Old 19-03-2009, 09:50 PM   #1
notbydesign
Default Mk2 Dash Problems
Hey guys having problems with my dash clusters. I can't get any illumination, fuel gauge, heat gauge, or tacho. But the turn signals, charge, high beam and oil lights are working. Any ideas?
notbydesign is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2009, 11:58 PM   #2
JamesR
for the illumination, you may need to swap some lights from ya old cluster.
http://www.turbosport.co.uk/showthre...gl+ghia+clocks
http://kotisivu.dnainternet.net/b001...ock_wiring.htm
read this thread, might be able to help.
hope it works out ok.
1977 MkII Escort Ghia.
2006 MY07 Subaru Liberty GT Spec B wagon.
my photo blog;
http://www.jamesruff.net
JamesR is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2009, 03:05 PM   #3
JordyCharlieBoz
MkII Escort
You do have the dash lights turned on right? lol.
I have a similar problem... i'll be driving along and the lights drop out cept the fuel gauge, auto electrician says its an earth problem.
JordyCharlieBoz is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2009, 09:36 PM   #4
notbydesign
i swapped some lights over, tried some new wire combinations, but in the end it was stock combination that worked. got the dash lights working. now how do i tell the difference between the wire for the heat gauge and the wire for the fuel gauge? one is working but have no idea which.
Old 20-03-2009, 09:57 PM   #5
JamesR
red/white wire should be from the temp sender.
blue/black wire should be from the fuel sender.
is that what you wanted?
did you get the tacho to work?
my photo blog;
Old 20-03-2009, 10:24 PM   #6
notbydesign
i think the wires on my loom have been customised as they arent the same as the ones where the loom plugs into! i think the fuel sender is working. i have to run a wire from the tacho to the distributor so ive read... not sure if this is true
Old 20-03-2009, 11:10 PM   #7
JamesR
well i guess to check which is temp wire, when car is cold, it wont trigger the guage.
wire from tacho to negative side of the coil.
my photo blog;
