Old 10-10-2010, 08:41 AM   #1
dogfish
dogfish's Avatar
Default Mobile Soda Blasting Whats It Worth Brissy
Hi I'm wondering what it would cost to get a Car soda blasted at home and the mess associated with it (BRISBANE).
What damage /warpage can happen to panels and rust issues (IF Any) later on in life as can happen with sand blasting.
Do you need to prime straight away.
Any help would be appreciated.
Cheers.
MY BABY:1968 XT Falcon 500 Factory 302 V8 Auto (Cruiseomatic)Wagon.
With Palomino Interior.
THE TOY:2003 CV8R Monaro 6Spd Manual.
dogfish is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2010, 09:52 PM   #2
wadsymoo
mr xagt
hi,im doing a resto on a lh torana for a customer atm and the owner had it soda blasted.
we ended up getting it sand blated after the soda blasting as the bloke who did it, did a terrible job and left paint,sealer,surface rust,and residue behind and just made a mess of the whole thing.so make sure who does it knows what they are doing.
wadsymoo is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2010, 11:54 PM   #3
OLDFORDNUT
OLDFORDNUT's Avatar
be very carefull,
i know of three cars personally around Hervey Bay that had bonnets ruined by soda blasting,
Unfortunatly everyone thinks Soda is the safe way of stripping cars,like days of old there were good sandblasters and there were bad, today is no different, if you get a bad one they will destroy your panels, two of the bonnets ive seen ,you could actually see where the reinforcing strips /frame was underneath as the top was pushed down enough to have the frame clearly seen impressed into panel. mate just finished his Pontiac Transam,in Toowoomba early this year and its won a few trophies down that way since , but he spent 5 whole days fixing bonnet after Soda blaster spent 5 minutes on it.Dave was not a happy man with soda blaster.
Hervey Bay QLD
Great trades recently- GILMORE
BOSSYONBIKE
OLDFORDNUT is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2013, 07:25 PM   #4
ScottSodablast
Smile Re: Mobile Soda Blasting Whats It Worth Brissy
Hey guys, even though this is an old discussion I thought it best we clear up the previous comments.
"i know of three cars personally around Hervey Bay that had bonnets ruined by soda blasting,
Unfortunatly everyone thinks Soda is the safe way of stripping cars,like days of old there were good sandblasters and there were bad, today is no different, if you get a bad one they will destroy your panels, two of the bonnets ive seen ,you could actually see where the reinforcing strips /frame was underneath as the top was pushed down enough to have the frame clearly seen impressed into panel. mate just finished his Pontiac Transam,in Toowoomba early this year and its won a few trophies down that way since , but he spent 5 whole days fixing bonnet after Soda blaster spent 5 minutes on it.Dave was not a happy man with soda blaster."
I run a Soda and Abrasive Blasting company in Hervey Bay QLD. In 2010 when this post was made there was another company servicing the area but in both our defence there is No Way that the Soda Blasting process can Damage a bonnet or any other metal part or panel.
1. The BiCarb Soda Media is only 2.4 on the hardness scale, there for anything harder than 2.4 cannot be damaged by the Soda.. it will simply turn to dust on impact.
2. there is No Heat in the Soda Blasting process, therfore there is no expansion, shrinking or warping of the metal.
3.If however the blaster used a different media Sand-Garnet-copper slag- Glass-etc.. there is a strong chance that the metal will get heated and upon cooling it will cool at different rates across the different layers of the bonnet. eg. the skin of the bonnet will cool quicker than the area where the skin touches the Frame. This will cause the warping. I know this because I had 1 customer "demand" that we lightly blast the underside of a RX3 Mazda bonnet with glass bead to remove the spiders of rust (Remembering the Soda Blasting will remove even the toughest of coatings but due to the softness of the particle it WILL NOT REMOVE RUST OR METAL). As expected after a light whip blast with Glass bead there was areas between the frame that had warped due to the cooling.
4. in the 5years since we have not had a section of any vechicle damaged or warped by Soda Blasting or by the use of Abrasive Blasting on the areas of the car that can safely be done. we do a Combo Blast on all restos unless the customer has requested we use 100% Soda Blasting.
If you or anyone has any questions on Soda or abrasive Blasting please feel free to give me a call on 0741946660 at Soda Blast Fraser Coast and I'll be happy to answer what i can.
P.s I didnt just join to have my say. I have used your forums for years while building my XY Sedan. a wealth of knowledge is a wonderful thing. I'll be posting again soon with a few questions. Cheers, Scott
ScottSodablast is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2013, 07:33 PM   #5
4stanger
Powered By EcoBoost
4stanger's Avatar
Default Re: Mobile Soda Blasting Whats It Worth Brissy
"due to the softness of the particle it WILL NOT REMOVE RUST OR METAL"
Will it remove surface rust?
4stanger is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2013, 07:42 PM   #6
ScottSodablast
Hey Arnaldo,
no mate it will remove 2cm think of concrete bitumen, paint, Bog, grease, grime, carbon, and a thousand other Coatings but it will not break the surface of the metal.. and that means it will not remove the oxidised metal (Rust). Soda Blasting can also remove the same coatings from a sheet of glass without damage to the glass.
that why we do a combo blast, we use a light abrasive on the solid parts of the car (these are the areas where most rust is) Door jams, round the screens gutters, sills, floor, etc.. and then we finish off with Soda on the softer areas.. Rear 1/4's Roof Door Skins, Bonnet, Boot.
If there is surface rust in these areas they just require a light sand. best way to ensure nothing is warped or damaged.
Old 31-07-2013, 08:15 PM   #7
Chris1001chris
Hey Scott I Was Wondering If You Are Still Operating Your Soda Blasting Company? If So Where Are You Located As I Couldnt Seem To Find Your Shop Today.
Chris1001chris is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2013, 09:04 PM   #8
ohzone
Dent Removal
ohzone's Avatar
Via Google
http://www.sodablastfrasercoast.com/...id=1&Itemid=53
Shed4 10 Driftwood Ct, Urangan.
Hervey Bay
Queensland
4655
Australia
E-mail: info@sodablastfrasercoast.com
Telephone: 0741 946660
Fax: F0741 253608
Give them a call, see if they are still there
ohzone is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2013, 09:14 PM   #9
Chris1001chris
Yeh Thanks Mate I tried Calling But No Answer. Thanks Anyway
Old 03-08-2013, 01:53 PM   #10
ScottSodablast
Hi Chris, Sorry for the late reply. Yes we are still operating in Hervey BAy and Surrounding areas. Have had a Massive few weeks Blasting and must have missed your call. Please give me a call on 0741946660. We are no longer in Driftwood Court but we are mobile so we can Blast On-Site, we also have a pick-up & delivery service.
