Old 04-02-2020, 07:31 PM   #1
Dingo
Ford T3 Partsologist
Dingo's Avatar
Default AU Upper Control Arms
These are advertised on ebay - but have a question
BAF-3044-B and BAF-3045-A is what these Guys are selling for a AU Sedan, The BAF-3044-B is a BA Ute arm, Ford Lists a BAF-3044-A for a AU Sedan - does any one know if they are the same even tho the part numbers are different ?
Any information would be helpful, thanx
https://www.ebay.com.au/itm/254326195449?ul_noapp=true
2002 Blueprint T3 TE50 Manual Koni Suspension # 161
T-Series Club of Australia - www.tseriesclub.org
Dingo is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2020, 08:28 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Default Re: AU Upper Control Arms
Ok.
BAF 3044 A is the RH upper arm for a sedan or wagon
BAF 3044 B is the RH upper arm for a Ute
BAF 3044 C is the RH upper arm for the RTV ute
The BAF 3045 ? are the LH versions of the same thing.
Observatio Facta Rotae
Old 05-02-2020, 09:18 AM   #3
Raptor
Raptor's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For quietly going about moderating in a fair and even manner.
See also : RTV front upper suspension arm question <= includes pics (one of which included below)
Though I'll admit I still don't know which are which, I do prefer the beefier I-cross section version though, which ever one that is.
I do not know why utes are different to sedan/wagon. Yes utes have a longer wheelbase and perhaps should have different in-built caster, but so do wagons have a longer wheelbase but use the same as a sedan
I do know the RTV mounts to the body are different - to lower the arm/raise the ute (which ever way you prefer to think about it).
'93 XG Falcon Ute( sold ) : '94 ED Falcon Classic ( sold ) : '04 Territory SX TS ( sold ) : '04 Falcon RTV BAII ute (still in the family)
Raptor is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2020, 04:19 PM   #4
Dingo
Dingo's Avatar
Thanx Raptor
So the BA Ute one appears to have a wider bush and bracket, can this be used on a AU Sedan ?
Old 06-02-2020, 08:58 PM   #5
Dingo
Dingo's Avatar
Raptor would these be a better option to use on a AU SDN - BAF-3044-D & BAF-3045-D
https://www.ebay.com.au/itm/GENUINE-...frcectupt=true
Old 06-02-2020, 09:44 PM   #6
Raptor
Raptor's Avatar
Hey, I'm no expert on these things.
But assuming the later design changes have been done for a good reason and in the other thread I mentioned it confirms some of the earlier ones are now absolute and can be replaced by the later ones.
I'd choose BAF... over BA... part numbers and the latest alpha designation.
So BAF-3044/5 D seems like the latest and greatest.
Why do you need to replace yours anyway? I also suspect they are all same enough to work AU - BA - BF as the structure they bolt to is unchanged.
Old 07-02-2020, 12:56 AM   #7
Dingo
Dingo's Avatar
Im not needing to replace im just thinking of buying a spare set for down the track for the T3 as these are now obsolete from Ford so i would like to grab a set why they are available and the price is reasonable as well for a Genuine Part but i just wanted to check that these are ok
Thread Tools
Display Modes
