Old 08-02-2007, 11:18 PM   #1
tonks0108
Default What's this damn rattle in the back?
I recently purchased a 12/05 BF XR6 turbo with only 8000 k's on the clock. 2000 k's later I've got this annoying rattle in the back somewhere that is especially noisy over bumps and small potholes. The dealership I bought it from tells me it is the control blade suspension that requires tightening of bolts at each service, but to me it sounds like shoddy shockers. Anyone got any ideas?
tonks0108 is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2007, 11:54 PM   #2
Pedro
Pedro's Avatar
I had a rattle in the back of my 3/06 build F6. Ford service couldn't find it, but I did. It was the U shaped catch attached to the rear bulk head that holds the rear seat back in place. It had been cross threaded at assembly and left loose.
Pedro is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2007, 12:41 AM   #3
holmsy
holmsy's Avatar
i think our xr6 has that as well. it sounds like it comes from the around the wheels somewhere.
holmsy is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2007, 03:12 AM   #4
Night Runner
- V8 ENTHUSIAST -
Night Runner's Avatar
I had an AU with the same noise and rattle as you're a describing. Does it sound like the spare tire could be loose on some bumps, that kind of bumping? The AUs were quite common at getting this and perhaps a few BAs/BFs get the problem too.
My guess is that it's one of your rear top shock mounts that has worn out. Some don't take long, 8K+ it could definitely be possible. We changed mine, peace and quiet, no more annoying rattles.
My 0.02c
Vehicles: 4 V8s & 1 V10
Night Runner is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2007, 07:19 AM   #5
tonks0108
Thanks for your suggestions, I will check them out. (Despite the noise its still the most enjoyable car to drive that I have owned!)
Old 09-02-2007, 07:50 AM   #6
CrankR
XR6 Madness
CrankR's Avatar
Yep i have the same rattle... definately sounds like suspension to me.
Took the XR6 into Ford for its 30 000 service and let them know, they said "We noticed you have and after market exhaust... that's where the rattling would be coming from."
What a load of crap! U didn't even check did u! I said.
Further diagnostics needed, they wrote on the service card.
BA XR6 na - K&N, F6 Intake, Red Back Zoorst,
Custom Tune, Underdrives, Paccie #4490's with 2 1/2 Magnaflow
CrankR is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2007, 08:20 PM   #7
AussieJason
AussieJason's Avatar
WTF ? Poor quality control and workmanship by Ford there. Makes you wonder about what else may be shoddily done on other Falcons out there...
Current Falcon:
2005 BF Falcon XR6 Vixen
Previous Falcons:
2003 BA Falcon XL Ute White
1994 EF Falcon GLi Aqua
bseries.com.au Member
And drive a Holden company car...
AussieJason is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2007, 12:27 PM   #8
RogueDriver
I have this same problem in my BA XR6 (2003). I also have the standard non-functioning handbrake problem.
Funnily enough, when I had the handbrake fixed under warranty, the noise completely disappeared. A few days later, the noise came back. So I checked the handbrake and, sure enough, it no longer worked.
So it seems when the handbrake is working the noise is gone.
Can anyone take any guesses as to which part that could be?
RogueDriver is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2007, 04:06 PM   #9
cArSiK
I had a similar problem with my 04' BA XR6T. It took Four (yes 4) trips to ford to get fixed. It turned out to be a bad weld in the parcel shelf that didnt take properly from the factory. They re-welded the shelf and the noise is all gone...
Hope this isnt your problem as this is a pain in the a$s to get ford to fix.
James
cArSiK is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2007, 04:08 PM   #10
cArSiK
My 0.02c
BA/BA dont have the same style shock mount that the AUs have in the cabin. With Control blade the shock mounting is in the wheel well.
