10-01-2007, 04:01 PM | #1 | ||
fit 'n' turn
Hi All
Im new to this site and forums in general so please excuse any bad etiquette. So here's my dilema i have just changed the upper control arm pivot bushes in my old xf ute as it was squeaking more than a whores bed. That fixed the problem for all of 5k's now its back just as bad. Has anyone had this problem before? Any advice greatly appreciated. Cheers Box |
10-01-2007, 04:04 PM | #2 | ||
Former BTIKD
Spray it with brake fluid.
Using a 'Hairdressers' waterspray bottle from any $2 shop
10-01-2007, 04:07 PM | #3 | ||
fit 'n' turn
thanks mate still hoping to fix the problem rather than cover it up.
Thanks for the reply. |
10-01-2007, 04:12 PM | #4 | ||
G'day and welcome
i had the same problem and it was the metal on metal rubbing that caused it, mine was fixed when i replaced them... did you greese them good? have they been torqued up properly? may be the shockies saddle that is worn did you replace that at the same time? You could also try CRC but this won't last if using brake fluid watch your paint. I know how anoing this is i put up with it for years |
10-01-2007, 04:13 PM | #5 | ||
Former BTIKD
No problem. It used to work for me.
I goes without saying that you DONT get brake fluid on the paintwork though
10-01-2007, 05:01 PM | #6 | ||
growing up is optional
Sure its not the upper ball joint squeaking? Have had this problem many times at work. Some of the aftermarket joints dont have provision for grease nipples. I usually poke a small hole in the rubber boot and spray CRC into it with a nozzle. Give it a try.
10-01-2007, 05:12 PM | #7 | ||
V8 wannaabeee
probably ball joint... i know what will fix that, an e - series :P
10-01-2007, 05:12 PM | #8 | |||
10-01-2007, 05:52 PM | #9 | ||
fit 'n' turn
Thanks for the suggestions fellas i will try them out for sure.
10-01-2007, 06:30 PM | #10 | ||
I have the same problem too.
Replaced all the bushes about 6months back fixed it for about a month but it back. i also found that when i didn't drive it for two weeks for about a week it didn't do it. good luck with it all and let me know the results
BA MK11 XR6- Black |
10-01-2007, 09:22 PM | #11 | ||
SZII in Silhouette
It's a standard XF feature....... Apparently if it disappears you can go to Ford Spares and order another box of squeaks..........
. . Strangers have the best candy....... |
10-01-2007, 10:44 PM | #12 | ||
Spring saddles!!replace them.
FORD RULES OK The more I know ppl the more I love my DOGS. 2011 SY Territory Limited Edition TS 2000 AUII SE ute IL6 |
11-01-2007, 05:24 PM | #13 | ||
fit 'n' turn
hey guys i tried the brake fluid and crc still no joy.
Just got some new spring saddles which i'll chuck in tomorrow will keep posting results untill fixed for those interested. thanks again for your replies and ideas :voldar02: Box |
13-01-2007, 05:45 PM | #14 | ||
fit 'n' turn
And the winner is SPRING SADDLES!!
Congratulations MO And Coupdy Do! Thanks to all who have replied to this post, legends all. Box |
