Old 26-01-2015, 10:01 AM   #1
c0n13oX
Default Wheel width advice needed (LS)
Hi all,
New to the forum, ive got a 2005 LS zetec hatch and i am looking at upgrading the rims. Just wondering what sort of width i can go out to. Im currently looking at some 18x8.5s with a 40 offset. Is anyone running a similar setup?
c0n13oX is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2015, 04:37 PM   #2
DZFord
DZFord's Avatar
Default Re: Wheel width advice needed (LS)
18 x 8 is OK, I'm not 100% on 18 x 8.5.
Your offset is OK though - recommended between 38 and 52 for the Focus if I recall correctly.
Old 28-01-2015, 09:16 PM   #3
c0n13oX
well im thinking if this guy can fit 18x8.75s i should be ok... but wheels are on the back burner now that my clutch has gone :/
Old 28-01-2015, 09:26 PM   #4
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Talking about wheels does anyone know the size of 18" MA Mondeo wheels as I'm keen on a set when my current tyres wear out.
Franco Cozzo is online now   Reply With Quote Multi-Quote with this Post
Old 28-01-2015, 11:27 PM   #5
dazFX
XR5s have their turning circle limited compared to a normal focus, you might get rubbing with full lock
dazFX is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2015, 11:47 PM   #6
c0n13oX
do you reckon ill be right with 8.5's then? its more of a poke issue than rubbing issue. will they poke out of the wheel well?
Old 29-01-2015, 11:46 AM   #7
DZFord
DZFord's Avatar
XR5s have 8" width WITH the steering limiter
So 8.5" without the steering rack limiter on your LS Zetec may cause a rubbing issue.
I wouldn't purchase these wheels without a trial fitment
Old 25-03-2015, 07:32 PM   #8
c0n13oX
Has anyone had problems fitting 18x8 on a lowered ls?
Current:
2005 LS Zetec
Previous:
1995 Mitsubishi FTO
1997 Honda Civic
Old 26-03-2015, 12:48 PM   #9
c0n13oX
Also, just went into a wheels shop, and the guy said id fit 8.75's on without scrubbing. I dont think hes right, but id be curious if they could fit them under, especially when lowered.
Current:
2005 LS Zetec
Previous:
1995 Mitsubishi FTO
1997 Honda Civic
Old 26-03-2015, 01:32 PM   #10
marg99
I thought they limited the turning circle on the performance models with the wider wheels.
