Old 08-03-2009, 07:29 PM   #1
Tucool
Tucool's Avatar
Default Which Car Jack ???
G'day all,
I've got a BFII XR8 ute which I like to Drag from time to time... but getting the wheels swapped from street to Drag and back again is a very time consuming pain in the Butt because of all the skirts on the XR8.... has any one come up with a good car jack for this Job ??
(and I don't want to use a big workshop tolley jack) used:
Tucool is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2009, 07:45 PM   #2
jaydee
jaydee's Avatar
There are small trolley jacks that do the job and don't take up hardly any room and easy to carry about.
jaydee351
4DV8
jaydee is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2009, 07:55 PM   #3
Tobey
BF Ute...
Tobey's Avatar
Originally Posted by Tucool
G'day all,
Short of using a trolley jack there isn't many options.
You will still have issues with lifting the front because of how deep the cross member is on the falcon. So you still have to jack either side at the front.
However the rear is simple, just jack off the diff.
But as said you can get a small trolley jack for doing light work.
Tobey is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2009, 08:24 PM   #4
ZA-289
ZA-289's Avatar
Bottle Jack maybe? But a trolley jack is the best idea, you can get light alloy ones. Get a decent electric rattle gun while your there and the job will be easy as!
Am I correct in assuming that the front crossmember is alloy? If so it should not be used for jacking.
ZA-289 is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2009, 08:51 PM   #5
FPV+fteT3
Performance Inc.
FPV+fteT3's Avatar
The problem with trolley jacks of any type is getting them under the side skirts or front airdam. You need a small ramp to run up on to get the trolley jack under the car.(xr or fpv body kit)
The original jacks are next to useless even on flat concrete but would not recommend jacking on the alloy crossmember at the front. For the rear on a ute trolley jack under the diff both wheels up and done.
In The Garage...
FPV Super Pursuit Build no 0080/91
Lotus Exige S/C S240
Kart Hasse Chassis 100J Power
Originally Posted by flappist
Rental cars, the equipment of choice to get to destinations where 4WDs fear to drive......
FPV+fteT3 is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2009, 09:32 PM   #6
Tucool
Tucool's Avatar
I'm only thinking of the rears and believe me changing with any conventional Jack is fiddly because of the skirts.... I,ve been thinking of getting an "old Ho^%#n" jack because of it,s circular movement instead of the up/down movement of a conventional
Jack.
Old 08-03-2009, 09:43 PM   #7
Matt P
No Boundries
Matt P's Avatar
Snap on make an alloy low slung trolly lack perfect for low vehicles with body kits its light and does not take up alot of room.
Matt P is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2009, 10:14 PM   #8
BlackLS
yum
Throwing it out there and it might be a silly idea but what about an exhaust jack?
2005 LS Focus LX
250,000kms.
Old 09-03-2009, 09:40 AM   #9
geckoGT
Ich bin ein auslander
geckoGT's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always level headed and i notice him being the voice of reason when a thread may be getting heated
I have a super pursuit and find that I have no problem getting a small trolley jack under the side skirts if I use the opening in front of the rear wheel to get it past the skirt.
If you are jacking under the diff (ok on ute live axle, never on seedan IRS as you will damage the diff bush) you will have no hassle getting a trolley jack under there. Either that or if you must have the best, cough up lots of cash and get V8SC air jacks :
Growing old is compulsory, growing up is optional!
geckoGT is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2009, 03:21 PM   #10
vanman_75
XD Sundowner
vanman_75's Avatar
i was about to type that ,quik very flat and a good price .
something old something blue
vanman_75 is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2013, 05:51 PM   #11
gjmelb
Default Re: Which Car Jack ???
G'day fellas, I just restored a 2T trolley jack today. I filled it up with valvolin atf dx3 as I didn't had any jack oil handy. The thing lifts & holds the load well, good damping while return. It does gets a bit hard to pump under load at the uppermost range. Is that normal or should I replace the oil? Since I bought it from a gara sale, I don't know if someone has stuffed with the safety adjustment screw. Any ideas on how to set that right? Cheers.
gjmelb is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2013, 06:10 PM   #12
blueprinted_xr
FPV F6E FG XR8 UTE EL XR6
blueprinted_xr's Avatar
or do it the lazy mans way...
http://www.ebay.com.au/itm/12v-Sciss...item2a27007365
blueprinted_xr is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2013, 06:29 PM   #13
Rockape
Rockape's Avatar
Hahaha that's cool ^^^ im getting one
PX1 Ranger
Kawasaki ZZR1100
Rockape is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2013, 06:35 PM   #14
Whitey-AMG
AWD Assassin
Whitey-AMG's Avatar
Originally Posted by blueprinted_xr View Post
That is gold!
Whitey-AMG is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2013, 07:13 PM   #15
The G6ET Spot
I have just bought one of these. Only weighs 22kg will lower to 90mm so will fit under nearly all cars and only take 8 handle strokes to full height.
I had a steel jack before now it just sits in the corner all lonely not getting used
http://www.ebay.com.au/itm/trolley-j...item1c36426cad
The G6ET Spot is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2013, 07:16 PM   #16
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
www.transquip.com.au
Check out their range of trolley jacks, they also ship Australia wide quite cheaply.
Franco Cozzo is online now   Reply With Quote Multi-Quote with this Post
Old 10-09-2013, 08:09 PM   #17
Spurious
It's amazing where you can place a trolley jack head: under diff, under control arm bushes/mounts, under ball joints (XF etc...), under the tow point/loop/hook, under the chassis rail at a junction (where 2 sections meet), under the tow bar.
There's no easy way other than some type of jack & a tyre iron!
Invest in a single stud axle & an airbag jack.
just keep the bag away from the hot exhaust pipe & sharp edges!
Spurious is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2013, 01:17 AM   #18
mik
mik's Avatar
i don't know how one of these would go if using a small compressor, but i have one for home use and it is very good for small height single wheel lifts, but at max height they can be unstable, i bought the model with the 2 short handles which is ok, but having had one now , i think the long handle with the remote and a bit of a hinge added so you can drop the handle would bloody grouse, but heavy little buggers and judicious use of the up button is needed because they lift god dammed fast, i say again at height they can become unstable, and once 2 wheels are off the ground again they can become even more unstable..
http://radum.com.au/catalog/index.php?cPath=11_289
Edit: you need to check the minimum height for your application.
Old 11-09-2013, 03:21 AM   #19
ILLaViTaR
ILLaViTaR's Avatar
Jacking up a car is probably the hardest/most annoying part of working on it haha you can jack up from the diff (front wheels chocked) and the k frame and cut the job in half as it's 2 wheels per lift as opposed to 1 wheel. Still a lot of effort really. I want one of these air jacks but have no idea whether they're any good. One of those and a rattle gun would have the wheels done in minutes
http://www.ebay.com.au/itm/151109092...84.m1423.l2649
EB II 1992 Fairmont - koni reds, wade 977b, 2.5inch/4480's and much more to come!
ILLaViTaR is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2013, 07:08 AM   #20
Towie 1962
Those air jacks are the goods, I use them doing wheel changes on the freeways in Melbourne for the RACV.
Towie 1962 is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2013, 03:09 PM   #21
PridenJoy
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For his contributions to the forum, especially showcased with his highly detailed AU build threads. He is a fountain of AU knowledge.
Looks like someone bought a heap of Costco jacks and flogging them on ebay for a slight premium. They are great jacks by the way, but not that light.
PridenJoy is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2013, 05:41 PM   #22
jpblue1000
jpblue1000's Avatar
I agree, Just bought one to replace one whose valve balls went missing during a maintenance mishap. works well, is low enough but quite heavy compared to my old alloy jack. But does lift significantly higher. Nice price as well. 4/5 from me.
jpblue1000 is offline   Reply With Quote Multi-Quote with this Post
