Go Back   Australian Ford Forums > Ford Australia Vehicles > Small and Mid Sized Cars > Cougar and Probe
Old 18-02-2018, 03:06 PM   #1
WildRacer
Cougar King
WildRacer's Avatar
Default Re: Cougar - SCT Tuning?
Originally Posted by REDDYZ View Post
SCT sells tuners specific to Cougars which can backup current program and flash it with SVT ECU program. It's pretty much plug and play sort of. On the top once they back up current ECU they can custom dyno tune as well. Not sure what happened in these 5 years things have changed a lot.
Anyway you can hookup a scan tool and go into Engine management which will give you the ECU code. Mine is an Eibach cougar and can give you the code off my car if that helps.
I have a 2000 Eibach MTX as well so your Strategy code should be identical to mine I would assume. That would be good if you could send it to me, I will pass it onto Herrod and see if they will authorise the tune for the Cougar. Thanks!
00 Eibach Cougar
Mods:
Escape 3.0 V6
ST220 UIM and LIM
NPG Fuel Adapter
California Clutch Stage 2 Disk and PP
ST200 Flywheel
Torsen LSD
Updated Shift Forks
ToyoSport Exhaust Headers
Custom 2.5" Exhaust dual
BAT 21mm RSB
PRT Heavy Duty rear drop links
Energy Suspension Polybushes all around
Eibach Suspension
Eibach body kit
01 Gauges
01 Steering Wheel
Aluminium Sports Pedals
Sony Double Din HU
ST200 Airbox
ST200 TB
Direnza ST200 Aluminium Radiator
Goodridge Brake Hoses
WildRacer is offline   Reply With Quote Multi-Quote with this Post
