27-11-2015, 01:01 PM | #61 | |||
I doubt someone would be too happy if they wore the way ward tyre/rim, or if a pedestrian/child/motorist/pet etc was killed or the tyre rim ended up in someones living room because of this, or if your 150K GT ended up in a ditch upside down because someone decided to save $5 on a wheel bearing, it's a rediculous situation that should be addressed. There is a difference between getting a pack of stale chips or bad service at the chinese take away and someone putting peoples lifes at risk
The Daily Driver : '98 EL Falcon, 5 Speed , 3.45 lsd The Week End Bruiser : FPV BF GT 40th Anniversary, 6 Speed Manual, 6/4 Brembo and lots of Herrod goodies Project 1 : '75 XB GS 351 Ute, Toploader, 9" with 3.5's Project 2 : '74 XB GS Big Block Coupe, Toploader, 9" with 4.11's In Storage : '74 XB GS 351 Fairmont Sedan XB Falcon Owners Group Mike's Man Cave |
27-11-2015, 01:08 PM | #62 | ||||
27-11-2015, 01:12 PM | #63 | ||
I'm still trying to get my head around the claim these bearing failed suddenly at highway speed with no prior indication. ie they were perfect until this trip, then one failed and all others were about to fail. How did they pass a inspection recently and now are unservicable?
What was the failure mode of the bearings. You stated the others were about to fail. What from? and do you have some pics of them? And why didn't you detect this with your pre trip inspection? How did they just fail so dramatically with no warning ie loose/tight, heat, shimmy when driving? I just don't get it.
I love Holdens.... |
27-11-2015, 01:19 PM | #64 | |||
Some people seem to miss the fact that my other trailer which has done possibly over 100.000km's and has been serviced, and maintained by myself for 18 years is fine, and it runs large 4x4 wheels and gets used off road and carried heavy loads, no wheels seem to be falling off or bearings wearing out. My cars also run around on bearings serviced and adjusted by me, with no issues or ecessive wear, however all these vehicles use quality brand name bearings. Strange a trailer that has travelled around 1500km loaded lightly on highways and was purchased brand new less that two years ago has lost a wheel, and upon pulling the remaining three bearing sets (all non branded marked 'Made in China') are all showing excessive wear and and are pretty much about to completely collapse. This is where my finely tuned red flag comes on. Your red flag might be due for serving and needs a bit of a service and a tune.
27-11-2015, 01:28 PM | #65 | |||
That was probably the point when they were going out the door, the trailer was recenlty regoed and inspected and passed, and yes they did check excessive movement when they did the rego inspection, trailer had done around 800km since rego, 500km of which was completely empty, not counting the 150km before the wheel fell off. At the time the trailer was loaded with an XA rolling shell. Not that hard to tell when they are no good once you pull them out. But I am guessing it must be my fault, nothing to do with substandard materials used, every other of my vehicles seems to be fine but still my fault I know I should probably pull up and repack the bearings every 50km on the side of the road, I guess if they still failed I should do it every 25km, or may the it's becaused the quality Timkin grease I use is not compatible with Chinese bearings Imagine buying a new car and after 3000km the wheel falls off and Ford claims it's your fault as you did not repack the bearings every three months, it's a rediciolous situation that should never happen, these parts are dangerous and should not be able to be sold here, it's 2015, nearly 2016, bearings last hundreds of thousands of KM's, and should not be failing after 3000km no matter what.
The Daily Driver : '98 EL Falcon, 5 Speed , 3.45 lsd The Week End Bruiser : FPV BF GT 40th Anniversary, 6 Speed Manual, 6/4 Brembo and lots of Herrod goodies Project 1 : '75 XB GS 351 Ute, Toploader, 9" with 3.5's Project 2 : '74 XB GS Big Block Coupe, Toploader, 9" with 4.11's In Storage : '74 XB GS 351 Fairmont Sedan XB Falcon Owners Group Mike's Man Cave Last edited by XB GS 351 Coupe; 27-11-2015 at 01:36 PM. |
5 users like this post: |
27-11-2015, 01:33 PM | #66 | ||
Maybe Mario usually caters to the 'trailer as garden ornament' customers ?
There's a lot of them around here... |
2 users like this post: |
27-11-2015, 02:07 PM | #67 | |||
I just checked the NSW transport site and under towing guides they recommend a check of bearings, brakes before every trip. I used to tow horse floats and checked wheels and brakes just about every trip. I'd also check hub temps by feel whenever I stopped somewhere. I am not saying the bearings are good. I am not saying they are bad. I am saying that there can be other reasons for failure. I am saying as the owner you have your part to play in checking things prior to departure and also when travelling. I am sure they didn't just fail without some prior symptom. You say you service your own bearings, why didn't you pick this up?
27-11-2015, 02:22 PM | #68 | |||
27-11-2015, 02:34 PM | #69 | |||
And sure as hell when I serviced the hubs I'd clean the bearings and inspect. If this thread was a general warning about the dangers of generic bearings then I'd have no issue with it. But it's not. It's payback at a manufacturer for not honouring an warranty that had expired. And when you go down that road you better be squeeky clean and make sure you've done everything you're supposed to. I am surprised that a blatant slagging off thread has been allowed to continue on here actually. I have a real issue with this. In the end no proof can be supplied that the original manufacturer was at fault. The proof is that generic bearings were used. The owner is now responsible for the maintenance of the trailer and he should have noticed the generic bearings were an issue during the annual servicing.
4 users like this post: |
27-11-2015, 02:37 PM | #70 | ||
They would have to be extremely poor quality bearings for this to happen. Even with a moderate amount of under servicing, for all 4 bearings to be on their way out would lead me to think that there are a lot of trailers out there ready to turn their wheels into missiles. Did the axle hub retaining nut come off as well or did the bearing disintegrate to the point whereby the hub assembly bypassed the nut and flew off???
27-11-2015, 02:44 PM | #71 | |||
The true danger only occurs when you take a potentially dangerous piece of machinery and place it in the hands of the most unpredictable species on the planet. Human behaviour, as history has catalogued, cannot account for what any persons actions may be, especially concerning their love of the motor vehicle. http://www.fireservicecollege.ac.uk |
27-11-2015, 02:50 PM | #72 | |||
Did i log onto every message board and make defamoritory thread's about the issues when they happened ? NO A public forum isn't the place believe it or not , especially if it can bring liabilty charges against the forum in a defamation suit but then being as educated and well off as you appear and love to brag about you should already be well aware of this ?? For what it's worth i will never do business with those workshops again forum sponsors or not , but i also wont spruke their name out loud for fear of retribution. There is always 3 x sides to a story The truth the facts and the grey area in the middle. Best of luck , i am surprised this thread publicly slandering Mario's Trailers has remained this visible for so long ... |
27-11-2015, 02:59 PM | #73 | ||
Experienced Member
No use guessing, you must be 100% factual that the bearings were inferior, there is many reasons why bearings can fail prematurely, I'm not saying they were not inferior but you must prove it beyond doubt & seek professional advise.
27-11-2015, 03:03 PM | #74 | |||
BIG MEMBER ;)
2010 FG XR6T, EGO, MANUAL, LUXURY PACK.
27-11-2015, 03:05 PM | #75 | ||
Obsessed with wheels
3000ks wheel falls off because of bearing failure. They are the real facts here, just say he did a 3000k trip straight from when he bought it. I suppose it's still his fault? It sounds like he paid the right money and it wasn't a cheap trailer so you'd expect to get more then that for it. Not to mention he had to fix numerous other problems with said trailer. I don't care if he didn't check it at all with in that 3000k, it just shouldn't of happened period.
27-11-2015, 03:08 PM | #76 | ||
Well done. I suppose this has made the OPs wish come true.
You are now slagging off the manufacturer with a video totally unrelated.
27-11-2015, 03:10 PM | #77 | ||
BIG MEMBER ;)
Lighten up ya old prude, it was a joke..It's Friday....
27-11-2015, 03:13 PM | #78 | ||
http://www.productreview.com.au/p/ma...d-painted.html
Seems you're not the only one who's had trouble with their "customer relations team". Looking at Mario's web-site, they give options for upgrading to better wheels and / or new tyres (vs second hand which is their standard). Maybe they should highlight the possibility of upgrading to serviceable bearings. Could be a bad batch, and they've never had problems before, but it pays to look after the customer, esp. in teh age of instant communication. Now everybody play nice and stay safe over the weekend...check those bearings, I know I will be, now!!
Steve Current rides 2012 Mondeo Titanium wagon (TDCI) Moondust silver 2016 Focus Trend, 1.5ecoboost, 6sp manual. Frozen white Previous 2004 Berlina Wagon (LS1) Vespers Blue 1995 Camry 2.2, white 1971 Ford Fairmont wagon 302w, C4 Polar white 1971 TC Cortina, 2L 4sp, Ermine white |
27-11-2015, 03:17 PM | #79 | |||
It certainly is unrelated, and was illustrating the danger of wheel-loss from a vehicle. Small boat trailer wheels are the biggest offenders, due to abuse (going into the drink whilst still hot) and naturally running hotter due to the small rolling diameter.
27-11-2015, 03:19 PM | #80 | |||
It was 16 months old and they failed. After it's yearly service and inspection. The bad bearings would have been obvious then as it had done next to no KM after that. What did they guy who cleaned and serviced the bearings say? Did he say they were good. Or did he say they were cheap chinese rubbish and needed to be replaced. They could then have been taken back under warranty. The person who did the service and inspection obviously didn't do his job.Let's get him next.
27-11-2015, 03:28 PM | #81 | ||
Still Chris 3000k is f'all shouldn't of needed checking. But I can relate to what you're saying when they were serviced. I'm not sure if Micheal ment he serviced them himself or did he take it back to Mario's.
27-11-2015, 03:31 PM | #82 | |||
I just take exception to trying to extract revenge in this way on a forum. I don't think it's the done thing.
27-11-2015, 03:40 PM | #83 | ||
27-11-2015, 08:07 PM | #84 | |||
27-11-2015, 08:10 PM | #85 | |||
27-11-2015, 08:36 PM | #86 | |||
I am guessing the nay sayers would rather not have a heads up about issues people have had with suppliers of parts, engines and other vehicle related parts. The way I see it the forum is here to share information and assist each other, others obviously feel different and would rather others get caught out the same as they did. Well I am not like that, if I find something good I will let people know, if I find something bad I will also let people know, if I get great service I am the first to praise any business, but I am just has happy to share my bad service experiences. Those that are screaming defamation obviously have no idea what defamation actually is. Here to do people another favour I will post up a simple definition, I have assisted you further by underlining and bolding the important word: DEFAMATION LEGAL DEFINITION - Any intentional false communication, either written or spoken, that harms a person's reputation; decreases the respect, regard, or confidence in which a person is held. To avoid this I have not posted anything that is not 100% factual, true and correct, I have the photos of the damage caused, I have the worn out bearings, the receipts and all communication with Mario's trailers. I don't think I have to defend my actions after purchasing a brand spanking new car trailer, for the best part of $5K and a wheel falls off after around 3000km of light use, if anyone thinks it is not reasonable to expect the bearings to last a LOT longer than that then they have a problem IMO or you just have really low expectations. If I had bought a second hand trailer I would change all bearings as soon as I brought it home, it's just what I do, just like I fully service and check any vehicle I buy before taking it out and putting it into daily use. This is a brand new trailer, and is not acceptable by any standards. The End.
27-11-2015, 08:41 PM | #87 | ||
A lot of "Holier Than Thou" sentiments are being thrown around but I'm going to go against the grain and side with the OP. The trailer had traveled less than 4000kms and the wheel fell off...
I have owned a cheap Chinese 6x4 trailer for the last five years - clocked up tens of thousands of kms dragging it all over the country and unless I'm mistaken, none of the wheels have fallen off. I'm also something of a rebel... I don't check my bearings every single day either. |
27-11-2015, 08:43 PM | #88 | |||
2017 Mustang GT (Magnetic) |
27-11-2015, 08:44 PM | #89 | ||
Could be just as simple as a missing cotter pin after service. Don't laugh I've seen it several times.
27-11-2015, 08:56 PM | #90 | ||
Cracked Pot
Chinese, no name bearing are not to be trusted. Not because they are inferior but the lack of quality control. They are just as good as US or Japan bearings it's just that the odd crook one gets through manufacturing.
It a bit tough to blame the trailer builder given that no name bearings are used by many builders. If you knew about Chinese bearings you should have check when you took delivery. And comparing single axle to a bogie trailer is apples and oranges. The forces on the bearings on a bogie trailer are substantially greater than a single axle.
Ford Faithful
