Old 02-07-2019, 09:34 AM   #1
Default Page Width - Safari, no Tapatalk
See thumbnail for what is happening.
The bar isn’t either wrapping or confirming to page width.
It’s been like this for a couple of days, I don’t think any longer. Same outcome on multiple devices using Safari and up-to-date OS’s.
Old 02-07-2019, 09:38 AM   #2
Linz
*SILVER SERVICE PILOT*
Default Re: Page Width - Safari, no Tapatalk
Same here, also getting an ad for a dent puller before logging in
BUILD THREAD
Linz is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2019, 11:03 AM   #3
PG2
#neuteredlyfe
PG2's Avatar
Hi Everyone
russellw is aware of the situation and is currently trying to work out why it is doing this and how to fix it.
Please be patient until a fix is found.
Old 02-07-2019, 11:22 AM   #4
Peuty
Afterburner + skids =
Peuty's Avatar
Thanks PG2
Oo\===/oO
Old 02-07-2019, 02:42 PM   #5
11ford11
Glad to hear it’s not something I have done
In the meantime Try going into user cp then bottom left change from default to legacy
Old 02-07-2019, 05:58 PM   #6
russellw
russellw's Avatar
I've made a minor change to the navbar display - can someone experiencing the issue please test and let me know. You'll probably need to clear your cache before testing.
Russ
Old 02-07-2019, 08:32 PM   #7
It’s still odd, the same as before.
Old 02-07-2019, 09:00 PM   #8
prydey
Rob
prydey's Avatar
Just came on here to ask the same question. Only started doing it yesterday for me and only on my mobile. Desktop is fine. If I load the site then change browser settings to 'load desktop site' then it fixes it, but I don't know how to make that a permanent thing. If I navigate away or close the site, it defaults back to mobile site.
UA2 TREND 4WD BI TURBO
Old 02-07-2019, 09:01 PM   #9
prydey
Rob
prydey's Avatar
Russ
I also notice some posts appear as normal, so this one from Russ that I've quoted is full width. All the others are narrow.
Old 02-07-2019, 10:41 PM   #10
OCTANEBOSS
Hi Russell,
If you use chrome or firefox as a search engine for AFF and click onto the legit result you end up with ad for a dent puller from a company in Canada in which you can close. They could be legit but may of been compromised as they have been reported for abuse by abuseipdb.com
Funny thing is if you search with IE or epic browser no ad appears and you can log in as usual.
Bloody internet scum bags never stop trying to stitch up their fellow humans
Run in and loving it .;)
OCTANEBOSS is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2019, 11:43 PM   #11
Linz
Originally Posted by OCTANEBOSS View Post
Hi Russell,
This happens to my mobile also, now I have a blind spot mirror ad
BUILD THREAD
Old 03-07-2019, 12:24 AM   #12
OCTANEBOSS
The old 360 degree mirror, high quality by the look of it too
Old 03-07-2019, 08:53 AM   #13
russellw
russellw's Avatar
Hi Russell,
If you have the IP address for them, I can permanently block them and get Google to do the same.
Old 03-07-2019, 09:00 AM   #14
russellw
russellw's Avatar
As noted in one of the earlier posts, it's happening because a page element is not adhering to the page width defined for it (or suddenly has it's own idea of what 100% is). My posts appear ok because the signature picture below my posts has a defined pixel width rather than using the percentage based width that everything else uses.
The mystery is why the element is ignoring the rules all of a sudden but as the legacy style seems to fix it, I can compare the differences between the styles and find the actual piece of code causing the issue that way.
Old 03-07-2019, 11:53 AM   #15
OCTANEBOSS
PM sent
Old 04-07-2019, 01:18 PM   #16
Mr Brooksy
Youth worker
Mr Brooksy's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Numerous helpful how-to's and sound advice!
I've been experiencing this issue for a little bit now as have others. I found that using the dark theme and legacy themes fix the issue. But both "default" versions seems to send the widths of everything mental.
FYI, using Chrome for Android in desktop version.
2007 FPV F6 Typhoon BFII, Neo. Build Number 325
2011 SZ Territory
Old Futura thread:
Brooksy's Ex Build
Mr Brooksy is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2019, 04:15 PM   #17
russellw
russellw's Avatar
I've done an extensive comparison of the 'default' theme against the legacy one and while there are minor code differences, there isn't anything in their stylesheets that suggests what we are seeing.
I'll keep digging but in the meantime I'm probably going to start copying the missing code sections (bit by bit) from the default scheme to the legacy one to see what might be the cause.
If those using the legacy theme could keep me updated it would be great.
Old 04-07-2019, 05:47 PM   #18
Appreciate the efforts to date; the reason I raised it to begin with, is wanting your “brand” to look its best.
Old 06-07-2019, 09:57 AM   #19
Mr Brooksy
Youth worker
Mr Brooksy's Avatar
Things are basically back to normal for me. The post widths are not quite as consistent as the dark version. But basically the same as before the recent change.
Thanks Russ and team
2011 SZ Territory
Old Futura thread:
Brooksy's Ex Build
Old 07-07-2019, 12:04 AM   #20
prydey
Rob
prydey's Avatar
Default style is all good again for me, thanks Russ. Never noticed anything changing on legacy style either.
