23-11-2011, 02:33 PM | #1 | ||
Over the weekend I changed plugs (BPR6EFS-13), Leads (Eagle Eliminator), coils (MSD) and cam sync. Now for some reason, and maybe it's in my head, but my exhaust seems to have gotten a drone at highway speeds...
Is this even possible? I wouldn't have thought so. The car has standard extractors and cats, but I think has an aftermarket cat back (I've not seen an factory exhaust, so can't be 100% sure). On a side note, plug 5 is a real pain in the butt to get at. I assume this get worse with after market extractors?
HIS: AU III XR8 220, 5 speed manual, short shifter, MSD coils, ACRON CAI, Front 330mm brakes with C4 calipers and braided lines HERS: BA Fairmont, vapour injected LPG I reject your reality and substitute my own! |
23-11-2011, 02:39 PM | #2 | ||
Flairs - Truckers Delight
cam sync - as in the cam that opens and closes the exhaust valves?
It's entirely possible.
23-11-2011, 02:49 PM | #3 | ||
Cam sync was squealing when cold, as is not unusual from what I've read on here. Unless the sync wasn't functioning at all, surely that wouldn't have an effect on the valves opening / closing. And yes, it was removed and installed with cylinder 1 at TDC and all lined up the same going in as it came out.
I should point out this is on the XR8 220 in case that wasn't clear.
23-11-2011, 06:26 PM | #4 | ||
RIP...
I would suspect it's all in your head.
. Oval Everywhere... |
23-11-2011, 07:51 PM | #5 | |||
[SIGPIC][/SIGPIC]
23-11-2011, 08:09 PM | #6 | |||
Afterburner + skids =
23-11-2011, 08:35 PM | #7 | ||
Yes it is possible, you have just change components that effect how well the engine run's and its overall tune.
The drone being a result of now running better and smoother, aka more consistant firing of all cylinders.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
23-11-2011, 10:47 PM | #8 | |||
not here much anymore
RAM 1500
24-11-2011, 02:56 PM | #9 | ||||
While we are on the subject, does anyone have a pic of the factory cat back?
24-11-2011, 03:02 PM | #10 | ||
No you got the name right. It was the 6cylinder owner that was confused!
24-11-2011, 03:38 PM | #11 | |||
AU II XR8
AU XR8 II ute XD FAIRMONT GHIA 302 XA FAIRMONT 302 TOPLOADER |
24-11-2011, 04:33 PM | #12 | ||
sigh.
24-11-2011, 06:01 PM | #13 | |||
[SIGPIC][/SIGPIC]
