Old 04-09-2013, 10:06 AM   #1
NC_Steve
She needs premium dude...
NC_Steve's Avatar
Default trailer hub question
I was speaking to a trailer parts supplier who said all trailer hubs carry the weight on the wheel studs instead of the centre spigot. Is there a reason for this as it seems strange to me and I thought it was illegal aswell? Does anyone have hubs that carry the weight on the spigot?
NC_Steve is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2013, 10:30 AM   #2
kempy311
BEN
kempy311's Avatar
Default Re: trailer hub question
Our 3.5t boat trailer carries it on the nuts the center hubs have a 1cm gap all the way around.
My Thread. The new whip: 2014 FGX XR8 Auto in victory gold. Mods : BMC air filter, 1500cc injectors, Walbro 485, 58mm kpm snout, kpm intercooler, 35% front and 20% rear tint, pedders supercar coilovers, whiteline sway bars, Phillips HIDs, lenso d1r wheels.
331rwkw.
12.7 sec stock as a rock with a passenger.
Now with 620rwhp ready to run the 10
built zf, built tailshaft, corn juice all to come.
The old rig: 2008 FG XR8 Auto in dash green with a tonne of mods to make 311rwkw.
kempy311 is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2013, 10:48 AM   #3
foxtrot3
foxtrot3's Avatar
Hi. the studs always have carried the load, If the wheel located tight enough on the hub to centralize it you would need a press to get it on and a puller to get it off. Thats why the nuts have tapered seats, to line the wheels up with the studs. Cheers MD
HI
I'M MICHAEL
foxtrot3 is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2013, 10:57 AM   #4
DJR-351
I am Groot
DJR-351's Avatar
I was going to get in to all the problems of having interference fit wheels but you explained it much better.....
McLaren F1
Dick Johnson Racing
"Those were the days when the cars were cars, they weren't built out of an Ikea pack like they are now and clothed in plastic; they were real cars." John Bowe
DJR-351 is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2013, 11:17 AM   #5
NC_Steve
NC_Steve's Avatar
Ok then why did my dads LTD get knocked back during a roadworthy for having one of the hub rings missing? If the studs were meant to carry all the loads then wouldnt hub rings be obselete?
Old 04-09-2013, 07:53 PM   #6
Random Ranger
nondescript
This is actually incorrect. The load is supposed to be carried by the hub and the studs locate the wheels.
In saying that, the studs take a heap of a torque form acceleration and braking.
Random Ranger is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2013, 09:49 PM   #7
mickbundy
Yep the studs are on the hub .... Which the hub carry's all the load on the axle stub ????? true or false .well that is my under standing .
mickbundy is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2013, 06:43 AM   #8
Sox
RIP...
Sox's Avatar
Actually you're incorrect.
This is a common myth, the hub only serves to centralise the rim, the clamping force of the studs (friction between hub face and rim) bear the load.
Oval Everywhere...
Old 05-09-2013, 10:51 AM   #9
nb_351
building the xe...
nb_351's Avatar
On a road car it's a combination of both the studs and hub
Studs stop centrifugal forces being too high with the wheel nuts clamping it
The hub stops the studs from moving too much in any direction under force
Hence why you need hub rings with aftermarket wheels if the centre hole is bigger on the wheel
Plenty of broken studs on cars where people don't run the right hub rings on aftermarket wheels
slowly but surely fixing up the king of the road
WANTED
P5 ltd/landau taillight centre panel
nb_351 is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2013, 02:20 PM   #10
OLD BALDY
With the son-inlaw last week adjusting the handbrake on his Crummydoor Berlina about 2005 model had to bash the standard mags off the hub with a very large hammer!!!!!l
OLD BALDY is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2013, 11:23 PM   #11
nb_351
building the xe...
nb_351's Avatar
Yeah a lot of the problem is the alloy reacting with the cast hubs, plus the small tolerances, sometimes welding the wheel to the hub haha
WANTED
