Old 28-04-2016, 12:57 AM   #1
Aether
Default Is any of this from a Capri???
ok so now I am putting this capri back together I have boxes of parts and I am not even sure which ones are capri parts and which ones are randoms.
Does anyone recognise any of these parts????
To make it easier I gave them a number...
1.
2.
3.
4.
5.
My Capri Project: http://fordforums.com.au/showthread.php?t=11423076
Aether is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2016, 01:36 PM   #2
Puzzlescort
Rally Nut
Puzzlescort's Avatar
Default Re: Is any of this from a Capri???
5 - sandwich plate behind sump to gearbox
2 - does its match up to the bell housing
it looks like auto trans stuff, brackets etc
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2016, 02:15 PM   #3
Mesa
3 & 4 appear to be front bumper brackets off a HQ Holden.
Mesa is online now   Reply With Quote Multi-Quote with this Post
Old 28-04-2016, 02:20 PM   #4
foxtrot3
foxtrot3's Avatar
Hi. 1 gearshift boot to floor reinforcement ring
2 gearbox/auto adaptor
3 HZ holden bumper bracket
4 HZ holden bumper bracket
5 flywheel cover plate
Cheers MD
HI
I'M MICHAEL
Old 28-04-2016, 03:08 PM   #5
Aether
Cheers MD
Thanks foxtrot.
1. I'll try that. I think you are right
2. Is this for capri v6 or another model? I didn't think it looked like my bell housing shape
3&4 I'll take that for granted.
5. I checked this but the holes don't line up with my bellhousing. I'll post a pic tonight to confirm. Could it be from an auto model?
Old 28-04-2016, 03:22 PM   #6
Tassie f100
I reckon the adapter ring is to fit a Holden Turbo 350-400 to a Holden Traumatic pattern V8 engine
Tassie f100 is online now   Reply With Quote Multi-Quote with this Post
Old 28-04-2016, 08:32 PM   #7
allanv6gt
Tippy-tronic Free Zone
1. V6 gearstick boot clamp to tunnel
allanv6gt is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2016, 01:15 AM   #8
Aether
Well you guys are pretty good at this game so I am going to keep sending them through. Heres another 6 to chew on. Theres's about 20 more parts I cant identify after this batch.
6.
7.
8.
9.
10
11.
Old 29-04-2016, 10:31 AM   #9
whitelion65
whitelion65's Avatar
#6 SEAL, RADIATOR SUPPORT TO FRAME, LH. Toyota
Easy google search on part number!
Steve
Current rides
2012 Mondeo Titanium wagon (TDCI)
Moondust silver
2016 Focus Trend, 1.5ecoboost, 6sp manual.
Frozen white
Previous
2004 Berlina Wagon (LS1) Vespers Blue
1995 Camry 2.2, white
1971 Ford Fairmont wagon 302w, C4 Polar white
1971 TC Cortina, 2L 4sp, Ermine white
whitelion65 is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2016, 11:04 AM   #10
Tassie f100
No 3 is an adapter to fit a 2 barrel holley carb to an engine originally fitted with a 2 bbl stromberg or carter carb.If you got sick of your old car fitting a Holley was a good way of it catching fire and burning to the ground!!!
Old 29-04-2016, 11:31 AM   #11
900dukess
7 = Fuel tank breather tube (located near filler tube)
9 = Capri 'Glove Box Trim" fits in dash on passenger side
11 = Capri tail light covers (fit inside boot over tail light globes and connectors)
900dukess is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2016, 09:50 PM   #12
allanv6gt
darn, too slow at this game ...
However, number 10 - I was going to say rear parcel shelf somewhere, but I think I'll go for ...
Heater Box floor vent near transmission tunnel, part no E920-T-1 (rhs) and E921-T-1 (lhs) , just below the tab on the heater box which supports your parcel shelf. Refer section 180 Heating and Ventilation Units@ bottom of page in the Ford Parts manual.
Ha !! that's 1 point to me !!!
(I did also correctly identify 7, 9 and 11, but wasn't the first so no points gained.)
Hang onto these photos, would make great trivia night questions .....
Old 29-04-2016, 09:55 PM   #13
allanv6gt
Okay, were finished with this set, can we have some more pls ?
Old 30-04-2016, 12:00 AM   #14
Aether
Ok ill need to do a points tally at the end.
I am a little surprised at how easy you guys are finding this. I'll hope these next 6 are a little harder.
12.
13.
14.
15.
16.
17.
Old 30-04-2016, 07:34 PM   #15
allanv6gt
12. (pass) Not Ford - The plating suggests something newer than early 1970s. Taper tip suggests Japanese (çoz they actually think about making assembly easy !!!)
13. Capri - Air diffuser from base of heater box.
14. (pass) I presume that is metal and not felt?
15. (pass) Not Ford - Looks like a timing chain auto (spring loaded block) adjuster bolt. (designed to rotate in a sleeve, frequently).
16. (pass) Not ford - looks like a throttle cable bracket that has adjusting with lock nuts.
17. Not Ford - Door striker plate. Not Capri at least.
Hmm... only 1 point today.
Old 11-06-2016, 05:18 AM   #16
whooligan
whooligan's Avatar
I like this game.....If I went thru my shed it would blow your guys minds. The previous owner of 2 of my cars (deceased estate) was into early falcons and motorbikes. I was given a whole heap of stuff I have never been able to identify.
I have listed stuff on ebay for 99c and someone usually identifies it.
whooligan is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2016, 05:22 AM   #17
whooligan
whooligan's Avatar
Oh, number 10 are trims that were fitted to the base of Capri rear quarter internal trims. Where they meet the floor of the car.
They are upside down in the picture which makes them hard to spot.
Old 13-06-2016, 07:49 PM   #18
allanv6gt
sorry whooligan, I beg to differ
(see my post 29-04-2016, 08:50 PM) You may be thinking of 70301-K46 or K47
See : Soft Trim - page 2 diagram top picture - Side trim
oooh, let the argument rage !!! bwa ha ha !!!!
Vale : Green Beastie (pic'd)
Hello: Diamond White 19 yr project
Old 13-06-2016, 09:27 PM   #19
whooligan
whooligan's Avatar
Not arguing. It was a just guess based on a very brief look.
I don't have a parts manual to refer to, just my foggy memory.
Old 14-06-2016, 08:30 PM   #20
allanv6gt
No probs.
I once tried using my parts manual as bedtime reading, to put me to sleep.
You know the kind of book; plain pics and boring text with no plot line to follow.
Unfortunately, all it did was make the brain go faster dreaming up more crazy possibilities !!!
Old 20-08-2016, 10:35 PM   #21
Aether
Ok so I am now trying to fit this breather tube but I have no idea how it goes on the car. My service manual doesnt have a pic so does anyone have a pic from the parts manual? I think it attaches to the fuel filler neck, and a vent hose goes from the fuel tank to one end of this piece and then it continues to the small opening underneath the fuel cap??
Any help much appreciated. The tank is in and the fuel cap will arrive any day now. Getting close to starting the motor, one piece at a time.
Old 23-08-2016, 11:20 PM   #22
allanv6gt
Try this for starters. 'Tho some real pics would be better
http://www.fordforums.com.au/photos/...=65840&cat=500
Old 23-08-2016, 11:35 PM   #23
allanv6gt
...... is a drain for overflow, goes from dish of filler cap (outside, under flap) to a hole in the inner skirt just behind the wheel arch. Very rarely 'activated'. Supposed to stop the embarrassing stains down the side of the car. Not connected to fuel tank in any way.
In the pic above, the downward hose from the metal loop (item 7) , IIRC just vents outside thru the floor (but i'd have to go and have a look). ..... At grommet 0706348 under 44725-S washer. Hope this makes sense.
p.s. any more random bits for identification?
Old 23-08-2016, 11:51 PM   #24
Aether
Ok thanks thats golden, thanks heaps.
I'll do the vent pipe first as I am pretty sure I know the grommet you are referring to. Although he doesnt answer to the name 0706348. In fact he doesnt answer me at all.
As for the overflow drain, I think I know the exit point you are talking about because I think it was cut out during rust repairs and replaced with blank sheet metal.... So I guess ill drill a new hole for it. This might mean I may need to install the battery on the passenger side instead of the drivers side. For anyone who has put the battery in the boot on a capri, is there a preference?
As for mystery parts, I have a few which ill post once I get my computers with the pictures sorted out.
Old 25-08-2016, 01:47 PM   #25
Aether
Ok so before I start installing tubes, can I check if these are the correct places to route them?
A: Opening in the rear inside fender for the fuel overflow tube
B: Opening for the fuel tank vent (just near where the fuel supply hose comes through). This one I am not sure of because the hole looks small.
A:
B:
Old 25-08-2016, 01:58 PM   #26
Aether
More Mystery Parts:
18.
19.
20.
21.
22.
23.
24.
25.
26.
Old 25-08-2016, 02:29 PM   #27
BlueBear
Shockwave
BlueBear's Avatar
14 looks like a handbrake cable joiner, wouldn't know if it's Capri or not though.
Cheers,
BlueBear is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2016, 08:03 PM   #28
cosworthfreak
cosworthfreak's Avatar
18. Mounting brackets for Rego plate to front bumper
19. Finishing trim for rear parcel shelf (drivers side)
21. Looks like bracket with timing light markings, but not sure if it's capri
22. I think this is a spacer that fits over the windscreen wiper spindles on capris
23. Not sure, but they look familiar
24. Bottom radiator deflector panel
This game is fun.
cosworthfreak is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2016, 08:30 PM   #29
Aether
This game is fun.
Damn.... I literally sent some parts for Zinc plating yesterday.... Should have posted these pics first. Oh well I guess ill sandblast them and paint.
Old 01-09-2016, 09:40 PM   #30
allanv6gt
Darn, too slow ... (thanks Windows 10 roll-back crash !!)
18. As above. Yup.
19. As above. Yup.
20. Pass.
21 - Yes timing. Not V6, which has the timing points as part of a moulded knob on the front of the .... timing ... cover.
22. Windscreen wiper spacer, inside car, under scuttle. Lugs point down IIRC (?) and wrap around black mounting bracket - not moving arms. Ensures clearance of oscillating arms under scuttle panel.
23. c-pillar headlining hooks and parcel shelf support that 19 screws to. Mount these on shell, stretch headling and staple to those nasty triangular tabs to keep the stretch, and 19 screws into the inward facing face to stop your shelf rattling around.
24. Radiator shroud - agreed. But if this is bottom V6 then well done. Never seen one OEM.
25. Something you would stretch a small coil spring to e.g. throttle spring mount. But not Capri V6.
26. Pass.
I think we're all ready for some more fun now ........
