Old 11-01-2020, 07:01 PM   #1
XW WA
XW WA's Avatar
Default AU IRS camber adjusters
Help ,Ford part for the XRs are obsolete and there doesn't seem to be an aftermarket replacement part that I can find on the web . wreckers that I have called are no help . Any one got a lead on what to use or some second hand ford units ?
XW WA is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2020, 07:06 PM   #2
tbro4123
Default Re: AU IRS camber adjusters
I've just had the same problem.
I'm taking down the drawing to my machinist to see if he can make these up at a competitive price with hardened washer, should know within the next day or two.
Can pm if you like.
Terry aka Tbro
tbro4123 is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2020, 08:57 PM   #3
XC50077
Drive'n Cruise'n Live'n
XC50077's Avatar
They don't look terribly different to Falcon XC front suspension camber bolts. Have some in the garage and will check tomorrow. Kmac made the best replacements for XC maybe worth a call.Cheers
XC50077 is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2020, 04:04 PM   #4
XC50077
XC50077's Avatar
XC is a little shorter and .495 inch dia.large washers are 43mm dia. cheers
Old 14-01-2020, 10:12 AM   #5
XW WA
XW WA's Avatar
thanks XC50077 for taking the time to measure them up . I have now sourced a set from a bloke wrecking an XR 8. Its a shame there is no generic after market product .
Old 18-01-2020, 09:38 AM   #6
NCII40
XR6T BA 2002
NCII40's Avatar
Good Find,
Can't believe they went Obsolete
While your back there, if you want a new 22mm Signature rear sway bar to put in, PM Me
XR6T 2002 BA
NCII40 is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
