#61 | ||
Wirlankarra yanama
The issue I have with E10, my car gets worse fuel economy using E10, approx 10% worse than using straight petrol. This worse fuel economy is not compensated by 4 cents per litre less in price. Now if E10 were 10% cheaper it would make it worth using.
#62 | |||
Current FPV FG GS Ute, 2 x PX XLT 4 x 4 twin cab Rangers, XB GT, BMW K1200S, previous 2 x FGXR6 turbos, before that BF Magnet & endless list before that. And remember: Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Beer in one hand - meat pie in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!!" |
#63 | ||
IWCMOGTVM Club Supporter
Some cars will respond well to it while other cars will suffer from it. Its up to the individual to work this out. People throw 98 in regular engines which is essentially throwing money out the door.
Daniel |
#64 | |||
#65 | |||
If your vehicle was designed to run on regular unleaded, the octane rating of the E10 would be too high for it and create a reduction in power and economy greater than that attributed to just the E10 alone. Peter ![]() |
#66 | ||
335 kw of goodness
This has been going on since the start of the internal combustion engine was invented. You just go a bad batch of fuel. Out of hundreds of thousands of people that fill up everyday & have no trouble you are the odd one out. The sad thing is, there's not much you can do about it.. Chalk it up to experience & move on. Its happened to all of us at one stage or another...
CAUTION! STILL Contain's opinion's & fact's that may offend !!! ![]() 2012 GTP 213 black what was I thinking? NOW FOR SALE>> http://www.fordforums.com.au/showthread.php?t=11439680 |
#67 | |||
I NEVER even thought about it being a bad batch of fuel. But now I know what it was and if it ever happens again i will putting in some fresh fuel before paying $300 for a bloody tow truck!!!! ![]() |
#68 | |||
However I find the point about E 10 causing a reduction in power (to an engine that's tuned for regular 91) harder to agree with. I've spoken to a number of experts on this subject and from what I've been told, I believe 95 E10 is pretty close to the regular 91 unleaded fuel when it comes to real world anti knock ability. That's because it has a MOTOR OCTANE NUMBER that's about the same, or close to the 91 unleaded fuel (which should be around 81 MON) whereas Premium 95 is likely to have a MON of around 85 and Premium 98 should be around 86 MON. It's generally not understood that the Research Octane Number test is an easier test than the Motor Octane Number test, and from what I've been told the MON test numbers are the important ones to take notice of. Apparently in the US these two numbers are averaged which is why their advertised Octane numbers are lower. I think fuel companies should advertise the Motor Octane Numbers of their fuels. Last edited by 2242100; 24-06-2015 at 07:00 PM. |
#69 | ||||
I use mostly 95PULP and the occasional 98PULP/E10 in my XR6T.
91ULP is the stuff to avoid in performance cars unless your car is just the plain jane runabout. A tuning shop's take on E10: http://www.mrtperformance.com.au/res...-blended-fuels Quote:
Reading this article, there appears to be a commenter who claims to have worked for FPV and apparently it was not exactly E10 that ruined the FPV GT owned by the boys in blue: Quote:
FGX Falcon XR6 Turbo |
#70 | |||
Apparently adding ethanol is a good way to get the Research Octane Number up but it doesn't raise the important Motor Octane Number up as much. Actually I ran a couple of tanks of 91 through my stock untuned FG XR6 T recently and the car went quite well, only 1 single ping sound (on one occasion)as I kicked it down and it was just as responsive (ie. initial throttle response) as it was on 98, but when I measured rolling acceleration with my GPS based acceleration test gear under identical conditions, it was 10% slower than on 98. So I think it was probably losing about 30 kW. I'd expect the electronics to make sure that 95 E10 doesn't hurt your engine, but I suspect you might losing more power than you realise because the initial throttle response will probably be similar. Whether on 91, 95 E10, 95 Premium or 98 Premium. Initial throttle response has a lot of affect on our perception of how fast a car is, I think. Last edited by 2242100; 24-06-2015 at 08:40 PM. |
#71 | |||
Wirlankarra yanama
E10 (95 RON) being too high for my vehicle - that's a new one. So how would you explain PULP (98 RON) giving better milage that normal ULP (91 RON)? |
#72 | |||
To redesign a engine which was built for 91 and convert it to E10, the compression ratio would need to be raised. If you tuned the 91 engine to run E10, all that is really being done is optimising the combination that is present, it will not compensate for the loss of efficiency because it don't have the higher compression ratio. With any N/A engine, it is best to run the highest compression ratio with the lowest possible optimised octane fuel. Think of it like this, it's no good running 105 octane fuel in an 8:1 compression ratio engine, It looses power. Same with running E10 in an engine designed for 91 octane. For best performance out of E10 it would be better in an engine designed for 95 octane. |
#73 | |||
Could be a case of both 91 and E10 both being too low an octane fuel for your vehicle. Hard to say. It can be likened to comparing fuel economy of 98 in my GT to 91 in my GT. With the 91 fuel it's gutless and uses fuel. |
#74 | |||
But what I'm getting at is the point that there is apparently little difference in antiknock ability between 95 E10 and regular 91 unleaded. I understand that the important MOTOR OCTANE NUMBER (ie MON) of 95 E10 is apparently close to, or the same as regular 91 unleaded fuel and that's typically 81 on the MON test, whereas 95 Premium is around 85 MON and 98 Premium is around 86. It's not surprising to me that these two fuels tend to be more expensive. The MON test is the tougher test and from what I've been told by experts, the Motor Octane Number is the important one to take notice of. It seems a pity to me that Research Numbers are even quoted. As I said earlier, in the US they quote an average of the RON and MON figures which is why their octane numbers are lower. Last edited by 2242100; 25-06-2015 at 12:02 AM. |
#75 | |||
What I do know is the ethanol based fuels burn cooler, this changes so many variables in the engine, that higher than anticipated compression ratios are possible and gains in power and fuel economy can be achieved. I am not saying that they will equal petrol, but they can come close. |
#76 | ||
![]() Last edited by yearby; 25-06-2015 at 12:21 AM. Reason: repeated post |
#77 | |||
The one and only
Apparently E10 has cleaning agents, so it's good to use as a flush fuel. I used to run E10 1 in every 4 tank refills.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
#78 | ||
Dunnydore Destroyer
Hmm never seen it happen on a scale as big as this!!!!
http://www.dailytelegraph.com.au/new...-1227413865790
______________________________________ "SKIN ON SKIN, LET THE LOVE BEGIN" ![]() |
#79 | |||
I'm sure all those people stuck out on the M4 near Sydney are happy to be doing thier bit for the environment by using E10...
![]() I notice some very new vehicles there getting loaded onto tilt trays. Poor sods. And they want to mandate that all our unleaded be filled with stuff that attracts water...well done. E10 fuel attracts about 50 times more water than normal unleaded fuel, so if you don't have a completely sealed fuel system (like, for instance, old cars...) it WILL be attracting water to the system. Nice. There should be two classes of unleaded fuel...pure unleaded, and something like E85 which only specially designed vehicles can use. Forcing people with new and old cars which were never designed to use any ethanol blend is simply wrong. But I have no doubt misguided and lied-to politicians will go ahead an mandate it eventually. It's been quite a big talking point among the classic car brigade for many years now. An interesting tech article about owning an older car... http://www.mossmotors.com/SiteGraphi...s/ethanol.html An interesting point in that article for owners of occasional-use old cars... Quote:
#81 | ||
I always use premium in my GSX1400...but then it's only got a 21 liter tank. I'd be a bit annoyed filling up fifty liters or so at 10 to 20 cents extra a liter every time...over a year that would really add up. And these days when things are tight and people are looking to save every penny they can. not many people are going to spend that much extra on fuel to avoid a problem that shouldn't even exist in the first place.
#82 | ||
#83 | ||
Which is fine for the rest of us with other vehicles not made in Europe...my 2008 GSX1400 motorcycle says it can use up to 5% ethanol, but it's not really recommended, and even then for "limited use only". My mothers 1996 Mazda 121 says absolutely not to use it (so what does she do if the idiots mandate it?). Our '82 Celica can't use it, our '82 253 WB ute can't use it.
There is no suggestion...apart from "just use expensive premium fuel"...for what those of us environmental vandals who dare to want to, you know, use the fuel our vehicles were designed for...are to do if they mandate the rubbish and you no longer have a choice. Oh...and if you think they're not going to demand to mandate ethanol content in premium as well, you're very naive. Look at the example of LPG... LPG was dirt cheap, a quarter the price of petrol or less...until the government had a big program and encouraged so many people to use it, then (presumably with a Mr Burns "Excellent" while they were doing so...) they whacked on the taxes and made it virtually uneconomical to use any more. Last edited by 2011G6E; 25-06-2015 at 09:19 AM. |
#84 | ||
Former BTIKD
![]() Join Date: Mar 2005
MB Australia's take on Ethanol............
"Use of unleaded petrol containing ethanol in Mercedes-Benz passenger cars and 4WD’s The Federal government believes that the inclusion of ethanol in petrol, up to a maximum of 10%, will be a positive step toward the reduction of greenhouse gas emissions and the sustainability of present fossil fuels. As ethanol is already being supplied through some petrol outlets it is important that Mercedes-Benz owners are aware of our official company position in this matter. Daimler AG. recommends that your vehicle be operated on fuel containing no more than 10% ethanol. Use of fuel with an ethanol content higher than 10% may result in engine malfunction, starting and operating difficulties and materials degradation. These adverse effects could result in permanent damage to your vehicle. Purchasing your fuel from a reputable supplier may reduce the risk of exceeding this 10% limit or of receiving fuel with abnormal properties. It should also be noted that when using ethanol blended fuels an increase in fuel consumption can be expected due to the lower energy content of ethanol. We can assure owners that all Mercedes-Benz passenger cars and 4WD’s manufactured after January 1st 1986 to Australian specification are able to be operated on unleaded petrol containing ethanol, providing the maximum limit of 10% is not exceeded."
#85 | |||
Of course...what guarantee do people have that the fuel we're using actually is only ten percent ethanol...? I mean it's not like there haven't already been issues with dodgy servos (bit and small) fiddling with the amount of this crap in our fuel supply. Sew even the tiniest seed of distrust, and people will speak up, especially when it comes to something you have little control over, ie: the fuel your car absolutely needs to run. |
#86 | |||
Former BTIKD
#87 | ||
Funny coincidence, 6 or more cars broke down in Sydney from a batch of contaminated E10 bought at the M4 Caltex
#88 | ||
tuning for higher levels of ethanol needs to be changed, so could be some of the reason for manufacturers limitations on certain vehicles
#89 | ||
BIG MEMBER ;)
2010 FG XR6T, EGO, MANUAL, LUXURY PACK.
#90 | |||
