Old 30-07-2015, 05:20 PM   #1141
Kingsley
Default Re: Malaysian Airways Flight 370
If Malaysian Airlines kept up to date maintenance records and as stated, the tags and stamping are still in place, it will be fairly easy to identify through the aircraft's service history.
Nearly all parts on an aircraft are a serviceable items. During regular servicing or maintenance every part of the procedure including opening, removing, servicing, inspection, and replacement parts used are normally logged and signed for against the aircraft's service history along with tradesmen, trade supervisor, independent inspector doing that particular job on every single item.
If the panel or part for what ever reason is replaced, the new serial numbers on the panel are recorded in the service log. The same thing happens with other interchangeable replacement items such as various pumps, engines etc etc.
This is one of the reasons why various air authorities world wide seize the maintenance records of downed aircraft immediately they're made aware of an accident. It helps to see what was serviced and by who, identify the aircraft's particular componentry and to stop people from changing any logged information before an investigation.
Kingsley is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2015, 05:53 PM   #1142
Kingsley
Just been confirmed the panel is from MH370.
Old 30-07-2015, 06:06 PM   #1143
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Well there you go.. Where to now? After so long with this start a second phase of searches?
___________________________
Old 30-07-2015, 06:09 PM   #1144
Bobman
Regulator
Bobman's Avatar
Haven't seen any official confirmation yet, anywhere, but just words to the effect: "almost certainly".
Regards
Bobby
Current Cars:
2000 AU2 Fairmont (2019-current)
2003 BA1 Falcon Divvy Van (2017-current)
2009 VW Mk6 Golf 118TSi (2020-current)
Previous Cars:
2003 MCX10R Avalon VXi (2017-2020)
1995 EF1 Falcon GLi (2016-2019)
1997 XH2 Falcon Van OPT20 (2016-2019)
2006 BF Fairlane Ghia (2013-2018)
2001 AU3 Futura (2010-2013)
1996 EL Fairmont (2008-2010)
2004 BA XR6 (2005-2008)
2001 AU2 Forte (2005-2006)
1988 EA Fairmont Ghia (2003-2005)
1984 AR Telstar TX5 Ghia (2001-2005)
Bobman is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2015, 06:13 PM   #1145
FPV414
FPV414's Avatar
Yes that theory was covered on Airliners.net, Bobman.
FPV414 is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2015, 06:15 PM   #1146
nstg8a
3..2..1..
nstg8a's Avatar
How many b777's are sitting in aircraft graveyards around the world?
Wouldn't be hard to grab a flaperon (sounds like a relative of flappist) and dip it in the ocean somewhere for a few months then whammy... Convenient evidence.
Now where did I put my tinfoil?
Originally Posted by pottery beige View Post
Happy mcgadget meal orphan mcboofhead
nstg8a is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2015, 06:20 PM   #1147
MAD
Petro-sexual
MAD's Avatar
Yes, unfortunately this will not put to rest the tin foil brigade.
- The Story
Old 30-07-2015, 06:22 PM   #1148
Kingsley
My fault. I shouldve clarified that the word 'confirmed' was used on Tens evening news.
'Almost certain' would be correct.
Old 30-07-2015, 06:49 PM   #1149
Bobman
Regulator
Bobman's Avatar
Perhaps not likely to be related, but a report of a "battered suitcase" also found nearby: http://www.huffingtonpost.co.uk/2015...tml?1438245167
Must be a whole heap of flotsam on that particular beach though.
Regards
Bobby
Current Cars:
Previous Cars:
Old 31-07-2015, 05:36 AM   #1150
Moby Vic
Cynical Idealist
Moby Vic's Avatar
Not many. They've only been in service since 1995.
Your plastic pal who's fun to be with!
Moby Vic is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2015, 08:37 AM   #1151
cram_it_frog
wombat
cram_it_frog's Avatar
time is 8 am Friday and they are saying the part number and it look like 90% it is the right part
but it does not help in finding the aircraft
I wonder what is the bill for the search up to now ?
BA Ford Fairmont with spot lights ECB full type 8 bar UHF radio ,
Life is full of experiences some good some bad and with luck they all balance out in the end
What Ford s have I owned
1969 Blue wagon 1974 XB owned 3 of them
Numerious others but I always went back to ford
My first car was a 6 volt VW sedan
cram_it_frog is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2015, 09:32 AM   #1152
jpblue1000
jpblue1000's Avatar
Probably very similar to the bill for having the search staff/teams sitting idle back at base!
JP
jpblue1000 is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2015, 11:36 AM   #1153
haha, been waiting for this path or similar to be taken.
My thought was they will sieze this opportunity and claim the part is from Flight370, whether it is or not, allowing people to believe the plane did in fact crash to the sea and thats that.
All good until something else is found later on, exposing this "find" and investigation to be a fabrication
Old 31-07-2015, 01:47 PM   #1154
Bobman
Regulator
Bobman's Avatar
With all the personnel involved in multiple countries & the part going to France, you could not get everyone to agree to such "conspiracy", not to mention the serial numbers are unique to the actual aircraft, per part.
When some of the tin foilers were suggesting MH17 in Ukraine was this one the eyes rolled faster than the tyres of a worked F6. Airframe build dates are also stamped all over the plane parts.
Hope we see a proven result by tonight or Sunday, however it looks very much like this is a 777 flaperon by looking closely at the angles & rivets etc.
Regards
Bobby
Current Cars:
Previous Cars:
Old 31-07-2015, 10:46 PM   #1155
MITCHAY
Obviously it is possible it was planted but what advantage is that if no conclusive verdict can be reached. It would be near impossible to fake any identifiable marks.
Anyone of reasonable thinking knows it crashed but obviously relatives and friends still hold hopes of a different outcome. Hopefully this may be some peace for them.
Old 31-07-2015, 11:28 PM   #1156
nuthin' fancy
Lyminge, Shepway, Kent
nuthin' fancy's Avatar
There will be a great deal of checking to confirm that is from that flight before anyone commits. Can you imagine providing confirmation and then having to withdraw that statement later?
Mel Brooks sums it up best;
"Comedy is when you fall into an open sewer and die, tragedy is when I get a paper cut"
nuthin' fancy is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2015, 04:42 PM   #1157
b0son
I hope not, enough money has been wasted on this.
b0son is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2015, 06:09 PM   #1158
Yellow_Festiva
Where to next??
I heard yesterday that China isn't paying their share of the search bill.....
Old 01-08-2015, 07:50 PM   #1159
CoupeKing
As much as some want the search to end, it won't end until they find the plane, even if the search carries into the 22nd century.
CoupeKing is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2015, 06:59 PM   #1160
Yellow_Festiva
Where to next??
Apparently a plane door has been also found.
Old 02-08-2015, 08:51 PM   #1161
XD 351 Ute
Excessive Fuel Ingestion
XD 351 Ute's Avatar
I was going to say only one piece of jetsam to go with the heap of flotsam, but maybe there is two now.......
Ed
Recommended Forum Traders: RSGerry, trimmaster, 51OAU, EB-92, adxr8, my67xr, RG, ZA-289, kruptor, gassa, Felony, RNXR, Rhino 351, Anchor, Smoke Pursuit, Mr. FPV (through E-Bay),
XD 351 Ute is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2015, 10:50 AM   #1162
Charliewool
Bolt Nerd
Charliewool's Avatar
Plane door turned out to be fireman sam's aly ladder
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4
Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD
Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD
2 wheels.. 2015 103ci HD Wideglide.. SOLD
SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida!
(Ex Blood Orange #023 FPV Pursuit owner : )
Charliewool is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2015, 12:25 PM   #1163
cram_it_frog
wombat
on the radio this morning they said a number of locals are reporting fake items
this may be there one and only chance of fame and there are the ones who will do or say any thing for that chance of 2 seconds of fame
so with every find they will have to be very careful and look at what has been found and where
Old 03-08-2015, 12:41 PM   #1164
Harrison
Can't really blame them.
Anyone who believes that the US government doesn't know exactly where this plane is right now should turn off their TV for awhile.
Harrison is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2015, 01:17 PM   #1165
CoupeKing
It only took them 18 hours to find Bin Laden. That entire decade they devoted to locate and exterminate him were just for laughs. They knew where he was but they thought it would be funny to troll global security agencies.
Old 03-08-2015, 01:20 PM   #1166
Polyal
The 'Stihl' Man
Polyal's Avatar
Just curios how one IDs a standard part to a mass manufacturer product?
Do they use dat dots or some kind of ID process that links it to that exact plane?
  • 1973 ZF Ford Fairlane
Old 03-08-2015, 03:53 PM   #1167
xxx000
And your proof/evidence for this is?
xxx000 is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2015, 04:21 PM   #1168
Bobman
Regulator
Bobman's Avatar
It's amazing how many people put so much faith thinking they're gods into US (or other) governments on one hand, but then these same people attack them and saying they're hopeless on the other. Quite funny.
Regards
Bobby
Current Cars:
Previous Cars:
Old 03-08-2015, 04:42 PM   #1169
JAZSXY
Parts Fiend
JAZSXY's Avatar
Same as you cant tell me they didnt know where James "Whitey" Bulger was either for his 20+ years on the run. Especially when he was living in downtown LA.
Successful Sales With
frenzal56, falconxr, loosecannon, lima_been, bo5ton, Mardk, Chapter Four, leakey, POELWYK, Dman4.0, rayban76, tutor, PridenJoy, Aplito Futura, sbutler, Bosko, storta1, portokatsiki, AUte, 5.8, xxxg, FTW-302, LeadFoot81, Peuty, BillM, Sox, needfordspeed, watejs06, CATXR8
JAZSXY is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2015, 05:29 PM   #1170
Revolver
Big Member
Revolver's Avatar
Yep, at the bottom of the ocean most likely.
So I throw on the conspiracy hat, and as said way earlier in this thread, some countries military knows where this plane went down, but kept mum top ensure no-one knows what part of the world they can track.
The Scarlet Fairlane: 94 5.Slow Litre NC II Fairlane 488800kms & Climbing
Rollin' on genuine ELGT wheels.
K&N Filter
/////Alpine Sound.
EBGT Momo Woodgrain Steering Wheel
The Scarlet Fairlane Build Thread
Project "White Knight"
93 ED XR6
ROH Alloys
Momo wheel
Cruise
Sunroof
Premo Sound
Manual
HO Goodies
PWK Build Thread
1990 Yamaha FZR 250: 59000ks & climbing. New fairing, old tank, my angry mosquito in a coffee tin! 14.977 1/4mile.
Revolver is offline   Reply With Quote Multi-Quote with this Post
