Old 11-04-2014, 03:08 PM   #1
Pinballlez
Pinballlez's Avatar
Default Surging MC Mondeo TDCi
Any ideas what would be causing my 2011 MC Mondeo TDCi to "surge", this is more easily detected under load. A part from change in engine noise another noise is evident from passenger side of engine bay (Turbo ?)
I have booked in to Ford after Easter to look at this but I am concerned I may do some major damage if I continue driving, and yes warranty expired last month.
Pinballlez is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2014, 12:24 PM   #2
ope126
ope126's Avatar
Default Re: Surging MC Mondeo TDCi
Maybe bad fuel, clogged DPF, clogged air filter, Maf sensor.
Have a look at all these and maybe add some Liqui Moly or similar Diesel additive or any DPF safe additive and see if that helps. Keep us posted.
Maybe go for a longer drive and give it a boot full to clean her out!
2016 (MY17) Ford Mondeo Titanium EcoBoost (Moondust Silver)...more power please!
ope126 is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2014, 02:58 PM   #3
Fishman
Fishman's Avatar
I had mine surging a little while ago mostly between70 and 80 kph. I had a diesel place have a look and they cleaned the intake and it was much better
Fishman is offline   Reply With Quote Multi-Quote with this Post
Old 04-05-2014, 11:25 PM   #4
Pinballlez
Pinballlez's Avatar
Left it with Ford who were unable to find a problem, a long drive had "cleaned" it out however fault has returned plus occasional rough idle, will look to clean MAF sensor later this week.
Will keep you posted
Old 04-09-2014, 10:33 PM   #5
ope126
ope126's Avatar
Was there an outcome? Other Diesel owners might be interested in what caused this issue.
Old 21-09-2014, 09:10 PM   #6
ope126
ope126's Avatar
Now that I have just replaced my EcoBoost with a TDCi I would like to know if there was an outcome from the dealership. Knowledge is power and if there is something you can share that might help other, please let us know!
Old 22-09-2014, 05:30 PM   #7
cobrin
Challenge Accepted!
cobrin's Avatar
Having just changed my Fuel Filter, and reading your post, I had the occasional hunting (also called surging) on first cold start idle. Well now thinking of it I haven't noticed it since the change. I'll keep an eye on it but I'd start with the easy stuff.
cobrin is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2014, 10:55 PM   #8
cobrin
Challenge Accepted!
cobrin's Avatar
update I noticed today a slight surging at idle on startup today. So that rules out a filter change.
Old 29-01-2015, 06:16 PM   #9
Pinballlez
Pinballlez's Avatar
Question Re: Surging MC Mondeo TDCi
An on going saga with Ford who are unable to diagnose issue "surging", I had thought transmission/ clutch slippage in power shift gearbox, but no joy! Recent service and software upgrade appeared to fix issue, this lasted as long as the 45 minute trip home. Throw in the occasional trip with rough idle / miss.
Engine light has come on today, a quick stop at my local non ford mechanic has thrown up 2 error codes
P2456 - diesel particulate filter pressure sensor 'A' circuit intermittent / erratic
P2463 - diesel particulate filter restriction - soot accumulation.
Now have two train of thoughts - Dpf has been the problem all along, or wrong oil has been used at service?
Note last week completed 350km trip in one hit surely this would be enough to clean system
Old 29-01-2015, 06:39 PM   #10
mik
mik's Avatar
Hi Pinballlez, what sort of driving do you normally do ? short trips / long trips/ mixture ?
Old 29-01-2015, 06:51 PM   #11
Binny
Maybe a problem with the sensor or wiring going to it?
If not it could really be sooting up more often than it should be. Do you fuel up at the same place all the time? Dodgy diesel will cause bulk sooting. I only ever use BP Ultimate or Caltex vortex diesel as they tend to burn cleaner.
Chips or ECU tunes can cause excess sooting too if you have any of them fitted.
2016 Kuga Trend TDCi
Binny is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2015, 08:20 PM   #12
Pinballlez
Pinballlez's Avatar
Mik, travel 12km's to work, average speed 75kms plus, however car will sit 4-5 days a week without use
Binny, fuel is normally from one outlet, caltex premium diesel mostly used, most recent fill up BP
Jason
Old 29-01-2015, 11:14 PM   #13
mik
mik's Avatar
cheers mate,
i found an interesting article on diesel particulate filters you may be interested in, its a pommy article , but still relevant i think..
http://www.hypermiler.co.uk/technica...filter-dpf-faq
Old 30-01-2015, 09:16 AM   #14
Pinballlez
Pinballlez's Avatar
Smile Re: Surging MC Mondeo TDCi
Great article, explains a great deal
Old 06-02-2015, 04:56 PM   #15
Pinballlez
Pinballlez's Avatar
Exclamation Re: MC Mondeo TDCi DPF relacement.
As per below, I am looking for a quote on replacing Dpf & dpf sensor, any suggestions for north east suburbs of Melbourne?
Ford have now reported and quoted the following
P2456 - dpf differential pressure sensor circuit intermittent / erratic
P2463 - dpf - soot accumulation
P2452 - dpf differential pressure sensor open
Regen carried out, road test showed Regen failed
Suspected fault with dpf pressure sensor
The expensive bit!
Sensor $471
Dpf $5,106!!!
Old 06-02-2015, 09:43 PM   #16
Binny
Holy crap!
Old 07-02-2015, 05:24 AM   #17
gumby123
LW Focus TDCI
Default Re: MC Mondeo TDCi DPF relacement.
The expensive bit!
Sensor $471
Dpf $5,106!!!
What a rort. Aftermarket DPFs are out there, you might have to order it in from the UK. e.g.
http://www.ebay.com.au/itm/FORD-MOND...item19f6b44ecc
gumby123 is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2015, 03:59 PM   #18
Paul22
I notice you said you use Premium diesel. A few months ago I read an article (can't now remember where can't remember when) that running premium diesel is not recommended on many (not all) modern diesels. Apparently premium diesel doesn't have the same connotation as premium petrol. Perhaps it might be an idea to check this out, say, with Ford for a start. I avoid the premium diesel and I'm not having the problems described here. Jus' sayin' is all!
Paul22 is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2015, 05:14 PM   #19
Pinballlez
Pinballlez's Avatar
Interesting article
http://www.team-bhp.com/tech-stuff/w...premium-diesel
Old 07-02-2015, 05:39 PM   #20
Pinballlez
Pinballlez's Avatar
http://www.caltex.com.au/FPL%20PDS/V...m%20Diesel.pdf
Mondeo owners manual says to use spec EN590, above product sheet suggests it meet most?
Old 07-02-2015, 09:03 PM   #21
mik
mik's Avatar
i would have used the alleged good stuff too old mate,
logic says a clean fuel system must be better, but two different pages there both have different views on fuel type x .
anyway, best of luck getting your limo back on the road for a reasonable price.
Old 07-02-2015, 10:31 PM   #22
Binny
Hmmm, I would take that with a big grain of salt. Its talking about India not Australia so who knows what the definition of Premium Diesel is over there. It could be completely different. For a start it sounds like you have a choice of regular or premium, like you do with Petrol here. Whereas Caltex and BP call theirs Premium but it is your only option if you go there and its the same price as any other servo anyway.
Everyone has a different experience but it "feels" like my car runs better on BP or Caltex and has less turbo lag. I have also noticed that if use the Shell or Matilda near me I notice it doing DPF cycles more often.
I personally think regardless of brand its more important to make sure you get diesel from a large busy servo that turns over a lot of it so its fresh. And in my case one that wasn't under metres of water and mud during the floods.
Old 26-04-2015, 09:52 AM   #23
tjsports
Hi Pinballez,
Any luck with your car? My wife's 2011 MC has just stated surging too. I thought gearbox/clutch at first but it could certainly be DPF problems. If it is the DPF I would look at ketting it taken out and the car re-tuned.
tjsports is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2015, 08:16 PM   #24
Pinballlez
Pinballlez's Avatar
Replaced Dpf differential pressure sensor, approx $400, and replaced blocked Dpf, found a wreck with 20,000kms, $250 for the dpf, has fixed most issues.
Clutches appears to still have minor slip under load, symptoms are rattle from transmission and noticeable taco bounce whilst holding gear. full transmission service due soon, will keep you posted on outcome
Old 26-04-2015, 08:51 PM   #25
tjsports
This youtube video is identical to my problem
https://www.youtube.com/watch?v=lCyKCL0weXg
The guy says a gearbox service fixed his problem. My wife's car didn't have any error codes and only has 35,000kms on it. So hopefully an oil change will fix the problem but I won't be happy if it needs a service every 30,000kms.
Old 17-05-2015, 09:22 PM   #26
tjsports
The $350 gearbox oil change/service fixed the problem.
