Old 07-02-2006, 06:19 PM   #181
riro
just had completely faded lcd display in my Au 1 same as 2 & 3 fixed by a real gentleman who knows how NOT to charge excessively $50 versus up to $300 for changeover try this link www.geocities.com/liquidxtal
riro is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2006, 08:21 PM   #182
StAndArdAU
Back in a Blue Oval
StAndArdAU's Avatar
Originally Posted by FPV8U
OK guys noticed today that Mums AUII XR8's speedo was jumping when being accelerated, is this a common problem and what is the fix?
Thanks alot guys
I had that problem too but found out it was the background bubbling (cheap replacement white gauges) and the needles were hitting. now it does it very subtly if i put the pedal down fast.
'13 Territory TX Diesel RWD. The Family Bus
'08 Mitsubishi Pajero. The Off-road Machine
StAndArdAU is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2006, 06:29 PM   #183
747FLI
Unhappy Not a common problem - it's bent to @%#$!!!
I last advised about a squeak with my rear right rotor etc. Well, it is not a common problem in this case cause the whole axle/hub set up is bent to the @%#$house! My guess is that the previous owner has had someone smack into the side of him and the problem is just starting to come through now. Anyway, Widowmaker in Caloundra are now going to replace the whole axle/hub for the right rear which shall keep me going until the AU is traded in on a new post BF model XR8 :eclipsee_ ...hope they build a good one!
Dave
Old 16-02-2006, 11:07 PM   #184
russky
Road Terrorist
Unhappy
Originally Posted by 012
Common problem. Climate control display unit with missing segments on the numbers being displayed. All AU Fairmont's, Fairmont Ghia's, Fairlane's, LTD's, TE50's (series I and II), TS50's and TL50's are effected. Don't know exactly what causes this, but have heard it's due to heat breaking down the contact points on the PCB at the back of the unit. Sorry folks, I only know of the problem, and have no solution, or idea on how/cost to fix it.
I bought a rebuilt unit (with lifetime warranty) for my TS50 and it's in 100% working order. Noticed some melted plastic type material on the back where the "strip"(?) of wire that comes off the LCD screen, meets the PCB on the back.
I second that problem. And riding in heaps of taxis, they all have the same problem. It costs heaps to fix it. I think its around 400 dollar mark, maybe a bit more.
russky is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2006, 01:12 AM   #185
OZFORDAU
OZFORDAU's Avatar
Talking Gas stating problems!
Hey,
I have a 99' Fote on dual fuel! I have trouble starting on gas! I've got advice from dealers n garages! Thought maybe someone knows how to solve it! All the mixers and stuff like that are fine! They said to me it's the gas converter that need's replacing soon?
Simon :
OZFORDAU is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2006, 01:31 AM   #186
Sleeperau
Highway Taxi
Default Gas
Originally Posted by OZFORDAU
Hey,
Simon :
You need to chat to AU II Se Ute , Pm him. He is knowlegeable & has a gas set up as well. :
Close only counts in Horse Shoes & Hand Grenades. :evil_laug
Sleeperau is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2006, 01:55 AM   #187
OZFORDAU
OZFORDAU's Avatar
Talking Thank's
Ok thank's! Will do!
Simon :1syellow1
Old 09-03-2006, 06:18 AM   #188
Mechan1k
Mechan1k's Avatar
Maybe your jet in the converter needs to be cleaned ... maybe a diaphram issue in the converter as well ... as they get older they are not as tight.
Old 12-03-2006, 04:51 PM   #189
nob92@
nob92@'s Avatar
Default how do u install blue leds>?
Originally Posted by JC
Dash lights dull - fitted blue LEDs.
AU1 brakes ineffective - fitted DBA slotted rotors.
AU2 I6 hesitated badly at WOT - replace leads #3 & #6.
how did u install the blue leds?
nob92@ is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2006, 09:14 PM   #190
Dark Horse
_Oo===oO_
Dark Horse's Avatar
Refer aufalcon.com workshop section.
Dark Horse is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2006, 05:03 PM   #191
StAndArdAU
Back in a Blue Oval
StAndArdAU's Avatar
i've got moisture build up in my front head light... how can i get rid of it?
Old 23-03-2006, 10:28 PM   #192
eminvil_12
if you want cheap leds go to 123leds.com or sickmods.net hes a great guy, and leds come with free resistors, contact him and he should be able to get you the right value.
dont go to dick smiths
sorry its a little off topic but most people like saving money, even if it is a little bit.
Should be able to get the leds shipped with resistors for under $5 opposed to DS's $3 for one led.
eminvil_12 is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2006, 12:20 AM   #193
chief
FTF Club Moderator
chief's Avatar
PM "The Dok". He runs a business called the Headlight Hospital and can refurbish them and reseal them.
Also I thought this thread was for problem and solution not a general Q & A.
Albert Einstein:
Fords in the Park 2010
Old 26-03-2006, 01:05 AM   #194
Fez WQ
Boot Hinges on the sedan broken fixed under warranty, and some bloke ran into me , under warranty would have loved to fix him up!!!!!. AU may be differnt in looks but excells in value and lasting well. Taxis drive them that says it all . I was in a AU2 the other day had done 750000KM+ and sounded in A1 condition. All AUs suffer form rust was you car often with a cap ful (50ml) of Kero in the water the car will last a heap longer. My paint protection place recomended it
Fez WQ is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2006, 01:27 AM   #195
12
Silhouette AU1 TS50.
12's Avatar
Have been catching a few taxi's in the last 2 months or so for work reasons. Been in Avalons', AU's, Camry's and BA's. Chatting to the drivers, I asked for their opinion on the late model taxis. The AU was highly regarded as the best. One driver in a Avalon absolutely loved the AU he had. He had AU-AU2-BA and now Camry. Hated the BA, and not impressed with the Camry. Every taxi driver I spoke to said the AU had been THE best taxi they've driven/owned. One BA driver said to me that his boss is so not impressed/mad with the BA, he wants to sell the lot of 'em and buy back the AU2 fleet he had prior. Never in my conversations did I mention to them I was a Ford man and a AU owner. Just smirked and nodded my head when they talked about the AU.
"People can have the Model T in any colour.. so long as it's black." HENRY FORD (30/07/1863 - 07/04/1947)
PIC'S OF MY
T1 TS50.
Old 26-03-2006, 01:31 AM   #196
xd5.8l
xd5.8l's Avatar
They said the same thing about the EF- EL and the EB-ED before that. I think we're just gradually getting worse.
xd5.8l is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2006, 01:56 AM   #197
BPXR6T
I agree with those taxi drivers in a reliability sense. I owned an AU1 XR8 before my current BA XR8. The AU was totally hassle free. I can't say the same for the BA. I've been pretty lucky compared to some but my 15K old BA has just had the diff replaced! One of many common BA problems.
In my experience an AU, apart from the weak auto its as solid as a rock!
Old 26-03-2006, 02:27 PM   #198
old fordnut
too many fords
old fordnut's Avatar
I've owned a series 1 XR6 and a series 2 XR8 ute and both cars have had the side view mirrors crap themselves. I've had to replace them at about $200 each.
old fordnut is offline   Reply With Quote Multi-Quote with this Post
Old 17-04-2006, 11:06 PM   #199
StevenAu2
Irregular Member
Another problem ive had to fix twice at about 12 monthly intervals is replacing the gasket(more like an o-ring) of the thermostat housing.
P!$$ easy job though!!!
StevenAu2 is offline   Reply With Quote Multi-Quote with this Post
Old 17-04-2006, 11:24 PM   #200
paddle
paddle's Avatar
Default Problems
The only problems ive had with my 1998 AU Forte is the Water Pump which i noticed the noise about a day after a brought the car. I got it second hand with 203 thou on the clock.
When i got the Towbar put on i got him to check over it. He picked out that the Rotars were undersized and majorly out of shape.
I got the car yard to fix all of this.
paddle is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2006, 01:26 PM   #201
toadin
Originally Posted by sbutler
I had a ripper one day! the left window wouldn't work it was stuck down, so I rang FTe service and the guy said, "get this" press the window switch up & down 31 yes 31 times, that will fix it!!! yeah right :tosser1: anyway I did this, and bugger me on the 31st time the bloody thing worked!! : Beats the hell outta me. I dont know if anyone else has had this..
I had the same prob. Thanks to u it is now fixed. Incredible, 31 is the lucky number!! I was told it was the regulator. $331 for a new one. If 31 doesn't work go a little longer.
toadin is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2006, 03:05 PM   #202
GASXR6
GASXR6's Avatar
Default electronic noise
Ok anyone heard of this one? I have a au11 xr8 ute 5 speed manual standard. When I accelerate in first gear and than depress the clutch I hear a beep, then the same into third, sometimes when slowing down and braking. It does it often and every time I drive the car. Just a short beep.
GASXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2006, 12:21 PM   #203
ixr872
Default interior lights
I have a 2000 auii xr8. GReat car , i have a problem with the interior lights staying on after car is locked and also staying on when driving. ant ideas????
ixr872 is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2006, 01:36 PM   #204
Donshe
is it possible that the little switch on your right near the headlights is flicked on?
dont laugh, ive seen it happen and this WAS the "problem"
Donshe is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2006, 12:44 AM   #205
GASXR6
GASXR6's Avatar
In addition to the beep, my airbag warning light has just come on. Wondering if the 2 are somehow related to each other? The beep doesn't coincide with the light. When I first start the car the light flashes and then after a while stays on. Any help appreciated.
Old 26-04-2006, 01:19 AM   #206
Firefox7
T3 Terrorist
Firefox7's Avatar
AU TE-50 T3....
The only probs with mine, rear passenger wheel bearing desintigrated, rear shock mounts replaced due to factory fault. In all honesty, best car I have ever owned by fu*ing a long shot, and is actually cheaper to run than my previous Ford V8's..EL & EF, fuel, reliabilty & performance wise.
Cheers.
Proud Owner of a Tickford TE-50 T3 No 033...13.16@107.12 mph 1.868 60"
Fastest Lap time At wakefield park on Dunlop Sp9000's : 1:14:30, Came 2nd in outright driver, in the overall V8 result, 2006 N.S.W dutton rally :1syellow1
:king: T3 :king: The Mightiest & Deadliest Tickford Ever To Hit The Road........
Firefox7 is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2006, 05:49 PM   #207
Stav
Smile
Stav's Avatar
The auto is leaking like a siv.The engine is leaking like a siv.There is no filler tube to top the auto oil up. I may stop anywhere if I leave home. So tommorow I am taking a day off and hopefully getting the car repaired.
Old 07-05-2006, 07:14 PM   #208
Dark Horse
_Oo===oO_
Dark Horse's Avatar
Yes a common problem regarding the BTR boxes in the AU are the seals, and also the from the speedo transducer.
Old 07-05-2006, 08:02 PM   #209
Stav
Smile
Stav's Avatar
Good man. This may be the likely culprit ...the speedo cog /transducer.The rear seal went and got replaced a year ago. Thanks.!! :sm_headba
Old 15-05-2006, 05:57 PM   #210
Stav
Smile
Stav's Avatar
Well the new second hand box went in last week.Apparently if the rear auto seal goes the tailshaft may thrash around causing bad wearing inside the main gearbox housing.
Today while driving around my brakes totally dissapeared.Yes no brakes.It seems the brake booster died and was hissing inside the car.I was lucky not to smash.The dam brake boosters are made of plastic!!! If your car is on 180,000 kms ,do yourself a favour and get another booster.If there was a lady or youngster on the car they could have been killed.
