Blue Power Racing Developments The home of Blue Power. Website Link |
01-11-2006, 05:01 PM | #1 | ||
Hello guys i am building a AC cobra and i own a BF gt motor and i am just wonderign if u guys know were u an get a throttle boby for it that uses a cable and not the drive by wire set up?
thanks i hope u can help joe |
01-11-2006, 05:48 PM | #2 | ||
How did you score a BF GT engine.
01-11-2006, 06:20 PM | #3 | ||
AFAIK the throttle drive motor and position sensor is needed for the computer to run the engine, and cant be removed.
But, if you are using an aftermarket ECU, just remove the actuator and replace with an aluminum plate. Extend the shaft through (prob in a bearing) and fit a cable operated cam from whatever you want. Should work fine. I think! Or try a tuner who sells the 80mm throttle bodies and have them do it for you? Blue Power (Chris) sells them doesnt he? BTW, good luck with the project. A Boss 290 in a Cobra sounds awesome! |
01-11-2006, 06:21 PM | #4 | ||
A mate of mine had one nad it got rear ended and was wrote off and he borught it back forom the insurance company so i brought the motor off him
01-11-2006, 10:29 PM | #5 | |||
01-11-2006, 10:52 PM | #6 | |||
BOSS 5.4L Enthusiast
01-11-2006, 10:53 PM | #7 | |||
02-11-2006, 12:06 AM | #8 | |||
02-11-2006, 12:14 AM | #9 | |||
02-11-2006, 03:34 AM | #10 | |||
Youre right, it aint no Ford GT! |
02-11-2006, 04:56 AM | #11 | |||
KB TECH SUPPORT
I've got a standard throttle body in the shed with the servo motor & throttle position sensor blanked off. It's got the shaft protruding through the side with an arm for a cable set-up. It's also been bored out to an 80mm, with butterfly. Regards AGRO. |
02-11-2006, 01:34 PM | #12 | ||
Hey agro how woudl u want for that set up? or do u how to modify the standnard ones?
depends on what parts u want xrqtar i can ask him what he isnt using and let u know if u want |
02-11-2006, 02:28 PM | #13 | |||
03-11-2006, 02:53 AM | #14 | |||
KB TECH SUPPORT
I can machine the standard TB to take the bigger butterfly, and/or make a new shaft to extend out of the side of the TB. Regards AGRO. |
