Old 02-02-2012, 08:44 PM   #1
vbvbvb088
vbvbvb088
Default WB Festiva - keys locked in it...
This goose has locked keys in it.
Any tips?
Cost of mobile locksmith too break into it ... Melb metro.
Not in RACV as in between houses I missed renewal and they want $180 to join plus annual subs...
matt
vbvbvb088 is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2012, 09:09 PM   #2
4.0i_SiX
SiX_iN_a_RoW
4.0i_SiX's Avatar
Default Re: WB Festiva - keys locked in it...
yes son, Im the best mono-thingy guy there ever was
Oh yeah, my G6ET eats diff bushes for breakfast!
4.0i_SiX is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2012, 09:52 PM   #3
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Ok. Get a really thick wire hanger. Straighten it out. Put a loop at 1 end large enough to go over window winder. Lube gap between door and body with dishwashing liquid. Work the wire down and loop it around the winder. You can unwind the window by moving the wire back and forth.
Took all of 20min. Trust me it works. You must use a thick hanger or it will bend when you try to wind. (the one I used was plastic coated which helped)
Old 03-02-2012, 04:25 PM   #4
vbvbvb088
vbvbvb088
Thanks for your response - i tried but not really getting anywhere... so I had a thought. Place hook ended coat hanger in door frame around drivers lock and hope like hell that by pushing it up and down I would randomly pull up door lock rod,,,, teedah!
Thanks once again....
My 5.0 VT Calais died and non economic to fix a 15yo car....so my Festiva (had a week) is a run around until I buy newer. Way different to drive but as long as keep in right gear can punt along ok. Would struggle with four people however!
Thanks
matt
Old 03-02-2012, 04:33 PM   #5
kypez
kypez's Avatar
Can always do what my mate did. Called NRMA (RACV) and they quoted $120 to unlock it. Called O'Brien and asked how much for a rear quarter window and was quoted $70. He booked in with O'Brien.
On topic though, the old metal ruler used to work as well on some of the older cars. Put in the drivers side area and slide it towards the B pillar. That pops some cars.
My Ford Family...
2014 GT-F, Manual, Kinetic with Black Stripes
2021 Mustang Mach 1, Manual, Velocity Blue
kypez is offline   Reply With Quote Multi-Quote with this Post
