Old 09-03-2007, 10:29 AM   #61
mcnews
Trev
mcnews's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Trev has owned several boosted fords and has really contributed a lot of info on them. His posts in the bike section are also very helpful. I think he should be recognised as a technical contributor.
Originally Posted by Piotr
The s200 has around 80% of peak torque availible from 2k right to redline. Its not as gutless down low as people think. Its only the awesome top end that leads people to beleive they are gutless down low (But above 2k they produce more torque than the focus does at peak).
Think that shoots the crap out of Steffos observations.
People have the same misconception about four cylinder motorcycles verses two cylinder motorcycles with the twin seemingly havimg heaps more mid-range torque when in fact they don't. It just seems so because their top end is so flat while the fours go berserko at the top end.
Trev
(FPV FG II GT-E thus the fully loaded burger with the lot as standard +Alpine/Dynamat fitout - 2 of only 4 ever made GT-E factory 9" rear rims - Michelin Pilot Supersports - Shockworks Suspension)
mcnews is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2007, 10:44 AM   #62
pb02
inconceivable!
pb02's Avatar
Exactly, they are completely different. You don't jump on a 4 after riding a twin and only rev it to 9000prm just because that's what you did with the twin.
I had a mate that used to say that if I only revved the S2000 to 6000rpm he would beat me in his V8. My reply was ok, but the second race we both have to rev to 9000rpm and see what happens.
The point is all engines are different, you can't make a blanket comparisson for different catagories. Everything needs to evaluated and used based on it's own merits and design.
pb02 is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2007, 11:50 AM   #63
XR Martin
XR Martin's Avatar
Personally I think the engine in the S2000 is pointless.
If you compare it to the Astra VXR engine, they have similar capacity and Kw. Yet the VXR makes its max power where the S2000 is making only 100kw. Also where the VXR is making its max torque, its nearly double what the S2000 is making at the same RPM.
So in conclusion youve got a car that weighs 150kg more, yet is just as fast, if not faster than the S2k. (in a straight line)
Forced induction > N/A
2004 BA wagon RTV project.
XR Martin is online now   Reply With Quote Multi-Quote with this Post
Old 09-03-2007, 11:58 AM   #64
pb02
inconceivable!
pb02's Avatar
Your missing the point in the design of the car. It's not built for straight line acceleration. Due to the overall design and engine size and position it has perfect 50/50 weight distribution. The Astra VXR has one of the worst chassis around and understeers like a dog!
Old 09-03-2007, 12:45 PM   #65
Steffo
LPG > You
Steffo's Avatar
Take a ride in an S2k (14 sec car) after being in a 14-sec XR8 or SS and tell me the difference in feel. At 3000 those things actually push you into your seat, and 3000 the S2000 is just buzzing and feels like nothing's going on. :
It may have 80% of its torque at 3000rpm... but that's only 175Nm.
The conversation isn't about the layout of the vehicle, its about the engine. And for all intents and purposes, the engine in the Astra is a better thought out, more useable piece of kit then Honda's effort.
As for beating Z3's, no surprises there. Modified Boxster's? Obviously you're a better driver then they were, because a stock Boxster S with two equal drivers makes a stock S2000 cry.
Oh and one more thing, 50/50 weight distribution does not automatically equal perfection. Many of the best performing cars in the world aren't setup like that.
Old 09-03-2007, 01:05 PM   #66
Des
V8 Rock'n'Roll....
Des's Avatar
Location: You got me Rootin' like a Hog, Barkin' like a Dog, Climbing trees and Jumping logs....
Yeah but you should compare apples with apples (or as close as possible).
8 cylinders vs 4 cylinders = 200%.
3000 rpm then equates to 6000 rpm.
5408cc & 6000cc vs 1998cc's
Most std (14 sec) factory V8's are slowing down by then (or stopped), where as the S2000 is still partying and willing for more.
1 owner 03 BA XR8 Manual Sedan
208.8 rwkw stock, update soon
20x8.5 fr 20x10 rr
Rumble thanks to:
Sureflo Exhaust - Stainless Cat's & 3.5in single catback system
"Tell 'em the guy with the Blue Mohawk sent Ya"
Des is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2007, 01:06 PM   #67
pb02
inconceivable!
pb02's Avatar
Again your comparing apples to oranges.....
If you want to make that comparison then you must obviously continue and look at when the power comes in. Between 6000rpm and 9000rpm the S2000 engine sings and is brilliant. How is the XR8 and SS engine doing at these sort of rpms???????
Old 09-03-2007, 01:23 PM   #68
Ives
Ives's Avatar
You cant compare turbocharged engine to an N/A engine.
Old 09-03-2007, 01:41 PM   #69
Steffo
LPG > You
Steffo's Avatar
They don't need those kind of revs to make power. : :
Old 09-03-2007, 01:46 PM   #70
Steffo
LPG > You
Steffo's Avatar
I said 14 sec XR8s and SSs... so that's 4942cc and 5665cc.
Most standard V8's have blown by the S2000 before its starting to party and will for more. It takes so long to get to that stage...
Hell, most good standard fast 6-cyl and 4-cyl engines have blown by the stupid thing before its in its power. 176kW @ 8300rpm and 208Nm @ 7500rpm and nothing below aren't impressive figures. Sure, the power is high, but its in a useless bit of rev band that 99% of the time you're not going to get close to.
Give me something like the 2.0 Turbo FSI in the upcoming Audi S3 please. 195kW @ 6000rpm and 350Nm @ 2500-5000rpm. Now that's an engine! Any gear, any revs, any time you want, stomp the right foot and you're off. None of this billion rpm, fifty thousand downshift garbage... feel like going fast? Stamp your foot down and you're going fast!
One really funny thing... the VE SV6 has the same amount of power as the upcoming S3 with LESS torque, from a 3.6litre V6 (over 40% more capacity and two extra cylinders)...
Old 09-03-2007, 02:33 PM   #71
mcnews
Trev
mcnews's Avatar
Well Steffo you must really, really hate rotaries then. I think you would prefer tractors to cars :->
Trev
Old 09-03-2007, 03:26 PM   #72
XR Martin
XR Martin's Avatar
No, Your missing the point.
Im comparing engines, not cars.
A turbo charged 2L 4cyl engine making 176kw will always be a much better engine than a N/A 2L making 176kw.
If you had a choice between the two engines in the S2000, the turbo engine would be chosen 99% of the time.
Old 09-03-2007, 03:42 PM   #73
BlackLS
I see the S2000 really usable around the track by being able to control the thing around longer corners, dive into the corner at 4000, plant the accel, and hold it there, you can still use the 6-9000rpm region coming out of the corner and you don't have to change gear.
Old 09-03-2007, 03:51 PM   #74
Homer1
Homer1's Avatar
Then I'd be in the 1% cause Id pick the S2000 engine anyday!
Tha turbo engine is good, but the problem is that its too good for the chassis its mated to (yeah I know you're comparing engines only, but an engine is pretty useless without a car attached to it as well)
Homer1 is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2007, 04:16 PM   #75
Ives
Ives's Avatar
--editted--
Ah never mind, S2000 is good. It's bloody expensive though. $72,990 + on-road costs.
Old 09-03-2007, 04:47 PM   #76
B-Series
Steffo hasn't even driven an S2000 :. Riding shotgun is one thing, actually driving it is another.
B-Series is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2007, 04:57 PM   #77
Piotr
Non-Regular Member
So basically Steffo is trying to say he likes having alot of torque.
Please stop comparing the S2000 engine with turbo engines, of course the turbo is gonna have more torque and more power thats the whole reason the turbo was invented. The advantage N/A engines hold is throttle response.
The S2000 is special because it has a nice small engine(Lightweight) that revs very high while still retaining a a relatively flat torque curve. It has more then enough torque down low for daily driving and if you wanna overtake just drop it down a gear or two it isn't hard.
Every man and his dog can build a 4L I6 that produced power but it takes something special to build a 2L that has the same sort of power and piston speeds that rival f1 cars.
2005 Renault Sport Megane 225
Old 09-03-2007, 05:13 PM   #78
mcnews
Trev
mcnews's Avatar
And because the S2000 is not a fat overweight taxi it doesn't need too much mumbo to get things moving. I would love one.
Trev
Old 09-03-2007, 05:45 PM   #79
Des
V8 Rock'n'Roll....
Des's Avatar
S2000 vs XR8/SS, depends if there's corners or not. In prduction racing the S2000 whipped the XR's (6T&8) & the SS's around Winton.
Gotta agree with the SV6 comment though, after driving one, gutless POS.
Still, a Jonathan Palmer Clubman would whip all of 'em, 4, 6 or 8. Straight line or corner.
20x8.5 fr 20x10 rr
Rumble thanks to:
Old 09-03-2007, 07:00 PM   #80
XR Martin
XR Martin's Avatar
Who cares if it takes 'something special' to build such an engine? It takes something special to build a 2dr VK like at the Summernats but that doesnt make it great.
Id much rather a Pontiac Solstice. RWD, roadster, 195kw 2L Turbo ecotec, USD$25k. While your harping on about your S2000s Hp/L, youd be getting beat like a redheaded step child in a straight line and on a road course.
Old 09-03-2007, 07:19 PM   #81
XRDRIFT
More Power, Bigger turbo
XRDRIFT's Avatar
Away from the topic just a little, but the Toyota 4AGE 1.6ltr 20valve motor had the highest power/kw per litre ever produced, having more horsepower per litre the engine had.
Had something like 187bhp from a 1.6litre, could be wrong but those engines rev and move in the right car.
I had a 1984 AE71 corolla and installed a 100kw 4AGE in it,dyno'd with 70 rwkws, and raced a S2000, didnt flog me by much....until his VTEC caught up, the cars are nuggets.
But cubic inches always helps too.....
Oh, and old school euro cars like the Peugot 108/9 gti had a 1.9 litre twin carbs and reved to 18,000rpm, redline at 14,000 or therebouts, fugly car but quick, standard.
Holden made the 6.0 litre coz their V8 couldnt match the Ford XR6 turbo.
Boosted all the way....... :eclipsee_ :thebirds:
XRDRIFT is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2007, 07:48 PM   #82
MITCHAY
You got to laugh when someone says "but you have to rev the crap out of it to do anything" Well no **** shirlock, it's doing what it was designed to do FFS!
It was designed to rev hard and make peak power at high revs, when you WANT to use all the power!
Old 09-03-2007, 08:05 PM   #83
Walkinshaw
Two > One
Walkinshaw's Avatar
I think we can all sort this arguement. We all just have to resign to the fact the S2000 motor is puss.
Old 09-03-2007, 10:55 PM   #84
M&Ms
M&Ms's Avatar
But isn't the whole point of a V-tec motor to improve fuel economy when doing low speed, low RPM city driving, but to give a boost in power once the revs rise and the driver wants to be a race driver? I'm sure that is what V-tec was designed for, whereas the VCT in the Fords (for example) was designed to give the motors greater torque in both halves of the rev range.
M&Ms is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2007, 11:11 PM   #85
MITCHAY
That is how I have always understood it to be.
Old 09-03-2007, 11:19 PM   #86
5tumpy
The only thing that the pontiac has over the S200 is 19kw mate...
Actually shows how little you know about the s2000.... It's rear wheel drive,
roaster, 176kw n/a, weighs only 1.2 tonnes, and once you factor in the cost of bringing the pontiac over (converting to RHD, import taxes etc.) the s2000 isn't that much more expensive...
5tumpy is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2007, 11:41 PM   #87
Steffo
LPG > You
Steffo's Avatar
Solstice GXP has 194kW @ 5300rpm to the S2000's 176kW @ 8300rpm. So it's got 18kW more power coming in 3000rpm earlier.
It's got 352Nm @ 2000rpm to the S2000's 208Nm @ 7500rpm. So it's got 144Nm more torque coming in 5500rpm earlier.
It redline's at 6300rpm - 1000rpm above its power peak. S2000 is 9000rpm, 700rpm above its power peak. So its got a bigger, more useable real spread of power... 2000 - 6000rpm or thereabouts, to the S2000's 7000 - 9000rpm.
Its 1340kg to the S2000's 1253kg, giving it 144.77kW/tonne and 262.68Nm/tonne to the S2000's 140.46kW/tonne and 166Nm/tonne. Advantage Solstice.
The only advantage the S2000 has is the six speed vs five speed manual gearbox. But with a power curve like it has and such, it needs every gear it can get.
And speak of the taxes and yadda yadda, the point is, the Honda still costs more, for an overall inferior product. Not to mention that the Solstice is physically larger, so bigger, taller people can actually drive/sit in the damn thing.
Old 09-03-2007, 11:43 PM   #88
Steffo
LPG > You
Steffo's Avatar
That's what they like to talk about yes.
What it helps with mostly is giving them the ability to make such a short stroke high revving engine have a liveable bottom end power curve, so they can actually be friendly day to day. Its an expensive way of solving a self imposed problem.
Old 09-03-2007, 11:53 PM   #89
B-Series
There we go steffo... comparing apples and you know what again. The S2000 is simply one of the best NA 2.0L engines around. So stop comparing it to a turbo powered vehicle or a ferrari V8.
Old 10-03-2007, 12:02 AM   #90
Steffo
LPG > You
Steffo's Avatar
The thing is, the S2000 and Solstice GXP are direct competitors. So I'm comparing apples to apples.
Just because the S2000 is, well, not better, and costs more, doesn't mean the Solstice is a whole different sort of car... :
