Hey guys,
Have recently bought a new steering rack, fitted it and gotten the alignment to a point i'm happy with. The other day however, I did a tight U-turn, and after doing so, the steering was shocking! To turn left was fine, but it took around 1/4 turn of a clockwise rotation to have any response when turning right. I've done a bit of inspecting and in that loose part of the rotation (turning right) it seems only my left wheel is responding and my right wheel is staying straight.... Any suggestions?
Regards, Tim ------------------------------ 1978 Ford Escort Panelvan |
Rally Nut
sounds like the rack is missing some teeth further down - definately pull it out & have a look by removing one of the rubber boots
Cheers mate, will give that a go.
Mk2 Racer
new or secondhand?
Regards, Les |
reconditioned steering rack
Mk2 Racer
as Puzzlescort says I'd be checking the teeth on the rack
Les |
