03-04-2008, 11:37 AM | #121 | |||
03-04-2008, 12:09 PM | #122 | ||
Big Fella
I serioulsy think you blokes have missed 1 big point.
How much better does this make the end product for "us" users. It fantastic that we have the luxury of two different car makers going at it to continually push the boundaries. WE, the car market get all the benefits. |
03-04-2008, 12:20 PM | #123 | |||
XB Parts Wanted Twin Horns 8-9/74 and lower horn dated 7-8/74, GT hubcaps. GT aircleaner. Please pm me if you can help |
03-04-2008, 01:22 PM | #124 | |||
LPG > You
I hate GM and their poor engineering. Its typical American. Can't do it? Make it bigger! Doesn't work? Throw more money at it! The Callaway LS1... well... I don't know why HSV used it. The 302kW/542Nm 5.7 LS6 from the C5 Z06 was cheaper and more readily available and better.
LPG Lovers Association President & Member #1. : |
03-04-2008, 03:17 PM | #125 | |||
XP Coupe
03-04-2008, 03:48 PM | #126 | |||
let it burn
03-04-2008, 04:16 PM | #127 | ||
XP Coupe
I would suggest that canted valves that were so obvious on the Chev motors would be a fairly obvious take from GM. I'm not in a position to say whether Knudson developed the heads for GM or if he refined the method, but either way the statement that GM has/had inferior engineering doesn't hold, if Ford are using the same engineers and ideas....does it?
03-04-2008, 05:30 PM | #128 | |||
LPG > You
03-04-2008, 05:32 PM | #129 | |||
03-04-2008, 06:09 PM | #130 | |||
XP Coupe
What "underengineering" are we talking about and how do you quantify/qualify that? Seems to me the Windsor was around for a very long time, which must mean it has some redeeming features. The "Aussie" six harks back fifty years from American design roots. Chev, Pontiac and Ford have all produced engines over a long period that have legacy trails, easy maintenance, easy repair, and longivity. It is the ease of modification that has contributed heavily to the DIY market and thus brand loyalty. |
03-04-2008, 07:12 PM | #131 | |||
Even my Forester would make a GT look like a waste. Might be faster but by how much... not enough thats how much. : |
03-04-2008, 07:44 PM | #132 | ||
why dosent ford just get back into the old windsor technology and bring out a single cam engine just like the all the LS series but of course alot better than the old windsor technology.
I dont beileve in quad cam crap, only single or twin cam and thats it becuz it just gets to costly for a cam upgrade and the engine just gets to complicated. |
03-04-2008, 07:46 PM | #133 | ||
VFII SS UTE
another repost
http://www.fordforums.com.au/showthread.php?t=11214343
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
03-04-2008, 08:47 PM | #134 | |||
1999 Ford Fairmont Ghia
I seem to recall the 304ci in the VL having 125kw and advertsed as an engine for towing while the top of the line halo Holden was the VL SS Group A with 180kw. Considering the XF had 120kw and was comparatively good on fuel it is no wonder the XF was the best selling Falcon ever. |
03-04-2008, 10:25 PM | #135 | |||
335 S/C GT: The new KING of Australian made performance cars.. |
03-04-2008, 11:02 PM | #136 | |||
Long live the GT !
The AMG 6.2L DOHC V8 makes 378kW@6800rpm, the 6.2L pushrod LS3 makes 317kW@6000, do you think if HSV tuned the LS3 to peak at 6800rpm, it would be making 507hp or even more?....I highly doubt it when the 7.0L LS7 only makes 505hp at 6300rpm....and believe it or not the AMG 6.2 mill has a better torque curve than the LS7!
2018 Ford Mustang GT - Oxford White | Auto | Herrod Tune | K&N Filter | StreetFighter Oil Separators | H&R Springs | Whiteline Vertical Links | Ceramic Protection | Tint "Whatya think of me car, XR Falcon, 351 Blown Cleveland running Motec injection and runnin' on methanol... goes pretty hard too, got heaps of torque for chucking burnouts, IT'S UNREAL !!" - Poida
04-04-2008, 12:40 AM | #137 | |||
04-04-2008, 01:00 AM | #138 | ||
7,753
Interesting we can get this topic up to over 2500 views, while over at LS1 dot com it doesn't seem to rate highly at all. One thread I found was locked.
All very relaxed about it in a community that should actually care.
BREAKING NEWS: The Pity Train has just derailed at the intersection of "Suck It Up & Move On" after it crashed into "We All Have Problems" before coming to a complete stop at "Get the Hell Over It." Reporting LIVE from Quitchur Bitchin' |
04-04-2008, 01:09 AM | #139 | ||
To them its probably same S***, different bucket.
Especially when the LS1 first came out they were modding and getting great results. Then when the 6 litre came out and everything carried over and worked just as well, even better with the slight extra cubes. 0.2 of a litre in pretty much the same motor is not a big deal, unless your in the market for a new V8.
A philosopher is a person who finds a problem for every solution . :Reverend: 95 EF XR8, Advance headers, Vortech V2 t trim blower, Ported Cobra Manifold, Capa Switch Chip Eliminator. 307 rwhp 395 ft/lb 13.2 @ 105mph Now NA- AFR 165 heads, 1.6RR, Ported Cobra 269rwhp 14.2 ... needs stall and 4.11's 1977 CL Chrysler Panel Van, 360, 727 torqueflite auto soon to be restored. |
04-04-2008, 01:20 AM | #140 | |||
Now Fordless
Strange group of characters over there. |
04-04-2008, 04:04 AM | #141 | |||
LPG > You
04-04-2008, 07:36 AM | #142 | |||
They way your talking you make it sound like there are four cames above each cylinder LOL! |
04-04-2008, 12:08 PM | #143 | ||
Looks like gm are working on direct injection & variable cam timing for the gen v range of motors. The torque curve goes just about straight up & stayed there across the rev range, although the peak didnt change much. Improved ecconomy as well. The next few years will be interesting.
04-04-2008, 02:29 PM | #144 | |||
Its not all about tech tech tech! Pushrod is cost effective! The LS3 in correct tune should be good for 330kw with still alot of room to move. Not this detuned 317kw crap. 330kw 6.2L LS3 for $6-7k out the crate compared to 378kw AMG engine for what? 20k+? The LS7 is cheaper than the AMG engine and again with an alright tune as seen in the CSV's its good for 400kw at the fly, if not more. |
04-04-2008, 03:08 PM | #145 | ||
XP Coupe
Isn't AMG what HSV and FPV are to Holden and Ford respectively, except AMG garner bits 'n bobs from Merc's racing engines?
I'd have thought with all that race breeding and o/head cams and twin valves the AMG would be putting out much more than 503 hp at 6,800 rpm and 456 lb-ft of torque at 5,200, compared to most powerful NA production engine being an antiquated 7.0 GM pushrod delivering 505 hp and 470 lb-ft. To my mind if GM, or Ford for that matter did decide to enter the market segments that Merc play in, they could probably justify making engines that trounce the competition in cubic capacity per pony. There is hardly anything black magic in engines. That they prefer to cater to the mass market is a strategy they are obviously comfortable with. Ford could simply call on Cosworth for the design. Focusing on displacement as the be all and end all of engine performance is tunnel vision, generally used for arguments that are being lost. |
04-04-2008, 03:23 PM | #146 | |||
Trev
I am sure if Chev was selling LS3s for as much money as a whole Commodore fitted with an LS3 then they would hand build them fitted with top end components and probably be making more than 600hp. As it is as the moment they are a relatively cheap engine that have proved pretty robust and damn good bang for the buck.
Trev (FPV FG II GT-E thus the fully loaded burger with the lot as standard +Alpine/Dynamat fitout - 2 of only 4 ever made GT-E factory 9" rear rims - Michelin Pilot Supersports - Shockworks Suspension) |
04-04-2008, 03:41 PM | #147 | |||
No wheelspin - Either he was launching it perfect and they were slow - or he wasn't launching hard enough |
04-04-2008, 03:49 PM | #148 | |||
haha thats the one i was talking about |
04-04-2008, 04:37 PM | #149 | |||
GT
CHECKOUT THE STATEMENT ABOVE . ^^^^^ WOOOOOOH MALOO UTE STOCK DOES A SCARY 13.9 AT THE DRAGS , THATS XR8 /GT CATAGORY. SO what's all this crap about the LS3 . OOOOOOOOOHH , VERY SCARY PERFORMANCE INDEED . |
04-04-2008, 05:10 PM | #150 | |||
T3/Sprint8
