13-07-2007, 12:59 AM | #1 | ||
Hi,
I have an AR 84 Telstar, 2.0l Auto. I has done 53,000Kms and is in great condition apart from a few oil leaks due to the age of the car and not being driven much. Anyway, yesterday i noticed the temp gauge go hot all of a sudden, i pulled over and it was bone dry, i poured some water in and it appers to be coming out of a hose/clamp under the manifold on the passanger side. Any ideas what the hose/clamp could be? Thanks. PS: It blows black smoke (Fuel) and uses a heap of it, would FORD be able to give it a tune up? Thanks again. |
13-07-2007, 07:53 AM | #2 | ||
Over Thinker
that would be a pipe joiner into the inlet manifold to cool the carby
if the hose has a split or the clamp failed you are lucky corrosion may be the problem black smoke-- the carby is running rich probably a choke issue /sure tune it To ford your money is as good as everyone elses
My car goes Brumm Brumm |
