11-06-2013, 02:42 AM | #1 | ||
I have a KE laser 1.6 carb. I have replaced coil & distributor & still have no spark at plugs. I am completely lost, can anybody help please.
Thank you for any response. |
14-06-2013, 02:26 AM | #3 | ||
It is not the std round coil, it is module type coil, I cleaned body where coil mounts and I have replaced engine control module on fire wall, still no spark, dist came off a running vehicle.
14-06-2013, 10:08 AM | #5 | ||
From memory, there is a black module inside the distributor called an ignitor....about the size of a matchbox, that can pack up. Easy to replace, needs to have thermal paste under it though. If this packs up, no spark.
Something like this: http://www.ebay.com.au/itm/IGNITION-...-/121066909830
LV MKII Focus XR5 - no mods yet! |
14-06-2013, 11:11 AM | #6 | ||
I have tried all the swap with old & new, I have put both units on a friends laser & they work ok.
14-06-2013, 11:13 AM | #7 | ||
15-06-2013, 12:29 PM | #8 | ||
Geez that's weird. Might be time to get a auto elec to look at it ???
Maybe also check all your fuses & relays - to make sure one hasn't blown. Engine is cranking over - just no spark ???? |
15-06-2013, 12:40 PM | #9 | ||
Thanks Peter, I think it is time to send to wreckers not worth spending more money, its had a good life.
