12-10-2010, 09:59 PM | #1 | ||
Pro Street Au Ute
G'day all,
I need some info on putting a c4 in an au behind a 5l. Can anyone shed some light on the subject or has anyone done it. I'm worried about the fit, like touching the steering rack with either the gearbox itself or the startermotor as i've heard someone say they do on the e series. Does someone do a bellhousing with the starter on the passenger side or would a smaller starter work. Also any problems with header clearance. Any help would be great thanks. |
12-10-2010, 11:11 PM | #2 | ||
My C4 in my EF XR8 had issues with extractors but was modified to suit but not sure about starter.
Call Al from AL's race glides Sydney as he has done a few E series ith C4 and also an AU with a C4 so im sure he can help u.
Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc |
12-10-2010, 11:51 PM | #3 | ||
Stroking it...
Would also be interested! If you get any info blownv8au please let me know
Had: 347ci AU Then: Now: Busted assed EB Wagon - 5sp and Dual Fuel. |
13-10-2010, 12:52 AM | #4 | ||
Pro Street Au Ute
thanks mickyyyy i will give him a bell might even enquire about a box while i'm at it.
Will do cam. |
13-10-2010, 11:20 PM | #5 | ||
Get a box from Al and u will be very happy like i was, say Michael with the blue stroker EF XR8 that he built a C4 sent u.
17-10-2010, 12:02 PM | #6 | ||
Stroking it...
Any update blownv8au?
17-10-2010, 12:06 PM | #7 | ||
Dellow Automative does a bellhousing with the starter on the passenger side.
17-10-2010, 01:51 PM | #8 | ||
Pro Street Au Ute
no nothing yet cam, been busy ordering wheels and steel so i can build a tray next weekend. Mav50l thats good news, but i didn't think about header clearance for the starter on that side since off the shelf extractors are made for drivers side clearance. So custom headers may be required which i'll have to do down the track but if i can't get a c4 to fit with what i have now it'll have to wait and i'll get a replacement t5 for now.
17-10-2010, 02:00 PM | #9 | ||
AU extractors off the shelf are for a passenger side starter.
17-10-2010, 02:13 PM | #10 | ||
blownv8au
If u go bigger than a 205cc head u will need a custom set of extractor made up dude to port size and bolt thread locations not meeting.
17-10-2010, 03:11 PM | #11 | |||
Pro Street Au Ute
Yeah i'll have to mickyyyy and since you put me onto thinking about trickflows i'd definitly have to ports are raised 0.750in were as afr i was hoping to cut the flange off and get new one lazer cut and weld back on and hope i had enough clearance. Cheers, Preston. |
17-10-2010, 06:10 PM | #12 | ||
If u get ur heads from TEA or Foxlake they have porting programs upto 255cc intake s u run less boost
17-10-2010, 07:01 PM | #13 | ||||
Stroking it...
I am running some old pacies.. Quote:
16-08-2011, 09:34 PM | #14 | ||
Stroking it...
Thread mine I know... But a C4 conversion is back on my radar.. Did this end up happening blownv8au??
Am contemplating going from 4sp + 3.9's + 2800 stall + LSD to C4 + 3.08 + 2800 stall + LSD.. |
17-08-2011, 09:38 AM | #15 | ||
Pro Street Au Ute
Hasn't happened yet cam, i've been stuffing around put the ute motor in my eb. I did buy a left hand starter kit off here a couple of months ago. So now i need a box to dummy up to make a crossmember and measure it for a tailshaft. Will get around to it but i'm a bit more focused on the eb atm. Have you had a look around or contacted dellow at all.
The kit i got is a bit of a let down. Its a c4 bellhousing with the left side cut out a bit and an adapter plate, but they have cut abit to far and cut half way through one of the bolt lugs. So i don't really know how strong its going to be. I don't think it will handel what i want to feed through it so its likely a waste of about $400. |
12-03-2012, 11:04 PM | #16 | ||
I am running a Ford AOD auto in my ute, and the starter is on the right hand side looking from the back of the car to the front. i ended up using a BA 6 cyl starter and it cleared the rack good, just had to remove a bit of metal on the snout to clear the ring gear. Custom pipes are a must to clear the starter being on the drivers side, i will look tomorrow to see if the c10 i have is the same as the AOD but i am sure that it is
MR INCH
06-08-2012, 05:23 PM | #17 | ||
hi guys does the au ecu need to run a std auto box or can the c4 bolt up and it runs fine still??
07-08-2012, 09:19 AM | #18 | |||
MR INCH
07-08-2012, 02:21 PM | #19 | ||
ok cool thanks mate. none of those things will worry me as its just going to be a skid car/ drag car to save me wrecking my ed xr8
07-08-2012, 02:40 PM | #20 | |||
Cool as dude
MR INCH
