22-07-2005, 10:35 PM | #1 | ||
Silhouette AU1 TS50.
Does anyone know if all the 220kw V8 motors in the AU's have the same camshaft? The camshaft in the early SVO alloy head 220kw is the following:
Camshaft = FIZE 6250 AIA. Intake opens = 20d BTDC. Intake closes = 76d ABDC. Exhaust opens = 67d BBDC. Exhaust closes = 19d ATDC. Valve lift: * 7.055mm Inlet. * 7.061mm Exhaust. Valve size: * 49.2mm Inlet. * 39.1mm Exhaust. Do the later GT40-P iron head 220kw motors have the same camshaft and valve size as above?
"People can have the Model T in any colour.. so long as it's black." HENRY FORD (30/07/1863 - 07/04/1947) PIC'S OF MY T1 TS50.
29-07-2005, 12:51 PM | #2 | ||
Anyone?
C'mooon.. there's got to be some cluey guys out there. :
29-07-2005, 04:05 PM | #3 | ||
Have you tried ringing Tickford/FPV. They may know. Or just PM Russ - he knows everything.
Does anyone know if there are any gains to be had by fitting this cam to the 185 kw AU1 or the AU2 200kw motor. Or is it just better to get the 2030/2031 cams?
29-07-2005, 07:38 PM | #4 | |||
Club Moderator
220kw @ 5250rpm 435nm @ 4000rpm valve timing = Inlet opens 14deg BTDC Inlet closes 74deg ABDC Exhaust opens 72deg BBDC exhaust closes 22deg ATDC Valve Lift Inlet 11.9mm Exhaust 12.0mm Valve Diameters Inlet 49.3mm Exhaust 39.4mm Going on this spec sheet it only lists that the heads changed from the SVO Y303 to the GT 40P (yella terra rework) in april 2001. It doesnt mention anything about the cam being changed. But looking at the difference in specs from what you have to what i have it must have been. Strange??? hope this helps a little Cheers Tim
2001 T2 TS50 2002 T3 TS50 2006 FPV GT Racecar 2010 FPV F6 Ute 2016 FGX XR6 Sprint 2020 PX3 Ranger Wildtrak |
29-07-2005, 11:55 PM | #5 | ||
Thanks EDXR6. Can I ask.. where did you get the spec's from please? I got my cam spec's from the FTe brochure on this site.
30-07-2005, 12:07 AM | #6 | ||
Club Moderator
I have a copy of the Tickford V8 Engines comparative engine chart.
I dont know how true it is, a few things on it we have found different, especially when it came to the 250kw motor. I know this will make me sound like an **** but i cant post it up here for people to view till i get permision from the people i got it from. Sorry :( Tim
30-07-2005, 12:23 AM | #7 | |||
30-07-2005, 09:53 AM | #8 | |||
