hi all
i have an xy fairmont i am upgrading driveline in to give true street a crack in APSA, the question i am asking is what sort of brakes are people running to pull their things up from 130+mph. i was looking at keeping the rear drums but upgrading the fronts, any suggestions? cheers brent
XY Fairmont GS 12.94 @ 104.5 Daily Driver 351clevo no longer, in comes 428ci svo block with trickflow heads, hogans sheet manifold and 1050 carb, 760hp at flywheel, bring on big skids FOR SALE:Moroso sump to suit SVO/Dart block pm for details FOR SALE:Brand new Dart block 9.2 deck 4.125 boreSold |
i wouldn't touch the fronts but i would put discs on the rear. if you crack 130mph with disc/drum ya need a chute and disc/disc is 140mph. the stock fronts should be more than enuff considering the width of a front runner dont put much of a foot print down anyways and its not like bathurst where your on the brake every 10 secs. but thats just my thoughts others may say differently.
V Gate got it slightly wrong.
Any vehicle at over 140mph needs a chute. If you have front and rear brakes (disc or drum), there is no requirement for a chute up to the 140mph limit. If you only have 1 set of brakes (front in a sedan, or rear only in a dragster), then 135mph is the limit when you will need a chute. I comfortably stop with the stock disc/drum factory combination in my xa coupe from 135mph, as do most others. Just make sure you have good quality pads and discs. Don't get cross drilled discs because they will crack around the holes. Also make sure you have fresh top quality brake fluid. The final tip is that a mid-range pad is best. A full race pad takes too long to heat up with just a single stop, and a standard pad will get too hot by the end of braking.
XA coupe 8.8sec @ 150mph http://www.fordforums.com.au/showthr...coupe+drag+car BA GT-P for the shed Mustang GT for the other half E3 chubsport - fully fat (and slow), sitting there waiting for me to get sick of it and sell it. BA XR6T for a daily NT Pajero for the bush XB 4 door project- swallows a BF xr6 turbo My dad is a generous bloke. He gave away his dead car batteries free of charge.... |
If your getting a diff built why not get disc rear end
Too much braking is better than not enough |
#5 | |||
#6 | |||
![]() I need some reading glasses! One figure relates to dragsters, the other to sedans with 2 wheels braking.
sounds like we both better start reading the rule book instead using our powers of remember
thanks guys for the tips, i have slotted rotors on the front of mine at the moment so i might just stick with them and drums on rear and see how we go.
