Feel the boost
hey all.
I picked up an au3 xr8 couple of weeks ago. Sadly the other day whilst coasting 140km/h i came round a RH bend with little bit of a dip in it, the v8 suddenly died in the ***. kinda like it starved for fuel. its still been like it since then, it happens when ya punch the throttle, or while cruising if ya hit a decent dip in the road it stutters again. Looking for any suggestions cause i would really like to have my power back.
2005 BA Mk2 XR8 ...... Let the fun begin ![]() Drive carefully! Remember, it's not only a car that can be recalled by it's maker. |
#2 | |||
You may also have a pickup issue in the fuel pump. Is it low on fuel when doing it?
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s 226.8rwkW@178kmh/537Nm@140kmh 1/9/2013 14.2@163kmh 23/10/2013 Boss349 built. Not yet run. Waiting on a shell. Retrotech thread http://www.fordforums.com.au/showthr...1363569&page=6 |
EBfairmont with TE50motor
could be maf as well
adrian
its the fuel pump. apparently there was a batch of them that suffered this issue. my S3 XR8 did it, so took it back to Ford and they replaced it with a hi flow pump (which is the factory fix for the issue) under warranty, and problem gone. usually only happens below half tank.
T3 TS50 #17 275kW AU3 XR8 SVP 220kW |
#5 | |||
Blue Blooded
Spark plugs?
Feel the boost
Thanks all for the input and ideas. I pulled the fuel pump out, to find a bit of water in the tank. All drained and much better
#8 | |||
Made the 300 :0)
New Owner of a fiesta ST |
