Old 02-06-2016, 09:45 PM   #121
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
Default Re: AU Scantool Experiments (codes/live data!)
Originally Posted by auIILTD View Post
I highly recommend to stay away from the Bluetooth ELM327s, as I have heard may have dramas with them. Jump on the forscan forums @ forscan.org. Do some research there, and I reckon you will be in good stead.
Stu
I suggest you try a laptop or PC. Dauphin reported the same issue and he got around it by loading the correct driver. the issue may be with you Android version?
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2018, 01:53 AM   #122
JackoTJK
Hey all.
I know this is an old dead thread but it had info I was looking for so thought I'd add what I'm working on...
An ADX file to use an ELM327 to setup Data Tracing in TunerProRT!!!
I'm making it up now with the PIDS for Mode22 and making up the conversion tables etc.
I'll be trying it out tomorrow on the AU2 and AU3 VCT XR6.
The only thing that may be a headache is figuring out where I need ATSP1 (was thinking connection command) and ATSHE410F1 may have the be a seperate header before each TX command. Otherwise it may just need to be the 1 header at the beginning of the Monitor macro. I'll cross that bridge when I get to it.
Also does anyone know how far off the PIDS are for an EECIV? I may just have to make another ADX later but that's neither here nor there.
I'll let you guys know!
Data Tracing with a bubble on free tuning software with a $20 adapter burning a $90 chip sounds good to me!
Last edited by auIILTD; 01-02-2018 at 09:36 AM. Reason: Deletion of text. This is a family friendly forum
JackoTJK is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2018, 01:01 AM   #123
NCII40
XR6T BA 2002
NCII40's Avatar
hey all
This is the ELM327 needed for FORD AU
https://www.ebay.com.au/itm/Diagnost...72.m2749.l2649
Modified for FORD Version ELM 327
XR6T 2002 BA
NCII40 is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2018, 09:48 AM   #124
vl_vic
Hi,
Who can help determine the equation for 1158 - short term fuel trim percent (ford focus 2)?
Here is the response: 7E8 05 62 11 58 87 AE 00 00 (should be 5.4 %) A=87 B=AE
1158 - short term fuel trim percent - 2 bytes - subtract 32768 then divide by -327.68 -not work(
vl_vic is offline   Reply With Quote Multi-Quote with this Post
