Old 04-07-2015, 03:48 PM   #1
Suh401
Default Esc
Hi guys, I have a 2010 fiesta zetec I will be taking it out on a track for the first time in the next month.
I have been told the esc may cause issues on the day. Does any one know how to turn the esc off manually or a wiring diagram so I can install a switch to turn it on and off for track days. Thanks guys.
Suh401 is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2015, 04:40 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
Default Re: Esc
stability control switch on and .off .....no idea ..pull a fuse ?
fang it around the track till something happens ...that ...you cant explain
only info i can find..about a fiesta today is on this system TC
traction control cant be bypassed on a 2010 fiesta
bet some have tried
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2015, 05:14 PM   #3
Suh401
Default Re: Esc
I was contemplating pulling the fuse Ill give it a go.
Thank you for your help..
Old 05-07-2015, 12:17 PM   #4
fiestaz
fiestaz's Avatar
Default Re: Esc
I have pulled the fuse out on my ESC system in my WT. Some fault lights come up obviously, but it also shuts off the ABS (atleast i assume as that light came up also).
I also found my steering went into a really light setting, rather than its normal gain weight as you speed up setting.
The rest of the car worked as normal.
2016 Mazda 3 SP25 GT
2019 Hyundai i30 Active.
fiestaz is online now   Reply With Quote Multi-Quote with this Post
Old 05-07-2015, 10:33 PM   #5
Suh401
Default Re: Esc
Ok that's interesting, I'll just have to keep that In mind on the day that could be dangerous.
Old 17-07-2015, 04:10 PM   #6
mad axe
Default Re: Esc
on the ws zetec you can retro fit an esc off switch, the metal model has one. all you need is the same switch, connector is tucked up behind lower center consul panel, switch fits in card holder, just pull out panel find connector remove card holder fit switch panel in re install panel, 15 mins tops. plug n play.
mad axe is offline   Reply With Quote Multi-Quote with this Post
