11-08-2013, 07:40 PM | #1 | ||
Walking with God
I was thinking of changing the diesel filter, as it looks like an easy job. What are your experiences of the bleeding/priming of the system?
My workshop manual states that simply turning the key over for 10 seconds (this can be done 3 times) could be enough to get the system primed again. If the car starts, the system is primed. Has that been enough for you all? Or have you needed to purchase a bleeding kit? Cheers, GK
15-08-2013, 08:28 PM | #2 | ||
Was enough for me, I just turned it to the position before ignition about 6 times and it started fine (MB Zetec)
16-08-2013, 11:57 AM | #3 | ||
I happened to do mine last week. I tried turning the ignition on/off/on/off etc. but no go. I could see the air in the fuel line. Maybe I just suck and let too much in...
Anyways, I made this to bleed it out and it worked like a charm: There are 2 holes in the lid, one for the bike pump tube and one to hold the end of the vacuum over.
Mondeo 2011 MC Titanium TDCi. Ink Blue. RIP: Mondeo 2008 MA TDCi. Colorado Red, Leather, Bluetooth, sunroof, Tow pack. C.R. Tech tuning box |
17-08-2013, 02:35 PM | #4 | ||
Walking with God
Thanks for the input guys.
I was beginning to wonder if the average Mondeo owner never did jobs like this! LOL! Cheers, GK
17-08-2013, 02:51 PM | #5 | ||
It was pretty easy to change but required the biggest socket I had and a tub to catch the fuel.
I didn't have any clean diesel on hand to fill the new filter before installing. I am thinking that is where all the air came from. Sent from my HTC Vision using Tapatalk 4
17-08-2013, 05:57 PM | #6 | ||
Walking with God
I'll ensure I get some diesel and soak the filter beforehand.
Did you get the filter from Ford? How much was it? GK
18-08-2013, 03:31 PM | #7 | ||
Just had to hunt down where I jotted down their quote. Too lazy to get the recept out of the glove box...
autopro carramar - 97235667 6/46 The Horsley Drive, Carramar, New South Wales oil - $18.35 air - $30.35 fuel - $26.5 cabbin - $18
18-08-2013, 04:53 PM | #8 | |||
Walking with God
nevetsg, you are becoming a good source of info! Cheers, GK
18-08-2013, 08:47 PM | #9 | ||
I only know what I know from google and YouTube..
Nevetsg.
19-08-2013, 04:17 PM | #10 | ||
Walking with God
LOL!
BTW, could you take a few more pics of the bleeding gagdet you made up? Cheers, GK
19-08-2013, 04:36 PM | #11 | ||
There is no more to take pics of... Other than my vacuum...
**By no way am I a mechanic or subject matter expert** -The tube is a standard bike pump extension and there are 2 holes in the lid of a jar. -Drill 1 hole big enough for the bike pump tube and screw it in (connection was not perfect). -I just drilled my 2nd hole the same size, you can see it just before the 'Dolmio'. -Connect the pump tube to the top of engine, over to the right with cover off. -Start up vacuum and place over 2nd hole. Diesel should start to splutter and flow into the jar. you can see how much I sucked through. -First start took a few sec of cranking because I still had the rear in the air so the bleeder was not level and the most high point. -checked the seal around the new filter for leaks. -Took pic of my new tool for the forums. -Poor fuel back into the tank using the high flow adapter thingy. -Tackled the evil that is the Cabin filter change. But that is another story.
19-08-2013, 06:17 PM | #12 | ||
Walking with God
No worries!
By vacuum you mean the vacuum you created when you cranked the engine right? I also have changed the cabin/pollen filter. It was a right royal pain in the butt. Next time I will replace the hex screws with Phillips head screws to make it easier to get them out with screwdrivers. GK
19-08-2013, 06:29 PM | #13 | ||
By vacuum, I mean one of the things you use to clean your carpet. Stick the end of the hose over the hole in the lid to create a vacuum in the jar.
Nevetsg.
20-08-2013, 08:51 PM | #14 | |||
Walking with God
Thanks! GK
