PM | #81 | ||
What would they be advertised at a reputable auction?
05-02-2014, 06:04 AM | #82 | ||
If i had a choice between a Phase 4 & an average Sydney home i would still take the Phase 4. Hands down.
4 users like this post: |
05-02-2014, 09:57 AM | #83 | |||
As to what i was refering to with all this was the car magazine and to go through that mainly first and for most. The fact is there was never a XA GT-HO Phase 4 ever sold to the public on page 71 there is a Dealer confidential bulletin saying so. So we are talking about one pre-production HO. and this was made after the 3 race cars and the 3 GT that had HO parts fitted and some RPO83 with the HO parts fitted to some degree. So there is only one XA GT-HO ever truely made. So when Eddy ask's the million dollar question you have to say, only one pre-production in fact. 3 race cars built by ford race division but different spec to the pre-production so called GT-HO, now are this lot of 3, Phase 4 ? The Phase 4 has a diffrent combustion chamber and a tamer cam as Bill Santuccione says so ? Am i right or am i wrong, that's why after reading the mag is why i ask and i think this would be the best place to ask. |
05-02-2014, 01:51 PM | #84 | |||
The Phase 4, 4v heads had some machining done to drop the compression down slightly from 11.5 to 11.0 to 1. And the camshaft was slightly different too. These changes and a couple of other mods (Factory Headers, Bigger Sump, Flexi-fan with a Bigger Radiator, and better QC Assembly) made the Phase 4 motor better, flexible and more reliable compared to the Phase 3. If you read the Phase 4 articles in Street Ford. Roy puts a stock Phase 3 and the Phase 4 motor on the Dyno for a comparison and you will see the difference. |
05-02-2014, 09:16 PM | #85 | ||
Peter Car
They machined the combustion chamber to remove any high spots that may have led to pinging, the result of this machining was a slight drop in compression, although the ph4 engine still made a little more power.
06-02-2014, 12:47 AM | #86 | |||
The deck height of the CK 617 cylinder heads were a bit thicker which raised the combustion chamber volume slightly and this is what dropped the compression slightly........smoothing of sharp edges is more of a anti pinging thing. Cheers Mick |
06-02-2014, 04:31 PM | #87 | ||
Peter Car
Learn something new everyday. Never knew that.
06-02-2014, 05:22 PM | #88 | |||
Dot heads have as you say raising the cc volume slightly. The P4 motor could run a 3.0 diff so she with this cam must be so much better down low performance. It does not say what the cam spec is, maybe it's one of the USA BOSS or HO spec. We had our own aussie spec in the Phase 2 and phase 3. P2 being the biggest then ford tamed it down a bit with the P3 and again with the P4 and it goes to show that it's not only the size of the cam that makes it perform better. The mag also goes on about the P4 blowing away of a P3 in top end and he did that in 3rd gear, haha ! but he does not say what diff ratio the P3 was running maybe 4.11 diff for all we know haha ! just had to point that out as well as some people can be misled in understanding. |
06-02-2014, 09:23 PM | #90 | |||
Your camshaft info is rubbish..........both the HO2 and HO3 ran the same DIZX-AA 494 th lift camshaft.........the HO3 also had an optional larger 524 th lift camshaft option........logic would assume the same DIZX-AA camshaft would of been originally used in the HO4 also. Cheers Mick |
