18-05-2014, 07:32 PM | #1 | ||
I have a au series 3 4.0L i6 auto.
It has the following mods, 2.5 inch cat back exhaust and panel filter, plus xr6t snorkel. I also have an air deflector fitted behind grill. Anyhow under WOT I noticed the car would change up at just before 5000rpm, to me it felt like it was a little too soon. Surely I was giving up a few kW up top. So I did this mod as a test. 1. Replaced the pipe from airbox to rest of intake with a straight piece of 3inch aluminium pipe. Removed fitting from airbox lid to get it in. 2. Flicked the panel filter and Grabbed a 45 degrees 3 inch pipe and fitted up a 3 inch pod filter inside the stock airbox. Used a 3 inch piece of silicone hose to join the two pipes. RESULT: There is a noticeable difference in off the line, mid range and top end power. It now is happy to rev out to 5200-5300rpm before changing up and feels more powerful in doing so. There is a little bit more induction noise from the pod but it's enclosed in the stock airbox. Great mod... Under $100 all parts. The stock intake pipe that I removed closes up to about 2 inches at the point of the airbox, it must be restricting the power. There is probably going to be a fuel economy advantage as well. To compliment this mod, I'd grab a xr6t snorkel and also the air deflector you can make yourself with a bit of aluminium sheet. If your AU is changing up before 5000rpm @WOT try this intake mod and enjoy the benefits. |
18-05-2014, 07:34 PM | #2 | ||
Racing improves the breed
Nice one Hulk, where did you get the new alloy pipe from? Any pics?
1970 Mini Cooper S Historic Group Nc Touring car 1964 Mini Cooper S Historic Group Nb Touring car 2024 Subaru Outback Touring XT Victorian Hill Climb Championship |
18-05-2014, 09:21 PM | #3 | ||
19-05-2014, 10:43 PM | #4 | |||
5.6L x 2 pilot
Cheers Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
2 users like this post: |
19-05-2014, 11:18 PM | #5 | |||
I doubt therefore that peak power has changed, but it is likely that more air is being sucked into the engine at high rpm with the restriction removed.
20-05-2014, 01:26 AM | #6 | |||
I've tested it plenty times, it's definitely true. |
20-05-2014, 01:31 AM | #7 | |||
It's definitely feeling more powerful, car just pulls harder everywhere. I'd be happy if I'd done a full exhaust and it made such a change as it's done. |
