Old 04-12-2014, 10:08 PM   #1
bigal74
Default Horn Button on MK1 indicator stalk
Howdy fellas.
Took off the end cap of the indicator stalk to check the condition of the contacts for the horn switch. Can't for the life of me get it to go back together and stay together. Is there some special trick to it or do I need to use some adhesive? Thanks.
bigal74 is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2014, 12:25 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
Default Re: Horn Button on MK1 indicator stalk
glue it , tape it , what ever is needed
this ebay seller wants $284 plus postage for the part.... and its used
fit a push button to work the horn somewhere handy
Attach sticker .."Horn broken watch for Finger"
http://www.ebay.com.au/itm/FORD-ESCO...item3399db0c8e
My car goes Brumm Brumm
Old 06-12-2014, 12:50 PM   #3
jpblue1000
jpblue1000's Avatar
How did you get it out/apart big al?
From memory, long time ago I think the button has a ridge around the base to prevent it being pushed out of the housing.
leverage may damage/strip this ridge.
I believe the button was installed while the two halves of the housing ot the wand were apart then glued together around the metal stalk
They are getting rare.
If its concourse you'll need to pay up or get greative otherwise adapt something from another car or relocate elsewhere like steering wheel center
JP
jpblue1000 is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2014, 06:26 PM   #4
bigal74
Dirty hands and JPblue, thanks for the reply. She's definitely not concourse, so I'm not gonna spend up on ebay. Some "mechanic" I was speaking to said he "remembered" that you could lever off the end cap with a sharp blade and fix if required. Of course I've now discovered that the switch is working fine and it didn't need fixing. Doh!!!
Anyway here are a couple of pics showing what I've done.
Old 08-12-2014, 09:13 PM   #5
dirty hands
Over Thinker
5 minuite araldite but make sure the horn works first
Old 09-12-2014, 11:32 AM   #6
bigal74
Thanks Dirty, the horn works when put straight onto a battery which was why I thought the switch might be dodgy. Thinking now might be a dirty earth or I might need to clean up the fuse box a bit.
Old 14-12-2014, 04:47 PM   #7
I bought a Land Rover Series 3 one which works and fits perfectly in mine. My horn worked but the indicators were playing up.
http://www.ebay.com.au/itm/575383-La...item43bdd201c7
Old 15-12-2014, 05:10 AM   #8
bigal74
LG17 thanks for the tip. I'm going to put mine back together as the indicator switch is fine. Worth keeping in mind though.
Old 15-12-2014, 07:48 AM   #9
Russ
Russ's Avatar
I never had any trouble with the horn or indicators working on mine when I had it many many years ago, I do however remember having to hold the stupid stalk with a fully closed hand and it pull it up or down to turn on the indicators :( It was either that or the centre part of the stalk would spin around, the indicators wouldn't be engaged and eventually the wire/s going to the horn button would shear off Araldite was a temporary fix for that problem but in this instance it should work fine Design has certainly come a long way since the early seventies
