Old 01-01-2020, 03:19 PM   #1
stefcio007
Question Force Air Recirculate
Is there a way to do this?
It seems after a while it just goes back to taking air from outside.
Now normally that's no so bad as I can turn it back on pretty quick but now with the bushfires it's especially bad with air pollution.
I don't understand the logic. Am I missing something here?
2020.25 Focus SA ST-Line Wagon + DAP
2011 Focus LW Trend (Diesel) [sold]
2006 Territory SY Ghia (AWD)
stefcio007 is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2020, 03:39 PM   #2
prydey
Rob
prydey's Avatar
Default Re: Force Air Recirculate
This is no doubt for your own safety. Using recirc for extended periods can be dangerous. Not sure if there is a work around for it. Not familiar with your car.
UA2 TREND 4WD BI TURBO
prydey is online now   Reply With Quote Multi-Quote with this Post
Old 01-01-2020, 03:41 PM   #3
stefcio007
True, but I'd like to be able to choose the less dangerous option.
Another option might be to pre-cut some kind of filter material and place it on the inside of the outside vents.
Old 14-01-2020, 11:12 PM   #4
stefcio007
My dad drives an Endura at the moment and he said you can definitely force air-recirculate to stay on. Is this because it has Sync 3?
Old 15-01-2020, 01:07 AM   #5
GTLEGEND
Your 2011 Focus is the European built vehicle with the indicator stalk on the LHS of the steering column. The later LW2 was built in Thailand and ID's by the blinker stalk on the RHS like most Aussie built vehicles.
In Europe its an EDR (I think that's correct), which is the equivalent of our ADR's to have the Fresh/Recirc vent to turn back to fresh after a certain time (around 10-15 minutes) so you don't breathe in your own Carbon Monoxide from the recirc position and fall asleep behind the wheel. Changing to fresh reduces this from happening. Because the car is built at sold in Europe, it was built to that specification. We do not have that as an ADR so there was no need to make any change to the vehicle when sold here.
When LW2 came along, built in Thailand for the Asia Pacific market, this was no longer a necessary function, so it was not specified to be like that and you can keep in either mode as long as you want.
You will find any vehicle built in Europe and sold here will be like this..
Old 15-01-2020, 01:08 AM   #6
GTLEGEND
You should have a pollen filter in the vehicle to help like this:
https://www.ebay.com.au/itm/FILTER-O...frcectupt=true
