13-09-2010, 02:18 PM | #1 | ||
Hi,
My AU XR8 is getting some upgrades, can anyone giv me an estimate of the 1/4 mile times i should be getting with my setup? Mods are: Rebuilt engine to handle boost. Not to sure what the specs are. Its basically forged rings etc, still a 302. New trickflow heads and manifold, comp cam. N/A form made 260rwhp. Rebuilt auto with 3000 hi stall Diff rebuilt with 3.9 ratio Centrifugal supercharger, not yet put on. Tuner expects to make around 400-450rwhp. Full exhaust system: twin 2.5, pacemaker 4-1s Cheers |
13-09-2010, 02:30 PM | #2 | ||
Pro Street Au Ute
not sure on your quarter times but with 400 plus rwhp your block will be more than likely on a borrowed time.
13-09-2010, 02:50 PM | #3 | ||
Just slidin'
Aspirated youd have to think mid to low 13's.
With the supercharger, probably the same as you wouldnt be able to launch it, youd have to baby it off the line, and back right off on gearchanges. Butyoud see more mph with the s/c. With semi's, a good tailshaft and a really good suspension set up, and a really tough gearbox and axles, it would have to dip into the 12's.
MD Mondeo - For the family
13-09-2010, 03:23 PM | #4 | ||
Rule of thumb for factory 302 windsor roller blocks is a 450 flywheel HP limit. Anything beyond that is taking a major risk for engine destruction.
13-09-2010, 03:48 PM | #5 | ||
Flairs - Truckers Delight
i have always thought about taking my tired old falc out onto the track for a 400m pass
but i'd probably get a 'sunscreen time': 30+
13-09-2010, 03:55 PM | #6 | |||
AU DIE HARD
NA with mods are getting mid 13s so boosted you would hope for low to mid 12s not stroking it was probably a good idea
13-09-2010, 05:17 PM | #7 | ||
Stroking it...
What tyres????
You could run a 14 on street tyres or an 12 on semis.... Also what does the "rebuild gearbox" entail? 300rwkw is a lot to push through a standard auto... And then there's the worries of the block.. I would be trying to limit my rwhp to no more then 400, sounds like your pouring some serious money into this thing, I would hate to see it go bang.... Did you consider an aftermarket block? (although you haven't really said whether its a standard block)
Had: 347ci AU Then: Now: Busted assed EB Wagon - 5sp and Dual Fuel. |
13-09-2010, 08:43 PM | #8 | ||
Now Fordless
So it has 260 rwhp now after the NA mods? Thats exactly what mine has and its stock apart from tune. Probably due to the lower compression for boost.
I done a 14.3. It should get a high 13 with a stall and practice. With the blower I would be looking at a 12 second pass. Im fitting one soon so it will be interesting to see what you get. |
13-09-2010, 11:09 PM | #9 | ||
Sorry i should have mentioned more about the engine.... I am using an aftermarket sportsman block.... The reason for 260rwhp N/A is lower compression and running on 95 octane.
Also, gearbox is a full "performance" rebuild with the best quality parts i have been told. |
14-09-2010, 12:17 AM | #10 | ||
mate with the dart sportsman block not a worry , im betting with proper setup, lose some weight , as per spare tyre out, remove back bottom portion of rear seat , etc etc , and a custom tune with the s/c setup easy low 12 , high 11 with some sticky rears.
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak! AU SERIES 3 LIQUID SILVER BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS 123.4 GROUND TEARING RWKW'S , LOL |
14-09-2010, 07:25 AM | #11 | ||
Stroking it...
Great to see your not using the stock block, really will pay off in the long run.. Kudos to you!
Agreed with sleeper393, wack some decent rubber on it and it should see the thing dip into the 11's with some practice...
14-09-2010, 12:01 PM | #12 | ||
Pro Street Au Ute
redauxr8 great way to start with a aftermarket block they are a good investment something you won't have to worry about as the power levels go up.
I think the main problem you'll have is getting the power to the ground and weight, does your xr8 have irs if so thats a fair bit of weight and they don't seem to put the power to the ground very well for straight line racing, if its not then with sticky rubber and well set up suspension should see some good times. Btw what type of supercharger did you end up going for? |
14-09-2010, 12:18 PM | #13 | |||
Im going to see how fast I can get on street tyres and weight, as this is my daily driven car! But ill probably take some weight off and run slicks eventually. I haven't actually decided on a blower yet. I'm either going to put a vortech or try the raptor out. Im only aiming for 400-450rwhp (at this stage). I am very tempted to put a Kenne Belle on.... I'll have to start a build thread when i get back from work. |
14-09-2010, 01:11 PM | #14 | ||
http://img442.imageshack.us/img442/6315/kennebell.mp4
KENNE BELL SETUP , GOTTA LOVE IT i'd go the bell setup if you have the $$$$ , positive displacement whipple on the street will blitz. JMO
14-09-2010, 02:20 PM | #15 | ||
Looking forward to this car!
Current Blueprint 03 xr8 5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives 256rwkw BA manual Typhoon Fully optioned, 340rwkw@16psi (thanks Bluepower)! The old ride.... AU Fairmont, cammed beast, R.I.P you made my p plate years bearable! 150.8rwkw courtesy BPR |
18-09-2010, 04:30 PM | #16 | ||
Smile
With 450 rwhp you will run 11 seconds to 12 seconds 1/4 mile
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
22-09-2010, 07:08 PM | #17 | ||
Teh Baest
Definately 12.45
1999 Liquid Silver AU Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!) Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler Coming..CMS Stg2A Cam, 68mm TB Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220 Currently: 151kW (165 on other dynos ) |
