Old 09-11-2011, 11:32 PM   #1
louiethelouper
td-76
Default td cortina stud pattern!
ive herd that saab interceptors fit on a td cortina! is there a specific model and what size rims are they?
louiethelouper is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2011, 11:48 PM   #2
K10wN
K10wN's Avatar
Default Re: td cortina stud pattern!
The PCD is correct, 4x108.
The offset may not be right though. Really need ET15 to ET25 on a Cortina. The SAAB wheels are usually ET35 to ET45.
The centre bore of the SAAB should be 65.1mm and the Cortina is 63.4mm.
** 2000 Ford Cougar SW 2.5L V6 **
** 1978 Ford BC Escort Coupe 1600 **
** 1978 Ford Cortina TE Ghia **
K10wN is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2011, 01:11 AM   #3
smally289
growing up is optional
smally289's Avatar
If you can find some, Mondeo 15" steelies fit straight on. I had 14's on my TE, they are easier to find.
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2011, 04:57 AM   #4
K10wN
K10wN's Avatar
Mondeo wheel offsets are also ET35 to ET45. This reduces the vehicle track. Yes they will bolt straight on with the same PCD and centre bore as the Cortina, but they are not legal.
Old 10-11-2011, 05:24 AM   #5
smally289
smally289's Avatar
Yeah, I guessed that being a FWD that would be the case. What is the SAAB offset like in comparison?
Old 11-11-2011, 12:35 AM   #6
louiethelouper
td-76
is there a specific year mondeo or are they all the same!!
Old 11-11-2011, 04:29 PM   #7
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
Smally, look at the post above your previous one. Louis, they will all be approx the same offset, most fwd cars are in the same ballpark.
Current shape Mondeos are 5 stud, 90's ones are 4 stud - there are a fair few years in between! The PCD is the same for both.
Old 11-11-2011, 04:32 PM   #8
smally289
smally289's Avatar
Good on me! That's what happens when you cruise the forums during night shift at work lol.
Old 11-11-2011, 05:00 PM   #9
EDtickford
Im told Audi rims fit also...not sure of offset. just my 2 cents
1994 ED XR8 Manual Black
1972 XA Falcon 500 302 Clevo
EDtickford is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2011, 05:44 PM   #10
KR1STO
Just another mock-up..
KR1STO's Avatar
Peugeot 206 & 306 run a 4x108, with ET25 ad ET15 offsets..
Also have 65.1mm centre bore..
They may be some help..?
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2011, 07:07 PM   #11
K10wN
K10wN's Avatar
You'd need a set of centre bore spigot rings made to fit the 65.1mm centre bore wheels onto the Cortina's 63.4mm centre bore hubs. Offest of ET35 to ET45 is still wrong though and if a copper wants to be a ***** he can ping you having the wrong wheels fitted.
Spigot rings is a quick easy job for anyone with a lathe.
Most modern wheels that have 4x108 PCD and ET15 to ET25 offset have a 70mm centre bore, and if you purchased them new they'd come with a set of spigot rings (there are still places selling new aftermarket Cortina wheels in 14" to 17").
Old 12-11-2011, 02:04 PM   #12
louiethelouper
td-76
ok cool! thats if the pigs do pick on them!! ill hunt around for the mondeo ones! did they come in 15s? thanks for your help guys much appreciated
Old 12-11-2011, 09:05 PM   #13
smally289
smally289's Avatar
Most of the early Mondeo steelies were 14s, but there were a few with 15s.
Old 14-11-2011, 07:24 PM   #14
louiethelouper
td-76
what years whould they have been?
Old 14-11-2011, 09:12 PM   #15
smally289
smally289's Avatar
When they were first released in '95 they were all 14s. I can remember that some time during '98 or '99 there were a couple with 15" steelies and hubcaps. Can't help you with any more info than that sorry.
Old 20-11-2011, 11:41 PM   #16
louiethelouper
td-76
ye i found a pair cheap cheap aswell!!!
