25-06-2012, 09:42 PM | #1 | ||
I was out over my mates today and hes got this old thames truck about a 8 tonner with this ford V 8 in it ,he thinks a 351 {which still runs** was def a clevland v8 i wasnt sure how to identifey it .Did they come out origanaly with a 351 in them ? Cheers Boingz
25-06-2012, 09:56 PM | #2 | ||
aussie coupes belong here
Pretty hard to indentify externally, your best is to pull out a spark plug, wind the engine over by hand, and measure the piston's stroke using a thin piece of wire. From memory a 302 is 3.5 inches(around 90mm) and a 351 is 4inch or just over 100mm. hope this helps cheers Pat
25-06-2012, 10:04 PM | #3 | ||
playing in my big shed
any photos ???
i dont think that they had clevos as original. we had one on the farm in the `70s and it was a 6 cylinder diesel. built in 1964 so long before the clevo. did the truck have a little short slopey bonnet or a a more conventional shaped long bonnet. this is a `65 model, the same style as our old `64. this is called a " K " series. these were built in the later part of the `60s.
`75 XB FAIRMONT sedan . mushroom beige, injected 351, toploader, 9inch `10 FG XR50 Turbo ute. Nitro blue, 6 sp Auto, Leather trim. `04 BA RTV tray back, Red, V8 auto, `04 BA XR6 Turbo sedan. Blueprint. auto, Leather trim. `03 BA XLS ute . Acid Rush, factory lpg, auto, `48 TEA20 Grey Ferguson, `62 Willys 6-230 , 4x4 light truck `04 Yamaha TTR 250 |
25-06-2012, 10:09 PM | #4 | ||
thanks Pat ill check it out 2morrow , ill check out the year dave it looks a lot newer than those trucks u have there ,they look real nice yuor trucks btw
25-06-2012, 10:31 PM | #5 | |||
Oooh baby living in Miami....
25-06-2012, 10:48 PM | #6 | ||
not my trucks. just a couple of examples from the net
26-06-2012, 05:03 PM | #7 | ||
Towies were known for putting V8s into old trucks that had either 6cyl petrols or diesels
a cleveland V8 would have been a much cheaper repower option to the original engine and have a heap more power I remember being at a farm in about 1983 when they pulled an old 50s 4tonne ford truck out of the scrub where it had been sitting for about 15 years It had a flathead V8, no exhaust manifold, the carb was full of rat droppings, the engine and gearbox were both had water in them and the fuel tank had rusted away To get it going they blew all the crap from the carb, drained the gearbox and engine oil until the water stopped and the oil began, used a boat fuel tank on the passenger floor and fitted a battery. Cranked it over a few times and it just fired up. had some fun with it blasting up and down the farm tracks, flatheads sound bloody awesome with the exhaust straight out of the engine It'd have to be worth some money these days as a project vehicle
03 BA XLS 6cyl Ute-Mercury Silver 04 Subaru Liberty GT Premium 99 Toyota 105 series Cruiser TD 99 5.8M Profish plate alloy carport decoration |
26-06-2012, 07:03 PM | #8 | ||
I have a shed load of those trucks. Seven in total ranging from small 2 tonners to large 7.5 tonners.
The Larger Forward control version had a 300 CID petrol six or a 330 Diesel six. They where built from 1957 to 1964. The Larger Normal control trucks started in 1962 had the same engines up to 1964. After that they had the same engine as the D Series and the name changed from Thames Trader NC to Ford K Series. They never had V8s but I am sure some would have been re-powered. The diesel powered trucks where the best. My largest truck has the 330 diesel, five speed gearbox and Eaton no 3 2 speed axle. The one pictured above with the short nose is a baby one, the 4 tonner and will most likely have the 300 petrol or the 330 diesel. The lower truck is on 16inch wheels so it is also a baby. If it is a 2 tonner it will have a large 4 cylinder engine. The engines are the same as those in late Fordson Super Major tractors. I have a lot of information on these and a lot of parts. Steve |
26-06-2012, 07:31 PM | #9 | ||
460 - cubes torque
from memory,
302c 3" stroke x 4" bore (about 75mm x 100mm) 351c 3.5" stroke x 4" bore 400c 4" stroke x 4" bore |
26-06-2012, 07:43 PM | #10 | ||
the one we had was the forward control model . 7 or maybe 7.5 ton . the diesel 6 and 2 speed diff. i cant remember if it was 4 or 5 speed gear box.
it was used daily carrying mill logs, post, hay, livestock, etc often somewhat overloaded and i cant remember it ever giving any trouble. it wasnt the fastest thing around but not much would stop it. that was the first truck i drove when i was probably about 12 or 13 years old.
26-06-2012, 07:58 PM | #11 | |||
The 7.5 tonners here in Aus had the 4 speed box standard up to end 1961 and the the 5 speed after that. 2 speed diff was also standard. At the time they where the largest truck sold by Ford Australia. I also used to drive them on our farm at 13 years old. The sound of that diesel engine is something else. Steve |
26-06-2012, 08:01 PM | #12 | ||
pretty sure ours was a `64 model .. the same as me.
it replaced a `61 model F600.
26-06-2012, 08:07 PM | #13 | |||
In 1965 it would have been replaced by the Ford D750. Steve |
26-06-2012, 08:21 PM | #14 | ||
thanks for the info steve.
last i heard of the truck after dad sold it was the new owner left it parked without the handbrake on while opened a gate and it ran down a hill into a tree. shame because it was a good truck. that was the early `80s.
26-06-2012, 08:45 PM | #15 | ||
Well i did another check 2day it was parked up against this fence ,its just got ford across the front squarish cab ,i measuered the stroke with a peice of 2mm rubber pipe after takin the plug out and turnrd it over by hand it measured 4 inches its only gotta 2 barrel manifold on it and mounted up to what looks like the origanal 5 speed box , it was used for carting horses around but well rusted out now the pan on the back would make a good shed lol .well start it up this weekend if its not chuckin it down
26-06-2012, 09:19 PM | #16 | |||
If so it would most likely have had a 240 CID or 300 CID I6 Petrol from new. My truck in the pic has a 380CID Diesel. Steve http://www.flickr.com/photos/7904662@N02/1938571773/ |
26-06-2012, 09:21 PM | #17 | ||
maybe its a "D" series . something like this
lol.. steve, you beat me.
26-06-2012, 10:13 PM | #18 | ||
thats the truck Dave & Jg
26-06-2012, 11:00 PM | #19 | |||
Excessive Fuel Ingestion
We had a D1000 at the time, with a 300 Canadian 6 in it. She had quite a bit of torque the old girl. My sister has a couple of Thames trucks on the farm, but they're pretty cactus now. Ed
Recommended Forum Traders: RSGerry, trimmaster, 51OAU, EB-92, adxr8, my67xr, RG, ZA-289, kruptor, gassa, Felony, RNXR, Rhino 351, Anchor, Smoke Pursuit, Mr. FPV (through E-Bay), |
26-06-2012, 11:24 PM | #20 | ||
sorry Ed. cant recall it, but then i have only been in this area for 6 years so it might have been before my time here.
